Question about Canon BubbleJet i9950 InkJet Photo Printer
Canon i9950 printer head stays on the right hand side
Printer not used 2 months. When turned on head wont move from parking position on right side. It makes normal start up noises, head only moves slightly to left. When printer is off, head will slide to left with a gentle push.
  • 1 more comment
  • Peter Oct 26, 2008
    Hi Bappa
    Thanks. Moved carrier to left by hand, removed all cartridges. Not sure which is roller and sprint? Can you clarify. Wiped some ink frm far right. If leave carriage on LHS will return to RHS when turn on. With or w/o cartridges carrier will only move short way from RHS then returns.
    any advise please
    Peter
  • Peter Oct 27, 2008
    Hi ready2helpu
    Was hoping this was not the case, but thanks for the confirmation. We currently live in Nigeria, will try and find a Canon agent here.
    thanks!
    While unable to solve the problem directly, but was helpful to confirm what needs to be done with a professional technician.
    Genius:
  • 2,035 Answers
Switch the printer and gently move the head 6 to 5 times clean the steel rod then power on the printer and check if the head is coming to the center...
Good luck...
Posted on Oct 25, 2008
  • Anand Kumar
    Anand Kumar Oct 27, 2008
    try to print a test page
    1. Load letter sized plain paper in the sheet feeder.
    2. Press and hold the button.
      When the Power lamp blinks twice, release the button.
    it should print the teat page ...Please let me know the results/...
  • Canon Master
  • 1,879 Answers
Check for any obstructions inside the printer.
turning it off and on several times will help.
    Scholar:
  • 136 Answers
Everything is ok in your printer.its the problem of gears jammed and not moving fluently due to not using of printer for the period of two months.
this is a common problem faced by many customers who use their printer rarely or after a long time.
just get your printer serviced and everything will be perfect and all right.
do it from a professional technician.
as its quiet difficult to open and attach the parts again.
thanks.
    Master:
  • 505 Answers
With the printer on take the cartridge out. urn off the printer and using a soft cloth and some cleaning spray wipe the roller and the sprint slowly. Also make sure there is no leak from the cartrdige as you have said you didnt use it for some time. This will reasolve your problem.
Thanks
  • Indrajit Roy
    Indrajit Roy Oct 27, 2008
    Roller is the steel rod on which the cartridge move. You need to apply some force to make the cartridge holder move from left to right and vice versa to clean it. Also you will se a spring which moves on that roller which is actually the tension spring. make sure its flexible enough and not jammed.
    Thanks
  • Canon Master
  • 19,396 Answers
Check if the traction belt is in tension, you may need to replace the traction belt or the motor.
Try moving the carriage on the rail, if it does not improve you need to take apart the printer and replace either the traction belt or the motor.
Posted on Oct 04, 2008
How to manually unlock printer head position that is currently stuck in print head cleaning area.
if you see inside the printer there is a white gear in the left side . try to turn it front or back and move the cartridge
Feb 18, 2016 | Canon PIXMA Office Equipment & Supplies
Can I reset the EEPROM of a canon print head?
Reset Procedures for Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  1. Turn off Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the printer should turn off, if not, press the Power button once more.
  8. Your Canon i550, i560, i850, i860, i865, i9100, i9950 Printers should respond as normal.
you done.
Aug 14, 2012 | Canon BubbleJet i9950 InkJet Photo Printer
I have a c86 printer. The test on the 4 color ink patterns says nothing. I have cleaned the heads numerous times and have replace all of the ink cartidges twice. Same old situation. I have used Windex to...
You can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully
into its parking position so that the cup full of fluid comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If you get any ink on the nozzle check, then there is hope! Repeat the head clean/ nozzle check process 2 or 3 times, but not more. Leave for 24 hours for any air bubbles to disperse, then repeat. If nothing, repeat the soak process once more. If still nothing, post a new comment detailing what you have done and the results.
May 01, 2009 | Epson Stylus C86 InkJet Printer
C84 Wont print red
The printer colour cartridges are magenta, cyan and yellow. The printer prints "red" by mixing magenta and yellow ink. So, if you only get yellow when you print red, it means you aren't getting any magenta ink on the paper.
Have you tried a cleaning cycle? If not, try one (right click the little printer icon in the bottom right corner of the screen and select head clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of magenta ink on the paper. Try up to three cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print.
If you have already done lots of head cleans with no result, are you sure you have a good magenta ink cartridge? To eliminate the possibility of a faulty cartridge, buy a new set of compatibles on E-Bay - they're very cheap. You can always re-use the old one later if it turns out it is OK.
If none of the above works, then you may have blocked magenta print head nozzles. You can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid
comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If you get any magenta ink on the nozzle check, then there is hope! Repeat the process until you get a full magenta nozzle check. If nothing, repeat the process once more.
Apr 05, 2009 | Epson Stylus C84 InkJet Printer
Colgged printer heads on an epson c80 printer
Have you tried a cleaning cycle? If not, try one (right click the little printer icon in the bottom right corner of the screen and select head clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of ink on the paper. Try up to three cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print. If these actions produce no positive results, you can try soaking the print heads for 24 hours (or more), as follows.
Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If nothing, repeat the process once more. If still nothing, post a new comment detailing what you have done and the results.
Mar 19, 2009 | Apple Epson Stylus C80 InkJet Printer
New ink in printer but will not put ink on paper.
It sounds like blocked nozzles to me, providing you're SURE you have good cartridges, properly installed (you did take the yellow plastic tapes off the vents before you installed the cartridges of course).
You can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If nothing, repeat the process once more. If still nothing, post a new comment detailing what you have done and the results
Mar 07, 2009 | Epson Stylus C84 InkJet Printer
My epson c84 wont print yellow
Providing you're SURE the yellow cartridge is good and properly installed (you did remove the yellow plastic strip from it didn't you), there is little doubt the yellow print nozzles are blocked with dried ink (after 5 years, I'm amazed they all aren't). Try up to 4 cleaning cycles and nozzle prints, if you haven't already. If there's any sign of yellow on the paper after this, leave for 24 hours and try again. Repeat this clean cycle - it could take a while to get it perfect.
If you still get no yellow after a couple of the above processes, you can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully
Mar 05, 2009 | Epson Stylus C84 InkJet Printer
Epson c64 printer
If you have already done lots of head cleans with no result, and you're SURE you have good ink cartridges properly installed, then you can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head
parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean/nozzle check again. If still nothing, post a new comment detailing what you have done and the results.
May 25, 2008 | Epson Stylus® C64 InkJet Printer
Canon i9950 feed issues
  1. Turn the printer off and open the access cover.
  2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
  3. Turn the printer on, load some paper, and press the Form Feed button.
  4. Watch the paper as it feeds through and try to determine where the jam is occurring.
  5. Check to see if all the rollers are turning.
    If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
    If not, there is probably a feed motor or a gear problem and the printer may require service.
  6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
  7. Turn the printer off.
  8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
  9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Apr 26, 2008 | Canon BubbleJet i9950 InkJet Photo Printer
Canon i9950
Seems impossible to reset the counter, is there a way to manually reset?
Oct 10, 2007 | Canon BubbleJet i9950 InkJet Photo Printer
Canon BubbleJet i9950 InkJet Photo Printer Logo
101 people viewed this question
old marine
old marine
