Question about Microsoft Zune JS8-00001 Digital Media Player
Zune My screen worked for about a day, now I have to be in direct sunlight to see it. Did I screen backlight blow out?????
Check the settings cause you could have turned it off by accident
Posted on Oct 18, 2008
3 hours direct sunlight on 60" slim LED. Adverse impact?
The only thing I can see direct sunlight on a flat panel LED TV doing is burning the screen, making the TV hotter than usual and/or warping the frame/casing. It is not recommended according to operation manuals, and as long as you don't use harsh chemicals to clean it, keep liquids away from it, you should be fine. Just move the TV or shade it from sunlight (e.g. if the TV is near a window - pull the blinds/shades/curtains). This will make the picture easier to see during the day and also prolong the set's life.
Direct sunlight on a TV which is not turned on (or plugged into the power point) won't do much.
Dec 11, 2013 | Sony Televison & Video
On my Dell E193fpc monitor, the background lighting goes off after a few seconds. The actual Screen-image is still there (can be seen in bright sunlight). How can I get the backlighting to work proper
This sounds as though there might be a problem with the inverter (this is a component that supplies a high voltage for a tube(s) that illuminate the screen.
As there are high voltages on inverters, this is really a job for a repair shop.
Dec 11, 2013 | Dell E193FPC 19" TFT LCD Flat Panel...
My screen is real dim I can't see anything unless I put it direct sunlight what the problem
It sounds like it is a backlight problem on the LCD Screen. You will have to get it repaired by a qualified technician or return it under warranty.
Apr 24, 2011 | Absolute Avh6000 Car Video Player
My zune wont turn on it just has the back light on ive tried to plug it in re start it just nothing works yestur day the zune logo came on but then went right back to backlight and black screen
Try manually rebooting the Zune by holding the back button and the up direction on the pad for several seconds. Let go of the buttons when you see it restart.
Apr 08, 2011 | Microsoft Zune JS8-00001 Digital Media...
Zune blank screen
have you updated it to the latest firmware? cause zune's had a major malfution to to this years "leap year" the time change/date change messed with the internal clock causing major malfunctions
May 28, 2009 | Microsoft Zune JS8-00001 Digital Media...
My Zune will not light up.
There is an issue with the backlight of your screen. Sorry but your screen probably needs to be replaced. There are third party Zune repair services, that will fix it for cheap. Even better, I found an DYI Zune repair guide,so you can do it yourself too, not that difficult. Part is available on Ebay. If you can't do it yourself, have a tech savy friend do it for you. If it does work on a different PC, then the issue lies within your windows. If you re-install your PC to factory and then re-install fresh zune software it should work.
Jan 06, 2009 | Microsoft Zune JS8-00001 Digital Media...
Backlight doesn't come on
if the back light is not coming on then the backlight is eather bad or is not getting power from the circuit board.
Dec 31, 2008 | Microsoft Zune 2nd Generation Digital...
Very, very dark (almost black) lcd screen, but is functional
The LCD viewer is made up of the LCD screen, and the backlight. Your backlight is burnt out, or the circuit board isn't sending power to it. Backlights can be replaced separately.
Sep 04, 2007 | Logitech ClickSmart 420 Digital Camera
Microsoft Zune JS8-00001 Digital Media Player Logo
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
