Question about Apple 15" PowerBook G4 Aluminum 1.67 GHz LCD Display (p/n 1002587) (661-3749 1002587) Mac Notebook
LCD Problems thanks for responding to my question. I have replaced the lcd since the time it was posted. i ran into another problem though. now it turns on but nothing happens. the screen worked one time but it would not boot. then i shut it down by pressing the power button. after that, i started the computer again. i got the mac start up sound but no picture. then after a while. the fan started blowing like crazy. i don't know what to do next.
    Novelist:
  • 137 Answers
This doesn't sound good, but there are a few things to do. First, if you replaced the screen yourself and feel comfortable opening up the case again, do so and check the connections. There might be something lose that's making the problem. I'm guessing not though. It sounds more like a logic board problem. You can try a few options though.
[]Reset the PRAM
[]Leave the battery out and the unit unplugged for a day and press the power button about 10 times to discharge the laptop. (sometimes does something to settings)
[]Hook it up to an external monitor to see if you have an image. This will tell you whether it's an internal thing or not. If you don't get an image on an external monitor, you probably have a bad logic board. Sorry I can't help more.
Posted on Oct 05, 2008
Dell Inspiron MINI 1012 Laptop Screen 10.1 LED flickers
soldbyajt,
It sounds as though the video card has gone bad in your system. There are a couple of things to try to eliminate the lcd.
If the LCD on the system shows no display or has other problems, here are some basic steps to take:
  1. If the LCD is not displaying any video, connect an external monitor to eliminate a no-POST problem. A good image on the external monitor eliminates a video card problem or a POST problem.
  2. Connect an external monitor when possible for all LCD-related problems to help eliminate a possible software or video card problem.
  3. If the LCD has lines on the screen, check the system during POST as well as system setup to determine if the lines are present in all modes of operation.
    If you cannot get any video by connecting an external monitor then your motherboard will need to be replaced. The reason for the motherboard replacement is because your video card is soldered onto the motherboard.
    Thank You,
    Dell-Jesse L
    Dell Social Media and Communities
Jan 11, 2013 | Dell Inspiron Mini 1012 Netbook
Ferrari 1000 LCD failer
Hi, Your post "Would a failed Inverter on an Acer Ferrari 1000 cause the system to not recognize the installed LCD?" No,the inverter only provides the high freq high volt for the backlight. Monitor/LCD recognition is part of your video/display controller. Pls check your video drivers (ATI Radeon Xpress 1150). Also your Default Monitor Properties. Hope this gives you some idea, Good luck and pls post again how things turn up. Kind regards.
Aug 10, 2007 | Acer Ferrari 1000-5123 Laptop
3110c no display
hi there!
hope you can give us more details on what happened before this problem started. but if you dropped the phone, try pressing the lcd screen's left and ride side, top and bottom too, see if the lcd screen responds. if not, it may need replacement. if it does respond, you still need to bring it to a techinician for they need to open it up and check if the lcd ribbon was disconnected or if it indeed need replacement. post back if you have more info for us to resolve the issue!
Apr 13, 2011 | Nokia 3110 Cellular Phone
The source button is not responding even though the power shows each time i press but no response.
There are two possible causes. 1. The Function Buttons on the TV are shorted thus not allowing commands to be sent to the Main bd. Replaced the Function Button PCB.
2. The Main bd is bad.
Apr 15, 2010 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Blank LCD screen on Compaq n800c laptop
First instinct would tell me that your LCD has gone bad. A refurbished replacement LCD should run around $300-$325 give or take.
Keep us posted, good luck
God Bless
-Carlos:
Jul 09, 2009 | Compaq Evo N800c Notebook
Sony TV no longer responds to Harmony remote
try using some rechargeable batteries. they tend to have more miliamps and last longer.
Jan 14, 2009 | Logitech Harmony 670 LCD Remote Control
K850i PROBLEM (POST SOLUTIONS PLS!!)
erwin - take the phone and have the firmware reflash on the phone and if that does not work then have the lcd replaced in the phone.
guest - replaced the phne lcd
darkside_ody - changed the lcd or the mainboard on the phone
Sep 14, 2008 | Sony Ericsson K850i Mobile Phone
Rear Colour LCD Screen Problems
if you intrested to sell the camera tell me how much u want otherwise lcd is available see www.omaxphoto.com.it mifht be something wrong with display back portion it has to be cheaked by an expert
Aug 22, 2008 | Nikon D70 Digital Camera with 18-70mm Lens
Sony DSC-W70 LCD Problem
You will need to describe what you see on the LCD in more detail in order for me to tell you what the problem is. There are two different issues that can cause things like what you are seeing. 1: Cracked LCD. You will see lines which resemble cracked glass. You will see bright vivid colors with specks of black or stark white all over. The image problems may be only in one portion of the screen. The LCD is made of glass, so if you look closely and see patterns that look like broken glass - this is your issue. Replace the LCD. 2: Bad LCD connection. You will see distorted colors, the screen may blank out and flicker when you shake the camera or press on the housing near the screen. If neither of these describe what you are seeing, post back and give more details and I will respond further. David Millier Advance Camera Repair
Feb 21, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Sony DSC W70 Problem
Feb 21, 2007 | Sony Cyber-Shot DSC-P92 Digital Camera
Apple 15" PowerBook G4 Aluminum 1.67 GHz LCD Display (p/n 1002587) (661-3749 1002587) Mac Notebook Logo
75 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
