Question about Ecoquest Flair Air Purifier
Flair motor the unit will not come on at all any more
  • 368 Answers
Hi vonniekay,
Absent any more details about your situation, this will get you started.
1. Make sure the safety cut-out switch on the lint screen in the back is properly engaged by the plastic plug on the screen. If this is out-of-position, nothing works (nor should it). This may fix the problem.
2. Check the fuse; if blown again, you have a short someplace that the fuse is protecting you from. Look for loose connections, or damaged components. Also make sure that nothing got left in the machine (eg. thread from cleaning rags), or any wires didn't get properly re-connected when you cleaned it.
If this doesn't fix it, write back with more details - - will the fan run, but not the O3 plates, or vice versa - - I'll need more infomation at that point.
If/when this solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Posted on Jan 14, 2009
I have a Flair air puifier but no ozone smell. I replaced the high voltage transformer( it was a 3500 watt instead of a 5000 watt transformer) The red light now flickers but no ozone smell . It has ne
Your ozone generator may have gone bad. It's the small black rectangular looking apparatus located near the bottom of the unit. It usually has a zip tie holding it to the circuit board. You will have to take the Flair out of it's case to see it. Make sure it's unplugged and remove the bolt from the bottom of the unit. You can then slide the framework out of the casing. It's also possible that it's time to replace your Ceramic Ozone Plates. They have a life expectancy of 2 to 4 years. The Flair has two of them that slide into slots in the rear of the unit. You can see them when you remove the washable filter. All items can be purchased on Ebay. DM
Apr 28, 2012 | Ecoquest Flair Air Purifier
Flair living air purificaion system
here are parts for your air purifier, including the motor and other parts you may need in the future.
AirPurifierRepair.
- just click the link
hope that helps, good luck
Jul 31, 2008 | Ecoquest Flair Air Purifier
How do you clean motor on Flair? Fan will not turn
The motor shouldn't need cleaning that would prevent it from turning on. When was the last time you cleaned the machine?
Jul 26, 2011 | Ecoquest Flair Air Purifier
Can feel motor run, but fan doesn't turn and very little ozone smell-have new plate
same deal with mine. Im gonna open er up n give a look c. Im thinkin the fan motor is running but not enough 2 turn the blades. Im fixin 2 google fan motors now as a matter of fact.
Jun 09, 2010 | Ecoquest Flair Air Purifier
How do we clean the fan on our Flair?
take the grill of and get a soft cloth and lubricate the center of the motor
Mar 17, 2010 | Ecoquest Flair Air Purifier
Flair sparking
Contact healthytech@triad.rr.com. They will be glad to help you.
Apr 09, 2009 | Ecoquest Flair Air Purifier
My Flair Ari purifier makes much more noise
Sounds like Motor or bearing is failing.
You could order parts but you will find it less expensive to replace unit. Than trying to repair.
Please rate. Hope this helped. If i can help you further let me know. Good luck!
Mar 09, 2009 | Ecoquest Flair Air Purifier
Only one plate inside, it's glass edges are broken or deteriorate
I haven't seen an older Flair that I know of. There will be as many slots for plates as are required. The filter is definitely washable. Use an enzyme cleaner and rinse with hot water. The fan motor should be oiled every month or two. It should cost less than $100 to get it running in top shape.
Feb 08, 2009 | Ecoquest Flair Air Purifier
Fan trouble with Flair
remove the retaining screw from the bottom of the unit and slide the insides out the back. use WD40 with the plastic extension tube, spray into the motor armature/stator and turn with your hand until it is free spinning then reassemble and turn on.
this is an ongoing problem with my unit because the air and all contaminents are pulled directly to the fan.
Apr 04, 2008 | Ecoquest Flair Air Purifier
My Fan on My Flair purifier is not turning when I turn on the unit. Nervous about poking around in there don't want to break it, any ideas how to fix this? Thanks
To fix it..........there is one screw on the unit on the outside.........really long!.......remove that and the entire unit just slides out of the housing..........
The replacement fan motor can be purchased on ebay....ranging from $21.95 to $32.95...depending on the model Flair that you have...the most common one is the $29.95 replacement...
Really quite simple to remove and replace!!! and well worth it!
Hope this helps.
Feb 02, 2008 | Ecoquest Flair Air Purifier
Ecoquest Flair Air Purifier Logo
76 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Michael Youngman
Michael Youngman
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
