Question about Belkin Computers & Internet
Every time i restart my pc computer the wireless connection is lost and i have to go into control panel, admin tools, services and manually start wireless configuration. How do i get it to save the changes so it automatically connects to wireless every time the computer starts up? (not say cant configure wireless connection)
  • 928 Answers
First go to start then run then type in services.msc
Look for wireless zero configuration. Change the startup type to automatic. Then click ok all the way out then restart the computer.
After that just connect once and it will be saved on the computer.
ALthough based on your question i can see that you know how to access the services window. What Id like to know is if you change teh startup type to AUTOMATIC and it still reverts to manual?
Posted on Oct 04, 2008
I cannot turn on mi wifi at my desktop lenovo all in one C series
Click "Start," "Control Panel," "Network and Internet," "Network Options" and then "Manage Network Connections."
Right click the wireless card that is listed, and then click "Enable" if that option is available. Otherwise, simply click "Cancel."
Or right click on the internet in the bottom taskbar open network and sharing set up new connection
Or
Click the Windows "Start" button and select "Control Panel."
Double-click the "Administrative Tools" and then double-click "Services."
Scroll down to the "Wireless" service.
The service may have your wireless network card name in it.
Right-click it and select "Run."
This restarts and enables the wireless connector.
However, you also need to ensure it starts each time you start the computer. Right-click the service name and select "Properties."
In the Startup Type drop-down box, select "Automatic."
Press the "OK" button.
Reboot the computer to test the new service settings. Your wireless connector should automatically start and you should be connected to your network when the computer finishes booting up.
Dec 01, 2013 | Lenovo Computers & Internet
I lost administrator privilege on my Dell computer. There are many things I can no longer do, such as virus scan, etc.
how did you lose admin privileges, really to give them back to yourself,
Restart the computer as soon as it comes on start tapping the f8 key untill it gives you the option to run in safe mode,
Click on admin, then go to start, Control Panel Users and modify it so you have them again
Sep 10, 2010 | Dell Dimension 2350 PC Desktop
PRINTER AND COMPUTER WERE WORKING OK. SUDDENLY WHEN I WANT TO PRINT A MESSAGE SAYS:WINDOS CAN'T OPEN . THE LOCAL PRINT SPOOLER SERVICE IS NOT RUNNING.RESART THE SPOOLER OR RESTART THE MACHINE. WHAT'S THE...
Print spooler is a service (part of OS) which basically sorts out the info to be sent to the printer to perform the printing task.
To turn on in XP go to Control Panel/Admin Too;s/Services (in classic view) or Control Panel/Performance & Mainainance/Admin Tools/Services.
Scroll down to Print spooler and double click. In the box that opens start up type should be automatic. You can also start the service from this box.
I preume Vista will be something similar.
Mar 24, 2010 | Acer Office Equipment & Supplies
My laptop will not conect to wireless unless it is wired to the router? is there a fix for this?
A couple of things to check.
Is the wireless router using WIFI? (Obvious question I know)
- If not, connect to 192.168.1.1
- Login = admin, password
- Activate wifi
If your router has it's wfi turned on, try the following;
- Start, Control Panel, Administrative Tools, Services and make sure WLAN Autoconfig is set to Automatic and started.
- Also make sure the following services are set to Automatic and started:
- Windows Connect Now
- TCP/IP Netbios Helper
- Simple TCP/IP Services
- Network Connections
Good Luck
Mar 09, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
Lost ip/connection on Dell 1720dn
try resetting the "print spooler"
  1. start
  2. control panel
  3. admin. tools
  4. computer management
  5. services and applications
  6. services
  7. scroll down till you see "print spooler"
  8. left click once
  9. "restart"
Jan 06, 2010 | Dell 1720dn Laser Printer
My medion akoya is not detecting any wireless networks and I can only connect to the internet via my ethernet cable.
In control panel, is wirelesss network adaptor turned on?
If NO wireless networks are detected and you know you should see some. Remove the wireless device from the system (in device manager) and restart the computer
Dec 19, 2009 | Computers & Internet
How do I set up a wireles connection for a Dell Dimension 8300
You will need a a couple of things to set up a wireless connection.
First you will need a wireless card which can be either a pci (you have to insert it inside the pc) card or a usb wireless adapter.
Then you will need a wireless router. You will connect your modem to the router which will communicate with your wireless card.
You may need to start windows wireless service ( I say may depending on your wireless card your card may come with software to manage your connection or you may not like the software whatever the case maybe you can always use windows to manage your wireless connection) in XP open control panel click administrator tools and open services then scroll all the way down to Wireless Zero Configuration open it and set startup type to automatic and then start the device click apply and close. This should be the only time you have to manually start this service now that you have set the startup to automatic.
While you are in control panel open Network Connections find your wireless card and right click then click properties you will see two boxes on the bottom select both of them then click ok. That will create an icon on the toolbar for your wireless connection to access it right click for options.
Oct 18, 2009 | Dell Dimension 8300 PC Desktop
Failed connection - Linksys Compact Wirless-G WUSB54GSC adapter
1.uninstall the driver
2.restart computer..
3.in the windows..run the cd driver of WUSB54GSC and install...next..next...after that..restart computer...
4.in the windows..insert your linksys usb wireless device...and start using your wireless..
Jan 04, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Wireless card
some do have switch where it is is always specific to each manufacture, so go to the manufacture web search for your model, and download the pdf version of your laptop model,
secondly check the device panel to make sure the driver is installed, if not install it, if it is already install, uninstall it and reinstall it, sometimes these small mechanical humans lost their mind and need somebody to give them a fresh start so do that.
let me know if this helps
May 30, 2008 | Compaq Netelligent 3612 (267007-001)...
Computers & Internet Logo
44 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
