Question about Acer (90.18612.36B) Computer Speakers
Acer Computer Speakers- no sound!
When I go through the control panel and test them, they are working fine. The LED light is on. When I actually try and play a song, say on Youtube, then no sound comes out of them. It is an Acer PC and Acer speakers.
  • 5 more comments
  • birdb Oct 04, 2008
    Nooooooo!!!!!! It's still not working......
    8:.(....
  • vradford293 Feb 28, 2009
    suddenly no sound from my computer for u-tube or even the sound of starting up. sound was fine one day and gone the next. Was it something I may have done???
  • Anonymous Mar 03, 2009
    they dont work
  • Anonymous Mar 07, 2009
    my speakers are plugged in and it says my speakers are on but when i go to play a song it doesn't work.
  • Anonymous Apr 05, 2009
    no sound on acer speaker. no sound on Youtube. test is fine in the acer emanagement
  • budonwally Apr 23, 2009
    speakers are hooked up but no sound
  • Anonymous Apr 28, 2009
    No Sound From Speakers
    Champion:
  • 200 Answers
Did you try to play a song in your computer instead of opening a video on youtube because some videos in youtube are not working properly or maybe there is an issue with flash player
Posted on Oct 04, 2008
I have an acer aspire z3101-e3812 i see the speakers working but there is no sound coming out of my pc...plz help,,because it is new and its not working...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Apr 19, 2011 | Acer (54.AA806.001) Sound Card
The headphone and external speakers don't work on my acer but the internal speakers are fine
check if you plugged them in the proper port the green one is proper for speaker.
Mar 31, 2011 | Acer Aspire One A150-1006 Notebook
Speakers dont work, led controls dont light up, diagnostic test does not work. My connections are correct and my drivers are updated. What is wrong?
you might have to uninstall then reinstall either the driver or the sound devices
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers or right click select properties to either troubleshoot,uninstall,rollback driver
hope this helps
Nov 28, 2010 | Altec Lansing ADA 885 Computer Speakers
No sound from speakers on acer 6706 desktop
First check you dont have a red line through your speaker on your toolbar. If so click it and "UN-mute it.
Check that the speakers are plugged into the GREEN port on the back of the computer and that the speakers are powered up with the volume at about 1/2 way.
Open volume control.
When the box with all the sliders opens up click on OPTIONS (top left)
Click PROERTIES
Make sure that Volume controls, Wave, SW Synth, CD PLayer, Line IN, and MIC all show on there and that the volume sliders are about half way up.
Make sure noe of the sliders have ticks at the bottom, if so UNTICK them.
If any of those are missing click options then properties from the top left and put a tick besides any that were missing (nothing else unles you know you want that item)
Now close the slider box.
Put a normal music cd in your cd/dvd player on the computer and set it to play with windows media player.
You should now have sound out of the speakers.
If not double check that you have no problems with your hardware from the device manager.
Sep 07, 2009 | Acer Veriton 5600G PC Desktop
Acer Speakers not functioning
if you do have a reinstall disk you might want to disconnect the speakers ,run the install disk follow the instructions .This might take care of it.
Good luck
Aug 29, 2009 | Acer (90.18612.36B) Computer Speakers
Acer speaker type no.: 9m-20a200-000
Check your sound settings. Go to control panel -sounds- volume-advanced tab
make sure you wav file volume is up and not muted. That should get you working.
Aug 06, 2009 | Acer (90.18612.36B) Computer Speakers
Try Updating Flashplayer from get.adobe.com/flashplayer
May 03, 2009 | Computers & Internet
Acer speakers- no sound!!!!!
Check the socket of your speaker to the computer if they are on the right socket.
Re-install the sound driver of your computer if you dont see an speaker icon at your task bar usually found at the right side of the task bar.
Oct 04, 2008 | Acer (90.18612.36B) Computer Speakers
Acer speakers no sound
Hello!
You should tell the model of your acer or the sound card on it so that i can serach it for you. However you can search it by your own by simply going to the acer website and then search the model of your laptop and the go to the support and downloads.
http://www.acer.com.ph/ or selet your location and search your model.
may this help. melnavz
Mar 14, 2008 | Acer (90.18612.36B) Computer Speakers
Only one of my speakers work
Dognayr15
Happy Holidays
well, if you put the green cable on the green connector on your sound card, you,ll be fine, and see if work, fine, depending on your configuration speakers, 5.1 or 2 way, you can test if the sound go on the 2 speakers.you also check if something is bad with the other speakers
Dec 26, 2007 | Acer 90.00012.30B Computer Speakers
516 people viewed this question
Top Acer Audio Players & Recorders Experts
NOEL
NOEL
Are you an Acer Audio Player and Recorder Expert? Answer questions, earn points and help others
