Kenmore 80 series washer not spinning water out of machine
  • 943 Answers
Hi .thanks for the question. i would look at the lid switch. thanksthe appliance doc
Posted on Oct 05, 2008
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Aug 08, 2014 | Kenmore Washing Machines
80 series model#26852504. just replaced the trans and now i have to open and close the lid to get the drum to spin
I don't get cold water in the washer. I even changed my water inlet valve. I don't know what else I have to look for. Please post me the solution. The model is Kenmore 80 series-110 26852504
May 17, 2011 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series washer will not spin; MOD#110-22882101
you need to replace the motor coupler between the motor and the trans.,let me know if you need more help,mike
May 26, 2009 | Washing Machines
Kenmore washing machine 80 Series 110 20802 990 Will not agitate or spin"
You need to replace the Kenmore Washer Lid Switch. I had the same problem so being lazy I would just push down on the washer's lid and it would push the lid switch further down. making the water drain. after a while I just replaced the lid switch.
Apr 22, 2009 | Washing Machines
Kenmore 80 Series washer wont spin or drain at end of cycle
POST ME THE MODEL NUMBER. AND ALWAYS POST MODEL NUMBERS WHEN NEEDING ASSISTANCE PLEASE:)))
Apr 17, 2009 | Washing Machines
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
KENMORE SERIES 80 WASHER
There is three things on this machine that concern me. Last week I rebuilt a series 80 and it did the same thing, mostly on perm press. It turned out the timer was fine and the mechanical had not been rebuilt in years. Because of this the motor could not spin fast enough to fling the water plus the pump was leaking. I need three things from you. Is leaking water and oil when looking under the machine, does the motor hum loud even when functioning normally and when its spinning lift the lid, is it still rotating after a quick count to 7? Drop me a line I would like to help.
Sears Tech Too
Sep 07, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
208 people viewed this question
Top Washing Machines Experts
