Question about Maytag Washing Machines
Can I wash rubber backed kitchen carpet in my Epic frontloader machine?
  • 943 Answers
No .you cant. the backing will come off, and clog the pump. no please don't. thanks the appliance doc
Posted on Oct 05, 2008
Water leaking from the panel under the turn knob
Water comes in the back, then goes via to solenoid valves to the back of the powder tray, it then is distributed through holes above each compartment, take out the powder tray (push down the blue bit at the back of the softener compartment) and check for cracks or even blockages, (water goes from tray down the back and through a short rubber hose straight into the drum.
Feb 11, 2014 | Russell Hobbs RH1042 Frontload Washing...
Maytag epic frontload washing machine won't drain
You did not post the model number but this does not look like a cheap or easy repair. Could be the main board.
Oct 30, 2017 | Maytag Washing Machines
MY LG FRONTLOAD WASHING MACHINE WAS OUT OF BALANCE AND DANCING ALL OVER THE FLOOR NOW THE RUBBER SKIRT AROUND THE DOOR IS DEFORMED AND TWISTED. HELP!!!
The washer tub spring has popped off it's mounting. You will need to remove the top panel and reconnect the support spring back on to the metal frame.
Jun 26, 2011 | Washing Machines
After washing my machine smells like stagnant water
Hi
First check to make sure that the machine is draining properly and that the pump filter is clear of any debris.
If the machine is a frontloader a common place for mold to build up is the rubber seal around the door. Clean this out as well as you can with ordinary kitchen cleaner then place a heaped cup of baking soda directly into the drum and run an empty hot/boil wash on a full cycle.
Baking soda has a cleaning and neutralising effect and will help remove any build up of mold or gunge within the machine. You may need to run two of these washes before you see a solid result.
Thereafter I recommend you run a monthly 'maintenance wash' with the baking soda to prevent the problem arising again.
Hope this helps. Thanks for using FixYa.
Sep 26, 2009 | Whirlpool Washing Machines
Maytag epic frontload dryer won't unlock
Hello, unplug the washer remove the lower front access panel, get to the switch and pull downward on the circullar shaped release tab. Now drain the machine manually, take the filter out of the pump and clean out. reassemble and test. good luck
Dec 09, 2008 | Maytag EPIC MFW9700S Front Load Washer
The ''control locked light is on'' how do i reset it
there is a button on the control panel, marked "control lock" hold for 3 secs to unlock, look closely its there
Nov 25, 2008 | Maytag EPIC MFW9700S Front Load Washer
Maytag Epic Z frontloader Error Code F20 Help Please!!!
i also have a magtag epic z &f 24 error code is on my washer. i don't know what to do.
Jul 01, 2008 | Maytag Washing Machines
Washing Machines Logo
22 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
