Question about Whirlpool GR773LXSS - Stainless Steel Electric Kitchen Range
Whirlpool Gold Range Model#GR773LXSS (WD Sensor Open)
Getting a WD Sensor Open reading on screen? Please help.
  • cncguru7777 Oct 05, 2008
    Thank You.
    Are you sure it isn't the one in the warming drawer? Reminder that it said "WD Sensor Open"
    Wouldn't the wd stand for warming drawer?
    Where can I find a part for the cheapest price?
    Do you know how old my unit is?
    Problem Solver:
@DocJohn - but if it says "WD Sensor Open," isn't it possible that the Door and latch switches do not agree (i.e. door open latch closed) and that maybe just checking the alignment might be the first place to start? Just thinking out loud.
Posted on Apr 09, 2010
  • 943 Answers
Hi thanks for the question. the sensor at fault is located in oven top left looks like a pen , replace the sensor thanks the appliance doc
Posted on Oct 05, 2008
  • cncguru7777 Feb 19, 2013
    Replaced. Same problem. It was $112. Ouch... Anything else?
Whirlpool oven isnt getting warm/hot
Hello & Welcome to FixYa
This indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Feb 03, 2011 | Whirlpool SF378LEPS Stainless Steel Gas...
Model # wfg114svqo gas range getting error code F-2. Oven boes will not maintain tempeture. Is there a part I can replace?
Hi
Thanks for using FixYa. Error F2 in your range/oven indicates oven temperature sensor circuit failure. To resolve this issue you'll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks Rylee
Oct 25, 2010 | Whirlpool Kitchen Ranges
Hi, I am getting an error reading on my whirpool gold stove it reads EO -F2- do you have any clues to what my be my problem. Thank you in advance for your suggestion
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Sep 20, 2009 | Whirlpool GR773LXSS - Stainless Steel...
Hi; We have a Whirlpool Gold range and stove - roughly two years old. The stove works but the oven and all functions ie clock set, timer do not work at all, not even a beep or anything appears on the creen...
Try holding down the off button for 5 seconds and if this does not work the start button for 5 seconds. Unplug for 5 minutes first. Then try holding the button and then set the clock.
Aug 25, 2009 | Whirlpool GR773LXSS - Stainless Steel...
What does E4 - F3 - mean on display on range
It means something may be wrong with the oven sensor. The Whirlpool technical manual says:
Check for open circuit. Sensor resistance should be 1K to 1.1K @ room temperature. If not, replace the sensor.
If you need help on how to do that, let me know.
Aug 23, 2009 | Whirlpool Gold GW399LXU Gas Range
Whirlpool Gold electric range control panel not working
I live in a new 500 home subdivision. The contractor ordered all Whirlpool Gold products including Electric and Electric/Gas Ranges. Many of my neighbors' panels have gone out! I'm talking about epedemic trouble. My son has had his oven panel (separate from stovetop) fail within the first year. Thank God it was under warranty...this is not a cheap replacement (he had the sensor touch pad. I just had my oven pad fail. I tried to set the clock for Daylight Savings and found out half my panel is out! The fix is a replacement of the panel. Depending on which model (push or sensor) look to spend at least a couple of hundred bucks. We have the Whirlpool Gold microwave panel and so far so good. My neighbor and my son's both went out! They just tossed the two year old products and replaced them with another brand. Sorry to break you the news...class action anyone?
Mar 04, 2009 | Whirlpool GY396 Electric Kitchen Range
I have Whirlpool error codes E-1 and F-5; My range door is locked. Please help.
Here are 3 Service manuals for your oven.
The E1 F5 is a door latch error.
SEE MORE ABOUT THE PROBLEM HERE
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused. You should disconnect power again for 15 seconds and reconnect and see if that helps. If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display. This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control. Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Mar 02, 2009 | Whirlpool GR773LXSS - Stainless Steel...
E1 F5 displays cannot use the oven whirlpool gold range When I triy to bake it doesnt let me it beeps twice an didsplay E1 F5, I pushed all cancel button on the range to no avail
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!
Feb 25, 2009 | Whirlpool GR773LXSS - Stainless Steel...
Whirlpool Gold Range Error code EO F2
On this website: http://www.repairclinic.com/0078.asp#Whirlpool , it shows all of the codes for the Whirlpool errors. Based on the remarks, if it shows a "4 digit failure code" it is "Shorted keypad"
"Replace Electronic Range Control/Clock (ERC)"
But verify this as I am not an appliance repair specialist. I am a computer nerd who just knows how to find information. I am actually trying to figure out an answer to my own problem with my Whirlpool Gold Accubake.
Dec 11, 2008 | Whirlpool GR773LXSS - Stainless Steel...
Whirlpool gold stove (wd sensor open)
on my stove i pushed the lock button for my oven now it want unlock. it is like it is froze up, it want let me cook or anything
Oct 04, 2008 | Whirlpool GY396 Electric Kitchen Range
Whirlpool GR773LXSS - Stainless Steel Electric Kitchen Range Logo
201 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
