Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
When add the plug for hdmi can't enable on menu
Read above
    Scholar:
  • 93 Answers
??Do you know you want to activate the TV menu?If so,you need to use RG-6(coaxial cable) to connect from your VCR or cable box to the tv.
solutiondoct
Posted on Nov 06, 2008
Asus laptop doesn't read the hdmi port
The hdmi port is an output to the high definition video, and the laptop does not read from it. If you mean the output from the laptop does not appear on the HDMI monitor that is plugged into the HDMI port, then go to the monitor and check the input selection menu on the screen. The VGA or composite input may be the default.
Jan 10, 2016 | ASUS Computers & Internet
Setup DVD&VR375
Check this link
http://in.youtube.com/watch?v=C-i26YB6ttE
Sep 01, 2008 | Samsung Televison & Video
Hdmi cable closed caption
Are you using the cable box settings (or remote) or your TV's remote to select the closed captions. When you use the HDMI cable, you need to enable the captioning on the set top box. The TV can only interpret the CC if the signal goes through the tuner (coaxial cable input). It's a matter of how they built the hardware; the cc interpreter is part of the tuner.
Which cable provider do you have? I know with some providers, there isn't a direct CC button on the remote. With them you need to go through the Settings menu to enable the closed captions. If you add a comment with your provider, I may be able to help you enable the CC if there isn't a CC button on the cable remote.
I hope this helps.
Dec 11, 2013 | Emerson Televison & Video
No picture or sound when I plugged in HDMI cables to back of PDP-R04E media receiver
Hi there
I do not know what SKY is,but if it is a kind of a transformer that is connected to the router. I have that because of the ADSL.
I discovered that this transformer has to be "new" in order to plug the HDMI cable in the transformer and the HDMI socket. I hope my English is understandable because this HDMI and scarts are a bitcomplecated to explain but simple inpractice.
all the best
Kolbrun
Feb 29, 2012 | Audio Players & Recorders
How to enable. Javascript in my (browser)
If you have the java script add on downloaded for the browser go to the menu in the upper right corner
click tools then options then add on scroll down to java add on and click enable if all you see is disable then it is already enabled. If you don't have the add on you can go to your browsers addon download page search for it and download it or go to java.com and downlaod java and install it it should enable it then if not try the above after installing java.
Nov 21, 2011 | HP Cameras
I cannot get sound when using an HDMI with my Panasonic Viera TC-L32X2 LCD. I have tried three different HDMI cables, I'm highly confident that is not the problem. My cable provider had to override...
Is this TV new or new to you? I suggest you check two parts of the Audio > Advanced Audio menu. First check if the TV speakers are set to on. Next check the HDMI audio setting. This should be set to Digital. (There is an analog option that works with DVI to HDMI cables and older HDMI cables that aren't fully HDMI compliant. For these situations, you connect an audio cable between the cable box and TV. I believe your audio cable needs to have a 3.5 MM (M) end at the TV and plugs in at the computer audio input.)
Since your cable provider turned off the HDCP (high definition copy protection), it's possible that the cable box is treating the cable as being incapable of carrying the audio. Try using the Analog audio option, described above. You may want to check if your cables are fully-compliant with the HDMI specification (and HDCP). Then get the HDCP enabled in the cable box. Similarly, check the audio output settings for the cable box. (If you can access the Settings for the cable box without a service call, you should look at the Audio and Display settings. My cable box has Display options for HDMI versus DVI cables, as well as a choice for Digital Audio for the HDMI option in the Display sub-menu.)
I hope these ideas help. If you need more information, add a comment with the settings for your Audio and Display settings. The manual is available on the TC-L32X2 support page, http://shop.panasonic.com/support-only/TC-L32X2.html . The direct link to the manual is currently ftp://ftp.panasonic.com/television/om/tc-l32x2_en_om.pdf . See page 28 for the Audio menu options. Since you tried three cables, I think the odds of all three being bad is slim.
Nov 01, 2017 | Panasonic TCL32X2 32 in. HD-Ready LCD TV
I need some answers. We have a Vizio TV, and we plugged in our DVD play to HDMI-2. When we put the TV on and then the DVD player on we get no picture.
Hello,some dvd players require that you go into there menu and turn on (enable ) the hdmi jack.I suggest you first hook the dvd player up with its yellow video cable to video 1 in on the tv and then search the dvd menu for its setup options.
Jan 12, 2011 | Audio Players & Recorders
I have only the cable and hdmi hook into my panasonic 42 plasma and i dont get anything that is hdmi is there other cables i need?
Using your input key on the remote should switch you to the other modes. If you cannot access any HDMI or other input labels, go to your menu, and into the Input Labeling menu (under settings) and make sure you have all the inputs you require enabled. Its possible you (or an out of the box error) put these other inputs offline, which is why you aren't able to access your media from HDMI. If all inputs are enabled, and labeled, double check all the HDMI inputs on the unit. Plug what you are using with HDMI into each port, having the power on and sending information to the television. In some rare cases, I've seen that it doesn't allow access to the HDMI without it providing some source information.
Hope that helps.
Apr 09, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
88 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
