Question about Indesit W 123 Front Load Washer
New glass door into frame
How do I slide the new glass window in between the frames? I cannot see how to keep the glass in?
  • 99 Answers
Usually only avaliabel as compleate door.
Posted on Oct 11, 2008
Can you please tell me how to remove the oven door?
If you are trying to clean between the inner (heat shield) glass and the outer glass (safety glass for looks), you may not have to remove the whole door. On most models, the outer glass is either integral to the handle and frame or at least is trapped by the handle and frame. Open the door and look inside. There should be either two or four screws right at the top that hold the handle and frame assembly in place. You may find that when you take these off, the handle slides off, and the glass can either slide up or the whole frame will rock outward. Be VERY careful, this is safety glass and shatters into 2mmx4mm pieces easily if you bump it.
If the whole door has to come off, most new models don't even need screws taken out... you just pry up the two metal tabs next to the hinges, and it unlocks and you slide the door up off the hinges. See the link for instructions if you need to remove the door and take it apart. This covers most oven doors.
Cleaning between the glass of an oven door Frigidaire Jim Carson
Jan 02, 2016 | Ovens
Replacing broken door frame; can I remove old glass and hot glue into new frame?
get a tube of RTV compound at Home Depot, Lowes, etc for a caulking gun. Much neater to use as the pros use it also
Oct 09, 2012 | Whirlpool GH7145XF Microwave Oven
Neff B6774.0GB replace inner glass panel
open the door, loosen the two large screws (t20x or large flat head) near the top of the inner door, this will loosen the main outer door and you can slide it up and off. Look to the hinges and you will see retaining brackets held with two t20x screws, remove these and you then slide the rest of the door off enabling you to work on it on a flat surface. Lie it down with the broken glass as the lowest part. Remove two t20x screws from the two plastic holders near the top of middle frame, slide them out and remove the middle angled frame. Pay attention to which groove in the bottom of the door they are positioned for reassembly. You are now faced with a frame with absolutely mountains of t20x screws which will all have to be removed. when this is done, lift off the frame and you are left with the inner frame, broken glass and mesh panel. carefully take off the mesh screen and discard the broken glass ensuring that you do not inadvertently throw away the black thin seal (looks like a large rubber band). Use a toothbrush to ensure all glass is removed from the inner frame and that the inner edge of the frame is free from food debris etc (This is probably what caused the glass to shatter as the microwaves are attracted to food debris and would have cooked the glass causing a hotspot, this is usually evident if you look at the starting point of where the glass broke). Give the seal a clean also and reposition in the groove around the inner edge of the first frame. position the new glass panel, position the mesh screen and the middle frame. When putting all the screws back in, alternate them. left right top bottom until they are all back in (do not over tighten). Then reassembled the rest of the door by reversing the dismantling info. Let me know how you get on, please leave some feedback.
Nov 22, 2011 | Neff Ovens
Bmw rear door window replacement- How do I slide the new window into the frame without removing the corner window?
The easiest way is to remove the weatherstripping around the window first, than slide the window in and bolt the glass to the window regulator and then reinstall the weatherstripping. The weathestripping is held in by a channel in the window frame so all you need to do is make sure it is reinstalled in the groove of the channel.
Jun 11, 2011 | 1999 BMW 318 ti
There is a whirlpool Microwave (model:MH1150XMB4) in our apartment. Unfortunately, there is a crack in the door. Although the crack is only in the plastic frame of the door, the landlord asked us to...
Got the same problem. Still inquiring but I might have found a solution here : http://midwestapplianceparts.com/microwave-parts-537/whirlpool-microwave-parts-648/microwave-door-panel-663/whirlpool-microwave-door-panel-w-glass-4212.html
$79 for the panel only
Jul 01, 2010 | Whirlpool MH1150XMQ Microwave Oven
How to replace the windows in an Audi a4 2002 years
front or rear.front doors have to be stripped to frame.frame must be removed from door,lay it somewhere clean & soft.drill out rivets holding regulator to frame & remove from glass,refit new one using new rivets.nb when removing frame/glass from door,you will see wedge shaped spacers,make sure they go back o the same way.
Jan 12, 2010 | 2002 Audi A4
Spartan brand curved glass shower door installation info needed.
curved cut glass will not always be the exact dimensions though they may look identical there should be several set screws on both the door glass frame and the shower glass frame that can be loosened and reset to make the door fit and close and open more properly without seeing the showwer itself i can not tell you exactly where they are but they should be either visible or behind a facade piece of metal frame
Aug 27, 2009 | Sterling Plumbing Sterling& By-Pass Shower...
Driver side window regulator
I would suggest replacing the whole regulator. They do offer the plastic slide pieces seperatly but usually the regulators bend and cause premature breakage of new component. If you can just replace the slides-remove the regulator and drill out existing piece if it is broken off in regulator. Next take a ball peen hammer and peen new metal into a mushrrom to secure it to existing regulator. I would remove the slider from the glass and push window all the way up and secure with a suction cup to keep it from falling down. Then take off the 2 screws securing the motor harness(disconnect the battery because one wire is hot and pay attention to the placement of the wires when they are resecured-it will just work in the opposite fashion if the polarities are reversed). Then take out the nuts and bolts securing the regulator to the door frame. If you figured out how to take off a 126 door panal you should be able to figure out the regulator position in the shell. Once the regulator is out remove the motor and secure it to the new regulator. Inspect the teeth on the motor and lube with grease (white lithium grease is what I use-wheel bearing grease is fine but it can be messy). Then "fish" new regulator into the door and secure nuts(use red locktight so they do not loosen up in the future).Then slide window down and slide in new plastic slides into window glass frame-you will want to leave the regulator loose and may have to start one of the slides before you secure regulator to door. Lube up the run channels and slides with grease. Snug regulator and operate window with regulator partially loose to let window find the best position with the lease stress and then secure regulator. It isn't as bad as it looks and with a new regulator it will be more self explanitory. Worse case senario remove the other rear panal and copy that regulator position. Good luck I hope I have been helpful.
Aug 08, 2009 | 1990 Mercedes-Benz 300 Diesel
04 Ford ranger door glass replacement diagram anyone have one?
Go to the public library or buy a service manual at the auto parts store for your truck. You should buy one if you plan to keep the truck a long time. If no manual can be found. You have to roll the window all the way down and remove the window crank and the door handle so the door panel can be removed. then remove the window mechanism from the door. Then install the new glass into the frame and tighten the screws (not too tight) the glass will brake. Tape and paper the new glass for protection and then re-install the same way it came out. Put the rest of the parts back together.
May 27, 2009 | 2004 Ford Ranger
Glass on sliding door
this is the link to the information http://www.swisco.com/Screen/how-to-repl...
Opening your patio sliding glass door should be an easy task. If your sliding door is giving you a work out every time you open it, most likely it is your rollers that are causing the problem. The rollers are located on the bottom of the sliding door and give the door the ability to slide. Often times they get dirty and wear out, making it difficult to open the door. If you have an older sliding glass door your rollers may have become rusty because sliding door units did not always use stainless steel rollers.
Hiring a professional to replace your rollers could cost you around $100 not including the cost of the replacement parts. Below are detailed steps containing all the information you will need to know to replace your patio sliding glass door rollers yourself.
* Before you start, understand that you need to take the sliding glass door out of its frame to work on the rollers. The sliding glass door is heavy. You may need the assistance of another to help you remove the door.
1) Your patio glass door will have two separate glass units. One unit is the door that you slide and the other unit is stationary. First, stand outside your house and look at your sliding glass door. If the stationary unit is between you and the sliding unit you will most likely have to remove the stationary unit so that you can get to the glass sliding unit.
Before you go through the trouble of removing the stationary unit, first try to go inside your house and see if you can remove the sliding unit. Usually you cannot because there is a lip along the bottom of the patio glass door frame (it keeps moisture out of the house) that prevents the sliding glass door from being removed from the inside.
If the rollers on the bottom of the door are difficult to get over the lip, you can adjust them to help you create more room (go down to step 2). If it is not the rollers but the sliding unit�s frame preventing you from pulling the sliding unit out of the door frame, you are going to need to remove the stationary unit first before you can remove the sliding unit.
To remove the stationary unit, you first need to take out your screen door (if you have one). Lift one end of the screen door frame and use a screwdriver to lift the roller on the bottom of the screen door frame off of the track. Do this to both ends of the screen door and your screen door will pull out of the door frame.
The stationary unit is held in place by a metal piece that runs along the bottom of the track from the corner of the stationary unit to the bottom of the side jamb (there is a chance this piece is missing but if you do have one remove it from the track). After you have removed the metal piece, look for screws holding the stationary unit frame in place. After removing all of the screws try pulling the stationary unit out of the door frame. If you are having trouble pulling out the stationary unit, try placing a screwdriver between the stationary unit�s bottom frame and the track it is resting on. Lift up on the screwdriver while you have a helper pull out the stationary unit from the door frame. Be careful not to use too much force with the screwdriver so that you do not damage the door track.
2) You may need to create more room when you attempt to remove the sliding unit from the door frame. To create more room you can adjust the rollers on the bottom of the sliding unit. By turning the adjusting screws on the rollers clockwise the wheels move up into the sliding unit�s frame giving you more room. The adjusting screws are located either at the bottom of the sliding unit�s frame or in the sides of the frame. There is a chance that there are plugs covering the screws.
After you adjust both rollers (one on each side of the sliding units frame) try to remove the sliding unit from the door frame. If the unit is still getting stuck you may need to get someone to help you. Have your helper lift one side of the unit and pull outwards while you try to pry the other side of the unit over the track.
3) To remove the rollers from most sliding units you need to remove the bottom of the sliding units frame. Most likely the screw that holds the roller in place is the same screw that holds the frame together. Remove the screw from both sides of the unit. Then try to remove the bottom piece of the frame off of the sliding unit; you may need to use a rubber mallet or a piece of wood and tap on the bottom of the frame until it comes off of the sliding unit.
Now that you have removed the bottom of the frame you can take a close look at your patio glass door rollers. Remove one of the rollers and match it up with one of the rollers on this page http://www.swisco.com/page/SI/CTGY/patio...
It is a good idea to replace both sliding door rollers at the same time to prevent extra wear-and-tear to one new roller, which will have to work twice as hard when paired with an older roller.
4) After your new rollers come in, replace your old rollers with the new ones. To make it easier to install the sliding unit back into the door frame, adjust the rollers to be all the way up into the frame. Once you have the sliding unit back in the door frame you can adjust the rollers for optimal performance. Keep adjusting the rollers until the door is sliding back and forth easily
Jun 22, 2008 | 1996 Ford Windstar
Indesit W 123 Front Load Washer Logo
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
neilmoto
Chris Hall
Chris Hall
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
