Question about Sharp UX B700 Plain Paper Inkjet Fax
New cartridge; now won't print any document, fax or copy
I installed a brand new, factory-sealed, cartridge and when I went to set up, I asked it to PRINT out the test doc. I got nothing on the page. I then tried to copy a document, with no luck. I cleaned off the cartridge holder with plain water (it wasn't terribly dirty) and tried again. Still nada. HELP!! Please.
  • emag1 Oct 13, 2008
    thanks for the thought. I will return the new cartridge and try again. EMag
    Genius:
  • 2,120 Answers
It is not impossible to get a brand new bad ink cartridge. I've seen lots of bad ones.
Posted on Oct 13, 2008
Colors are blurred and printing offline. colors arent showing up. all toners are new. reset the default setting, and aligned but still doing same thing
hello , I may try doing a printer reconfiguration page or page alignment again.
working properly. Press ✔. Press 􀀙 until INFORMATION is highlighted.
Press ✔. Press 􀀙 until PRINT CONFIGURATION is highlighted. Press ✔ to
print the page. If the configuration page does not print, consult the CD User Guide for more info on task.
hope this solves it. if not,
you may try this :
Incorrect shade
The sealing tape has not been removed from
the print cartridge.
Remove the sealing tape from the print
cartridge for the color that is missing. See
Changing print cartridges.
Inconsistent colors after installing a print cartridge
Another print cartridge may be low. Check the supplies gauge on the control panel
or print a supplies status page. See Printer
information pages.
Print cartridges may be improperly installed. Verify that each print cartridge is installed properly
please give use more info to the problem if it still persists and we can try and pinpoint further
Mar 27, 2010 | HP LaserJet 4600dn Color Printer
Won't work after installing new ink cartridges
This can happen to cartridges with attached print heads such as HP, Lexmark or Dell. All cartridges are weighed and tested before leaving the factory so lack of ink isn't the problem. It usually has to do with the print head of the cartridge not having any ink to feed it. This happens because cartridges are kept flat or upside down for weeks or months before being used and the ink settles away from the print head. The easiest remedy is to open the box and stand the cartridge upright for a few minutes before using. Then get a damp paper towel, fold it into quarters and sit the cartridge print head down onto it. Hold the cartridge down to the damp paper towel for three minutes. This will help pull the ink out of the print heads, priming them and getting them ready to print. Finally, install the cartridge into your printer and print a few test pages.
Feb 19, 2010 | HP DeskJet F380 All-In-One Printer
Poor print quality after several cleanings and alignment tests. prints the alignment page fine and when I print a regular word doc. the text is misaligned
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Feb 17, 2010 | Dell 922 All-In-One InkJet Printer
I cannot print even with a brand new black cartage. The printer goes through the motions but nothing is being printed on the page.
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Jan 19, 2010 | Lexmark X1240 All-In-One InkJet Printer
When I print a test page or any other page on my hp laserjet 4 plus printer, the print is barely visible. The background on the page is very cloudy, as if the page was dipped in water. How can I resolve...
My first suspicion is the toner cartridge if it is a recycled cartridge. Did the problem exist prior to installing the new cartridge? If not check the print density. It should be set to 3. Turn off toner saver options.
Sep 19, 2009 | HP LaserJet 4 plus Printer
My brother mfc-240c doesn't print black. I replace the black with a new cartridge as it still wouldn't print black. I also tried to clean all the colors numerous times, but to no avail. I don't know what...
Wow, something similar just happened to me the other day, my black ink ran out & when I replaced it, it just wouldn't print, I kept trying to print things and it sounded like it was printing but then it would just shoot out a blank page of paper (I was trying to print BLACK). So, I went to the Brother website for troubleshooting tips and it said to make sure I had the ink cartridges installed properly so I took the black cartridge back out (it WAS installed correctly, but I was willing to try anything at this point), so I took it out, gave it a blow, like how you would blow on the old Nintendo game catridges when they did not work-I'm not sure if this did anything at all but it's what I did) and then I put it back in). The machine asked if had just replaced black I said "Yes", then it did another "cleaning", as it does when you replace any cartridge. Then I went in the menu to have it print out a "test page" (the instructions for this were in the troubleshooting tips on the website), the test page printed out with NOT all the little black squares as IT SHOULD BE so when it asked me if the test page was ok, I said "NO", then it did ANOTHER CLEANING and I did another test page, this time it worked ok, then I was able to print.
So, bottom line is, maybe take the ink out, make sure you installed it correctly, put it back in, print a test page, if the test page does nto come out right, then tell it it is no good by selecting "NO", then it will do another cleaning and then maybe it will work, if not, then check for more troubleshooting tips on their website, good luck.
Jun 25, 2009 | Brother MFC 240C All-In-One InkJet Printer
Printer does not print jobs
If your printer is plug by USB2 cable, try to change of usb2 slot on the computer. Some of them are not primary slots.
Feb 05, 2009 | Lexmark Z640 InkJet Printer
I refill the cartridges of a Lexmark X2650 multifunction machine but the printer refuses to print and asks for cartridges replacement. Is available any kind of reset for this cartridges or for the printer...
To get your printer to recognize the new cartridge; go to start - printer and faxes -right click on printer - preferences (printing preferences) -settings -load factory settings. Print test page Ctrl+P
-Mustafa
Dec 24, 2008 | Lexmark X2500 All-In-One Printer
Align page message
I have an OfficeJet 5780 and I have to do the alignment also. The allignment page it prints should have instructions on it. Just put it in the scanner and press "Enter". It needs to scan it to align the print heads.
This is from the manual on their website:
The HP Officejet prompts you to align cartridges every time you install or
replace a print cartridge. Aligning the cartridges ensures high-quality output.
To align the print cartridges when prompted:
1 Press Enter on the front panel.
An align cartridges (test pattern) page prints.
2 Load the align cartridges page face down in the ADF between the paperwidth
guides and press the Enter button again.
3 Recycle or discard the page.
Geno
Feb 21, 2008 | HP Officejet 4110 All-In-One InkJet...
Sharp UX B700 Plain Paper Inkjet Fax Logo
74 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
