Question about Toshiba Satellite A65-S1065 Notebook
Touch pad failed.
Touch pad worked fine. closed down laptop and restarted later. No function of touch pad. No cursor appears. buttons don't produce any response. would appreciate any solutions. Thanks in advance.
  • Janet Nery
    Janet Nery May 11, 2010
    Do you still see your desktop screen? icons?
  • Anonymous Mar 28, 2014
    The touch pad is NOT working. Cannot use cursor.
  • 46 Answers
Look along the top of the keyboard for an "f key" that shows a "touch pad" icon, IF you see it, press the "function key" (along the bottom of the keyboard) PLUS at the same time the "f key" (that you found along the top) and that should "toggle" the touch pad back on....
Also, IF you plug in a USB mouse that will allow you to move the cursor around--but the USB mouse doesn't fix your touch pad problem.
Hope this helps.
Posted on Jan 31, 2009
Acer aspire 5735 touchpad not working properly doesn't zoom
You can try updating the software for the touch pad but the most likely problem is you have a bad touch pad. Touch pads don't necessarily go all at once. You lose some functionality. In your case, it would appear you are able to to point and move the cursor. You didn't mention, does the touchpad respond when you tap it to hit ENTER instead of hitting the ENTER key itself. This is 1 area that will commonly lose function over time as well.
Nov 10, 2011 | Acer Aspire 5735 Notebook
My Acer 5810T laptop touch pad click function is not working, however the cursor/mouse movement via the touch pad is working well
In the bottom left of your screen by the clock there should be an icon that says touch pad device, synaptics touch, or something along those lines. If you click on this it will give you different options for the touch pad and one of them is tap to click, make sure this is turned on.
Mar 11, 2011 | Computers & Internet
I have an hp g60-535dx. my touch pad has been working 100% up until today when it just stopped working. i can turn it on and off but clicking right or left buttons doesnt work nor can i move the cursor...
HI
I would go to device manager
scroll down to find the touch pad
uninstall it
then restart laptop
hopefully when you restart windows will find new hardware
and reinstall the touch pad correctly
good luck
if not go to website and download another driver for it
www.hp.com
Feb 23, 2011 | Computers & Internet
When get to my home screen my cursor wont move when I move my finger on the mouse pad.
I'm assuming that you are using a laptop. If so, then look around for a button that locks out your touch pad from being recognized. Some laptops have the Touch pad "On\Off" button just above the touch pad. Other laptops will require you to do a key-combination to turn the touch pad On or Off. To do this typically requires you to press the FN or Function key while pressing one of the keys between F1 - F12. There should be a symbol\icon of a different color on whichever key it is that will give you an idea of what that key's function is. Every laptop is setup and arrange slightly different.
Aug 17, 2010 | Computers & Internet
The touchpad (and buttons) stopped working. No response at all. External mouse works fine, so it is not a software issue. Could this be a loose connection? or do these fail after a while? Are the...
Is there a button with a light on it near your touch pad, sometimes these buttons don't have lights? Usually this button is centered on the bottom or top of the touch pad. If there is a button like this, then try pressing it to see if it gives you functionality of the touch pad. If you do have a button like this and it doesn't resolve the problem then there is a possibility that the touch pad has malfunctioned or that the connector has come loose somehow. If you don't have this type of button then look at your keyboard to see if there is a function key for turning off\on the touch pad. Look for the FN key. What color is it? Then look at the keys that have icons in that color. If you find one that you believe is for the keyboard then try pressing that key and the FN key at the same time.
Jun 25, 2010 | Toshiba Satellite M55-S325 Notebook
TOUCH PAD ISN'T WORKING, CURSOR WON'T MOVE
your touchpad might have a 'lock' button nearby it, to enable or disable its sensitivity. this is usually helpful while typing, so you can disable it so that the when the touchpad gets touched, the mouse won't make any reaction. You can then enable it to work with the mouse. This button is usually either near the top border or near one of the four borders. Alternately, some laptops have a function key for touchpad enable-diable thing. It is usually Fn + F3. The function key (Fn) is near the Ctrl key. The touchpad key, in the in colour of the Fn key will be somewhere in the Function keys.
May 02, 2010 | Toshiba Satellite A100-S8111TD Notebook
My laptop computer is okey except that the touch command for the cursor is not responding, if i use a mouse thru the usb port then its alright..why does the touch command for the cursor not responding?
Touch pads are not very reliable. I have seen a lot fail.
A computer repair person will need to replace it for you.
My advice is to stick with a USB mouse. Or if it is under warranty, take advantage of that warranty.
Best of luck.
Apr 26, 2009 | Acer Computers & Internet
My dell mini's touchpad has locked up. I can't move the cursor
Whenever that happens to me I just restart my laptop and everything returns to normal...
Jan 17, 2009 | Computers & Internet
Cursor Shift
This could be either a driver glitch or the touch pad is going out, both are common on these models. Start by uninstalling the drivers for the touch pad (some times referred to as the synaptic pointing device), then restart the machine. The machine will find the touch pad and reinstall the drivers automatically. If it's a simple glitch, this will fix it. If it persists, then the pad is failing and will need replaced. The only other thing you might try is to adjust the cursor speed or touch pad sensitivity from the control panel. This will sometimes help to dampen the effect, but usually won't get rid of it entirely.
Sep 04, 2008 | Dell Latitude C610 Notebook
Toshiba Satellite A65-S1065 Notebook Logo
743 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
