Question about Bosch Nexxt WTMC3321US Electric Dryer
Bosch Nexxt electric dryer clicks twice but won't run
All the LEDs light up, you hear a faint click followed a second later by a louder click but the drum doesn't turn and nothing seems to heat up.
  • dwils4230 Dec 27, 2008
    Same problem. Lint filter light is on, but all cleaned. Isn't there a reset button?
  • Anonymous Jan 23, 2009
    same problem if anyone has the fix please email to me at mrichard4u@aol.com thanks
SOURCE: Squeaks from drum area during operation
I have the same high pitch squeal from drum are after dryer gets heated up. Anyone find what the problem was? Service call help??
Posted on Apr 06, 2008
Richie_asg1
  • 1036 Answers
Hi there!
I think it is the drum main bearing that has started to sieze.
If it is not this, then the drive belt may need replacement.
If this leads to a solution, please take a moment to accept. Thank you.
Posted on Jun 18, 2008
SOURCE: My Bosch nexxt electric dryer won't turn on
Belt broke or came off. Replace or reset belt. Be sure to reset the switch that the tension arm activates when tension is lost.
Posted on May 26, 2009
heatman101
  • 43501 Answers
SOURCE: Ticking getting worse!
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
edgfd
Posted on Sep 29, 2010
SOURCE: my bosch nexxt 500 series electric dryer is not
We had the same problem. Cleaned out lint filter and still no heat. We took off the back (lots of screws and had to take top off to get back off). If you are looking at back - at the bottom left there was a red reset button and it clicked when we pressed it (when we pressed it again there was no click). Worked fine after. This solution came from internet. My brother-in-law changed setting to "extra dry"- we usually just used 20/40/60 setting. I think it overheated.
Posted on Oct 04, 2010
Bosch Nexxt WTMC 6300 Electric Dryer won't start/ no light, No power
check and see if the outlit it is plugged in to works with somthing simple like a light somthing may have triped the breaker in your house
Jun 05, 2012 | Bosch Nexxt WTMC 6300 Electric Dryer
Bosch nexxt 800 series wtmc8520uc not working
How do you get to the motor mount? Where is it located?
Jan 22, 2012 | Bosch Nexxt WTMC8320US Electric Dryer
I have a Bosch 500 plus model. I was drying a blanket by itself when the dryer just shut off. The blanket was in a ball. I spread it out and turned the dryer back on and it wouldn't start. No error codes...
The motor tripped..The wiring diagram for the dryer is inside the back cover tie-wrapped to the frame as it sounds like the motor has a trip on it:
To reset the switch unplug the dryer, remove the power cable and back cover completely. two screws holding back cover are under the top cover which is held on with two screws at the rear. Remove the screws then pull top cover back and then lift it off. Remove last two screws and take off the full back cover . On the front of the motor you should see two white wires going into the safety switch for the belt breaking. Push the button on the left to reset the switch (you probably will hear a click) Do not push the right button as that is what got tripped originally . Good Luck Tim
Oct 30, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
My dryer heatsp but the drum wont spin.
If you are getting heat but the drum won't turn then the problem is usually with the motor or the belt. If the motor is running but the belt is off or broken then you should hear a faint hum of the motor running and the motor coasting to a stop when you shut it down...
If the belt is off and not broken then check the guides and wheels to make sure that one of them has not come out of alignment or broken throwing the belt off...
Also check out this tip...
DryerRepair - The Dryer is not Turning
heatman101
Sep 15, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
heatman101
edgfd
Sep 30, 2009 | Bosch Nexxt 500 Dryer
Bosch Nexxt Electric dryer tumbling but not heating up at all, I here rumors of a reset switch. Where is it located?
Unplug the dryer first. Then remove the back cover on the dryer. You will find the red reset button underneath the dryer drum. If the button has been tripped, you will feel and hear it click when you press it in. I would suggest that you vacuum out any dust or lint that has collected inside the unit before replacing the cover.
Feb 28, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
Nov 04, 2008 | Bosch Nexxt WTMC3321US Electric Dryer
Brand new Dryer with loud noise and hot
contact bosch for factory service on the unit
May 10, 2008 | Bosch Nexxt WTMC 6300 Electric Dryer
Bosch Nexxt WTMC3321US Electric Dryer Logo
275 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
