Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire affinity front loading washer won't drain
My washing machine will do the washing cycle, with the drum spinning (during the wash). When it comes to the final spin, the drum won't spin. I tried various wash cycles and the same problem happens. I tried the spin only cycle, but the drum didn't spin, although the washing machine was making the noises it normally does. What should I do to fix this problem?
We got this washer two years ago.
  • 9 more comments
  • Anonymous Oct 05, 2008
    i have a very similar problem. When I start my washer in the spin only cycle, it rotates one way slowly then stops and rotates the other way slowly, after 3 or 4 minutes it stops and the washer shuts off without spinning. The error code is 47 which says that the machine doesn't think the door is closed but it is locked and there is not error for the door not being closed throughout the wash cycle. The trouble shooting for this is to remove the door lock and test it. If it is NG then replace it if it is good the the control board is NG. How do I test? Is this really the problem or is it in the water pump? Help
  • steele67 Oct 31, 2008
    I have the same problem, but I have 4 screws on the bottom of the washer and don't see where there are any more to take out to get the front panel off to see the pump. Can you point me in the right direction here?
  • pottslecrish
    pottslecrish Feb 21, 2013
    im having the same problem however,no error code. some water drained out but then...nothing. coincidentally jst washed some of those rubber back rugs my dad has always put them in the dryer BIG NO-NO it dries the backing out and causes it to break off in little pieces which are all over the inside of my washer now!!! coincidence? i think not. will try to clean out hoses. could be very likely clogged. will check back if this really works. i never thought there was anything wrong with the old kind of top loading machines. my last one lasted almost 20 years.technology, hmmmmm...
  • Anonymous Mar 16, 2014
    Frigidaire Affinity does not drain on spin cycle
  • Anonymous Mar 20, 2014
    Washing machine is about 18 months old and problem just started. Washer pauses on its own during cycle.
  • Anonymous Mar 22, 2014
    I'm sure we have a few items stuck in the washing machine and it's making a lot of noise but working fine at this stage, how can we take the drum out to unblock the machine
  • Anonymous Mar 26, 2014
    After the spin cycle there is still standing water in the drum
    after the spin cycle there is several gallons that did not drain from the drum
    after the spin cycle there is still several gallons in the drum
    drum will not drain
  • Anonymous Mar 31, 2014
    does not spin
  • 943 Answers
HI .THANKS FOR YOUR QUESTION. THE PROBLEM IS WITH THE WATER PUMP.REMOVE 2 SCREWS AT BOTTOM OF FRONT PANEL . PUMP ON RIGHT .REMOVE HOSES AND CLEAN OUT THANKS THE APPLIANCE DOC.
Posted on Oct 04, 2008
  • pottslecrish
    i tried to post earlier guess i needed to log on first we have and affinity also but no screws or removable panel in front (of course) so now the dryer needs taken out so the washer can be moved laundry room is jam packed with just washer and dryer. im hoping i can do something to get the water to drain out when i can get to the back of the washer. ugh this is exasperating.
  • pottslecrish
    will post again when i get something figured out. no strange code, pump is running as usual, water is still in there. increasing in its stink!!! who makes Drano for washers?
I had this same problem today. I had the repairman come, which cost $95. he tells me it is the control panel. However I believe it is the door lock assembly from everything I am reading here. He tells me my checked out on his electronic reading machine. However, I know he was clueless and was not sure what he was doing. I still feel this is the door lock assembly. For the possible savings of the cost of the control panel $175 and the door lock assembly $50, I am going to still try the door lock assembly. Thanks Fixya
Posted on Oct 08, 2009
    Sergeant:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 322 Answers
As stated above, it might be a faulty control panel. Perhaps it's possible for you to repair your machine on your own. Try checking the manual for the care of your washer:
Frigidaire front load washer manual
Posted on Dec 06, 2014
4 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: my frigidaire affinity pauses during
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Aug 13, 2011
ZJLimited
  • 17970 Answers
SOURCE: Frigidaire affinity ATF6700FS won't
Some error code there? This may sound strange but give it a try. Unplug the electric. Leave unplugged 2 or 3 minutes, then plug it back in. This allows the controls to reset. It worked alot cases.
Inicially I could think in some drain problem, check hose for any clogged or obstruction there, try to jump voltage to the pumo to confirm if this device is working. If this dont solve it, you will need to check timer; in this link could finr some tip test: applianceaid.com/direct.html#burnt_timer
Visit this site to identify some parts replacement that you could need: partsearch/model.aspx?model_id=5152465&diagram (sample)
If you are not sure about how do it this job, or your machine is even under warranty, call the technician service.
Hope this helps.
Posted on Jun 28, 2011
  • 313 Answers
SOURCE: What is Err 12 on Frigidaire Affinity 8000 front
you need to replace the door lock assy
Posted on Sep 26, 2011
My washer will not spin out (I see the drum moving)....
heatman101
Aug 26, 2011 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
My frigidaire affinity pauses during the cycle and won't drain
heatman101
Aug 13, 2011 | Washing Machines
My frigidaire affinity washer doesnt spin during the rinse cycle.
Hi javierc569,
Before the Spin Cycle should start, all water must be drained out of the machine. If it does not start, it could likely mean the Drain pump may be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Jul 26, 2011 | Frigidaire Affinity ATF7000E Front Load...
When doing a load of laundry the washer will stop at the rinse cycle and not drain or spin out the excess water
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Jan 03, 2011 | Frigidaire Affinity ATF6000F Front Load...
What will cause the drum not to spin during cycle? It spins freely by hand. Belt is in tact and motor shaft turns freely manually?
heatman101
Sep 15, 2010 | Frigidaire FCCW3000F Front Load Washer
My front load washer just stopped spinning. Every other cycle works!
heatman101
Sep 08, 2010 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity Glacier Stackable upright washer. Washer will not agitate and makes a buzzing sound from the pump that extracts water from the drum. Water collects and remains in bottom of washer.
heatman101
Aug 29, 2010 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
My frigidaire fron loader will not spin during wash cycle but will spin when placed on spin
If the drain pump is working correctly and you can get it to spin manually, then the board is faulty. Had the exact same problem with an Lg front loader 40 min. ago.(have to replace the board.)
Jun 14, 2010 | Frigidaire Affinity ATF7000E Front Load...
Won't do spin cycle
http://www.servicematters.com/maytag_library/docs/16022808.pdf
http://www.repairclinic.com/Washing-Machine-Repair-Help
http://frigidaireservicetips.com/pdfs/360_TumbleActionWashers.pdf
OK please find above a service and repair manual and a DIY washer self help site, with all this and the troubleshooting procedures in the manuals you should be able to isolate and repair.
May 21, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
4,723 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
