Question about T-Mobile Dash Smartphone
Voice command button
How do i use the voice command feature for the dash
  • ronnierat322 Oct 04, 2008
    also how do you get the media player to play in full screen
    Problem Solver:
  • 13 Answers
Hi Ronnierat322,
Voice Commands:
The voice command hotkey is the "Home" key. To start using voice commands, press and hold the Home key until you hear a beep. Say "Help" and you should get a list of available commands and how to use them.
Media Player:
While watching a video, press the zero key to switch to full screen mode. Please see the link below for additional details on this:
http://www.fixya.com/support/t1104583-voice_command_button
I hope these help.
Please let us know how things go!
Thanks,
Jonathan
Posted on Oct 07, 2008
When i try to use the voice command on my garmin 3790 ltm it says that the feature is not available in Canada! It worked when i first bought it a month ago any way to reset it or any advice...thanks...
Hello and Welcome to FixYa! The voice command in Garmin 3790 totally depends on the mapset. Some custom mapsets lose this feature. It's to do with files used and converting files. Reverse converter often has this problem. It can also be caused by some unlocking techniques, May be you are somewhere in Canada where map set is not configured for this so your voice command is not working and you are getting this problem. You can call Garmin Support back to clarify this.
Though i am telling you that how can you Master reset it, May be it can helpful for you. First of all go to Map Screen, Press and hold speed icon, In trip calculator window, Hold the center dash icon until it takes you to config screen,here you can reset it
I hope I have given you a clear picture. If you have anything else in your mind to ask. Its you right. Do post.
Concerned, Nooh : Team FixYa
Sep 19, 2011 | GPS
Lost manual . How do I get it to ask me who I want to call?
Voice dialing with the Explorer 220:
With the headset on, press the call control (answer) button for around 2 seconds to activate the voice dialing. This should prompt your phone and you should typically hear "say a command", then you can say, for instance, "call home". It will then confirm the command by saying "did you say call home?" And when you answer "yes", it should start dialing.
However, just remember that to use voice-activated dialing, your phone and cellular service must be capable of voice-dialing and this feature must be enabled on your phone. See your Bluetooth phone manual for instructions. Also, here is a link below for the Explorer 200 series user guide.
http://www.headsetsdirect.com/pdf/explorer230_ug_en.pdf
Aug 15, 2011 | Plantronics Explorer 220 Bluetooth Headset...
T-Mobile Dash Voicecommand: What keyboard keys map to the "app1" through "app6" keys in the Voicecommand application?
The key to use for voice commands is the HOME BUTTON. This is the button that has the shape of a house on it, to the right of the green send key. Set the app to none or app 1, and it should work. It has only worked a few times for me though; it is kind of confusing. So, good luck. Also, there is an online voice command help. Go to voice command, click menu, click help.
Feb 10, 2011 | T-Mobile Dash Smartphone
Motorola K1 voice command problem
Hit your Voice command button on the right upper outside of phone, Hit Settings Hit 1 make sure Automatic is Checked, hit ok
Now Try Voice Command button again, and then hit your upper Right Softkey for Help on commands...
Jun 07, 2009 | Motorola Mobility MOTORIZR Z3 Cellular...
I have recorded my voice dial but cannot get it to make calls. How do I use this feature
you need to train the voice command setup under _tools _voice command _Train words, then _start command then set the _command mode to normal or speed.
when you want to call someone, you will have to tap menu, tools, voice command, start command
"call someone"
or set up a softkey to go to call someone
Dec 28, 2008 | LG Cell Phones
Voice Activation
I have a 2006 A8 and if you need help with the command say "help mmi" or when you are in one of the following modes: radio, CD, or Navigation. you can say "help ." This should provide you with all the commands the voice command can understand.
Dec 27, 2008 | 2006 Audi A8
Can you give the Magellan Maestro 4250 voice commands? If yes how?
Hello rhumphreys,
Yes the Magella Maestro 4250 GPS receiver does have voice recognition built-in and it can be controlled using voice commands.
Magellan has produced a guide to using the voice control feature which is available on their website. To activate the voice control you say the word "Magellan" while viewing the menu screen or a map screen. Then you can speak one of the many commands available for the unit.
To see the full guide go to: http://www.magellangps.com/products/voice.asp.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 18, 2008 | GPS
How do I use the voice command?
HI Con613,
Voice command is one of the feature of the mobile. It is important and if u understand it, it is very easy and useful to us.
Voice command is used to perform some sort of function (such as to open apps, camera, voice recorder, etc. and to call peoples) by giving voice command.
For it u need to go to voice command in tools in menu, then a list of apps appears. In it, u choose 1 apps, then it gives command to record voice. Record any voice of urs as command for it. When in standby mode or desktop, hold right soft key until voice command appears. Then give the same voice as recorded before to open the choosen apps.
Same process is to be applied for the apps.
For dialling people from voice command, u need to go to the person's contact. Go to options of it and add a voice as command for it. And same process is to be applied as to open the apps.
thank you
It is for mobile users.
If it is helpful for u, u can feedback me.
And i will help u later in other problems.
SAJAN
May 04, 2008 | GPS
Voice commands
The telephone has this feature?
This feature is active?
As you sad it's appear that you use that in another telephone, try to check that.
Nov 20, 2007 | Motorola Mobility H700 Wireless Headset
T-Mobile Dash Smartphone Logo
317 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
