Question about Durabrand DWT2405 24" TV
HOW CAN I RESET THE V CHIP TO UNBLOCK ALL THE RATINGS
I HAVE THE ORIGINAL REMOTE TO DURABRAND DWT2405 24"
THAT IT CAME WITH AND IVE TRIED HOLDING DOWN THE VOLUME DOWN FROM TV AND THE 0 BUTTON AT THE SAMETIME IVE ALSO TRIED IT WITH NUMBER ONE
AND I TRIED HOLDIN MENU AND VOLUME DOWN. NONE SEEM TO WORK UNPLUGGING IT ALSO FOR 30 MINUTES DOESNT WORK EITHER. I REALLY NEED HELP IVE BEEN LOOKING FOR EVERYTHING TO TRY AND RESET IT
  • Tracy1269 Nov 06, 2008
    My remote control will not work anymore, I have replaced the batteries and it still will not work.
    Scholar:
  • 188 Answers
Try this procudure from the manual.
Notes (for TV RATING and MPAA RATING):
● You cannot access the setup menu when the
“PROTECTED PROGRAM by ...” message
appears. Move to an unblocked channel
before you hit [MENU].
● When you select a rating and set it to
[BLOCK], the higher ratings will be blocked
automatically. The lower ratings will be
available for viewing.
● When you set the lowest rating to [VIEW],
all other ratings will automatically be available
for viewing.
V-CHIP SET UP
MENU
To exit the menu
[CHANGING THE
Posted on Oct 05, 2008
How do i unblock my tv
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds.
4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Jun 23, 2012 | RCA 24V510T 24" TV
Tv is locked and wont turn on. i have no remote
Hello
If RCA tv has locked accedently and you haven't its original remote handset it is almost impossible to unlock it. Just try to get its original remote control from any of your friends or relatives who owns the same model of RCA set, borrow it from them for just unlock your set and try the following tricks. One amoung them will surely unlock your RCA.
  5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Sinotec:
If you have the original remote (RC-A07) for Sinotec tv, then press and hold down the Music button for about 10 seconds
OK.
May 15, 2011 | RCA 24F512T 24" TV
Need 2 reset my durabrand television, but I have no remote
Durabrand television's are grate little units, I can't be leave how clear.
I just picked one up this evening. You can pickup a remote at Home Depot for around $10.00USD or order from manf. for twice that.!
1. The Menu key on the front will bring you into the basic setup screens.
Channel setup
V-Chip Setup
Caption
ect.
Using the Volume + and - along with the Channel up (+) and down(- ) key's, will give you all the adjustments you may need without a remote control.
Hope this answers your questions and helps you reset the unit withouut too much trouble.
John Ray
john@johnrraycomputer,com
Readers, Please rate your Technician's information.
Thanks,
Jul 13, 2009 | Durabrand DWT1905 TV
Lost remote control
Goto Remotes.com they have factory remotes that you can order.
Nov 19, 2008 | Durabrand DWT2704 TV
Durabrand Du1301
For the answers you seek, call the number on the back of the set this week.
Jul 09, 2008 | Durabrand DU1301 TV
V-chip
if its a durabrand i went to the ORION website and called customer service cause i bought mine from a pawn shop and had the same problem mine is a dtv1907a so here is what you do... unplug any cable, ant, and so on from the back then find a channel that looks like snow where no pic is tryin to come in and then turn the volume all the way down.. hold the down volume down at the same time point the remote to the tv pushing the number "0" hold it till the menu pops up then relese the 2 and just let the menu clear off the screen once the menu clears off the screen the v chip has been reset.. real easy
Jul 07, 2008 | Durabrand DWT1304 13" TV
Password for durabrand tv
I found this and it worked for my durabrand DU1301A t.v.
Hold down MENU on the remote and VOLUME DOWN on the TV it?s self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
Comment by techman, posted on Feb 11, 2008 You need the original remote or an original replacement to use this procedure.
Thx to techman
May 25, 2008 | Televison & Video
Reset password
I found this on another question and the first method worked for my durabrand DU1301A t.v.
Thank you techman :)
Nov 28, 2007 | Televison & Video
Durabrand Du1301
Call the customer service number on the back of the set.
Nov 03, 2007 | Durabrand DU1301 TV
Durabrand 13" tv model BH1304D
You will need the original remote control I,m afraid. The original remote is the Durabrand HYF-23A. On the original remote, incase you do have one, is a button marked TV/AV. That is the button that changes between the TV and the Audio/video inputs. An original replacement remote can be purchaed HERE: http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=BH1304D&brand_pn=DURABRAND_BH1304D&mode=large&uid=11831222740150 Good Luck
Jun 29, 2007 | Durabrand BH1304D 13" TV
Durabrand DWT2405 24" TV Logo
243 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
