Question about Breville ESP8XL Espresso Machine
Plastic baffle came out of drip tray when moving.
How do i replace the plastic baffle thing that came out of the drip tray when i moved the machine? Breville cafe roma.
  • ladycass Oct 06, 2008
    Yes, but how? It doesn't stay put and the button thing on it doesn't fit under the hole it's supposed to. The baffle doesn't stay put long enough to put the drip tray back in place! And there's a sort of semi circular piece in the back that doesn't fit anywhere as far as I can see.
    Sue
  • 515 Answers
I think it should fit in the back of the driptray.
/Mirran
Posted on Oct 06, 2008
What's Wrong - Espresso going into Drip Tray
Sadly FIXYA has no idea what might be wrong with it
perhaps you need to confer with the manufacturer.
Jan 16, 2018 | DeLonghi Magnifica Coffee Makers &...
I left a screw in my jacket that got washed now the screw is lodged between the steel drum and plastic shell, you can hear it scraping when you spin the drum, how do i get to it and get it out
Try to remove one of the plastic baffles inside the spin basket. They are held in place by one phillips head screw. If you take that screw out you should be able to slide the baffle toward you and remove it. Sometimes, but not always, in manufacturing they move a little catch to keep the baffle from moving; in that case it will be hard to slide it. If you can get one baffle out, you will have a pretty good size opening to look for your screw.
May 20, 2011 | Kenmore 44102 Front Load Washer
My machine unable to complete program its saying check coin trap? where is the coin trap?
To find your coin trap:Loot at the front of the machine, and at the bottom-left is the coin trap.Put towels in front of the machine to mop up any water (it's going to get wet).It opens anti-clockwise (remember righty-tightie, leftie-loosey), but you need to move the little bit of yellow plastic (12-oclock position) up first. The machine dose come with a little tool to do this, but you may have lost it. You can move the bit of plastic up by carefully using a flat screwdriver, and turning the round plastic with your other hand. Don't force anything. After you remove it, just swim over to your machine and remove the yellow thing in the middle by pulling it gently towards you. Clean out the coins/paperclips/buttons that you find in there.Push back on the yellow bit into the coin tray, tighten back on the cover the coin tray (the yellow thing at the top will 'click' back).Using a mop, take the opportunity to clean the kitchen floor now that it is all wet.
Feb 26, 2011 | Dyson Memory CRO1 Front Load Washer
When I switch on an error is occuring : Dredgdraw
Hi
Dredge drawer is the big box on the bottom right. That is where the grounds are dumped. Remove the drip tray and pull the drawer out about half way. Push it back in with 1 finger on the right side of the drawer. That should clear the message. If it comes back on when you put in the drip tray, there is a section of the drip tray that can be removed to stop that. On the right side of the drip tray is a notch. Inside that notch is a thin piece of plastic. It curls up on the right side. Cut out the piece that curls up (just the piece that curls, about an inch). When you push in the drip tray that curl lifts the dredge drawer and knocks it out of position.
The white thing on the side is for the cappuccinatore. It slides on with a twist. The hose goes into your milk. You twist the little knob on the top when it is steaming until the milk goes up the tube and produces the foam. Once you get the foam going you won't have to move the knob again. Just keep everything clean.
Dec 29, 2009 | Saeco Royal Professional Espresso Machine
Baffle loose (Can see hole when moving baffle)
Hi there :)
The baffles are held in by 2 quarter inch screws per baffle. The only way to get to them is by taking off the top lid of the dryer.
Good luck.
Aug 05, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Alternatively slow brew and water under drip tray
when you remove the brew groupyou see a plastic piece with 2 seal on it at the bottom of that there like a funnel with little hole hole get block with old coffee clean that so extra pressure come out thereif its block its should be full of water in there and for our slow brewing did you change coffee brand defferent expresso bean diff setting dont forget if you move the setting 1 move it only when our grinding coffee 2 when you move the setting dont forget to make a least 2 or 3 cup before moving the setting again let me no pierre
Jan 09, 2009 | Saeco Vienna De Luxe Espresso Machine
Water hissing at back of brew unit after coffee made
I think you have to replace the steam valve.
Have you descale your machine regulary?
How old is your machine?
Maybe your boiler have to be replaced:-(
Jul 25, 2008 | Saeco Incanto Classic Espresso Machine
Drip Tray and Container for coffee stuck
the only thing would our drip tray is not properlt install and is jamming the rest try to move in and out the drip tray i am sure you already try it but it about the only thing that can hold the rest take our time dont force it good luck cheers
Jan 20, 2008 | Saeco Royal Exclusive 30153 Espresso...
Replacement drip tray and spatula
Customer service at 1-866-372-5866 should be able to help you!
Sep 05, 2007 | George Foreman GR15 Indoor Grill
Breville ESP8XL Espresso Machine Logo
300 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Tally Girl
Tally Girl
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
