Question about Kenmore Elite 45986 Front Load Washer
Please help! I get a "sud" and then it flashes "F" then "02" and it doesnt drain. I press pause/cancel two times and nothing, it appears to be jammed and is not draining the water out even after I removed all the clothes. I have restarted without clothes and it will go until the drain/spin cycle and pause with a humming sound. Help!
  • normanamuche Oct 05, 2008
    Thank you for sharing your knowledge, it saved me potentially hundreds of dollars. It was exactly that, the pump had three socks bundled together and lots of water coming out, luckily I was prepared for it.
    This website and your knowledge is awesome.
    -norma
    Genius:
  • 1,028 Answers
Remove bottom panel remove as much water as possible from tub ..have lots of towels handy remove clean out port on pump clean and reinstall...also ck as far into pump for something jammed in impeller ..pump may need to be removed to clean if unable to clear jam ..3 screws hold pump motor to pump body remove if necessary also ck to see if pump impeller is spinning freely on motor shaft should be some resistance when turning if impeller spins freely replace pump
Posted on Oct 05, 2008
F 02 flashing on control panel
F/02..
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Oct 21, 2012 | Kenmore HE3T Washer
The washer is flashing F2. It will not go thru an entire wash cycle without having to be paused and then restarted at what ever time is left in the cycle.
do this...
"F/02" Long Drain
Feb 08, 2011 | Whirlpool GHW9150 Front Load Washer
Washer is flashing a signal of 02 F and beeping
F02:
Long Drain
Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later
the F/02 error code will be displayed.
Potential Causes • Check the drain hose and make sure it is not plugged or kinked • Check the electrical connections at the pump and make sure the pump is
running. • Check the drain pump filter for foreign objects • If the above does not correct the problem replace the pump
Feb 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My maytag clothes washer Bravo quiet series 300, keeps flashing a Sd error code. Or it may be 5d
What does the Sd code mean?
This code indicates that excessive detergent suds occurred during the cycle. The washer will not be able to spin out water with the excess suds. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the wash action and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This process is necessary and may occur several times to eliminate the suds.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
Use only HE High Efficiency detergent for BravosTM washers.
Is "Sd" displayed and the wash cycle dial is flashing?
This indicates the washer was not able to clear all the excess suds from the washer. Re-select your desired cycle using cold water. Press Start/Pause. Do not add detergent.
Is "Sd" displayed and the wash cycle dial is not flashing?
If "Sd" is displayed and the wash cycle dial is not flashing, allow the machine to continue running, even if it appears that nothing is happening. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the wash action will pause to allow the bubbles in the suds to break, and the washer will add water for better rinsing. This rinsing process is necessary and may occur several times to eliminate the suds.
Is the drain hose kinked or clogged?
Make sure that the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose.
To remove the error display, press Power/Cancel or Pause/Cancel once.
If Power/Cancel or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start/Pause.
NOTE: If the error remains on the display, and all of the other questions above have been checked, call for service.
Dec 27, 2010 | Maytag Bravos 3.8 Cu. Ft. Washer
F-02 error code on whirlpool front loader duet
F/02 Long Drain
Mar 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Have error code f 02 showing up on my Duet fronload washer, during rinse and spin cycle
F/02
DURéE EXCESSIVE DE LA VIDANGE
If the drain time exceeds eight minutes, the water valves are turned off
and “F/02” is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the “Sud” error will be displayed, then four
minutes later the “F/02” error code will be displayed.
Si la durée de l’opération de vidange est de plus de huit minutes, le système commande
la fermeture des électrovannes et l’affichage du code “F/02” clignotant. Appuyer deux
fois sur la touche PAUSE/CANCEL pour commander l’effacement.
NOTE : Après quatre minutes le code d’erreur “Sud” sera affiché; quatre minutes plus
tard le code “F/02” sera affiché.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Nov 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F02 code flashes and stops rinse cycle
Long Drain If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be disp NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the displaylayedPress PAUSE/CANCEL twice to clear the displayCheck the drain hose and make sure it is not plugged or kinkedCheck the electrical connections at the pump and make sure the pump is runninCheck the drain pump filter for foreign objects.g. If the above does not correct the problem, replace the pump.
Jul 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My washer will not go through a complete cycle. It flashes F2 and will sit on SUD for ever as well as run on the last 1 minute for an hour. Help
If the drain time exceeds eight minutes, the water valves are turned off and “F/02” is flashed. Press PAUSE/CANCEL two times to clear the display. NOTE: After four minutes the “Sud” error will be displayed, then four minutes later the “F/02” error code will be displayed. Si la durée de l’opération de vidange est de plus de huit minutes, le système commande la fermeture des électrovannes et l’affichage du code “F/02” clignote. Appuyer deux fois sur la touche PAUSE/CANCEL pour commander l’effacement. NOTE : Après quatre minutes le code d’erreur “Sud” sera affiché; quatre minutes plus tard le code “F/02” sera affiché. Possible Causes / Procedure 1. Check the drain hose and make sure it is not plugged or kinked. 2. Unplug washer or disconnect power. 3. Check the electrical connections at the pump and make sure the pump is running. 4. Check the drain pump filter for foreign objects. 5. Plug in washer or reconnect power. 6. If the above does not correct the problem, go to step 7. 7. Unplug washer or disconnect power. 8. Replace the pump.
Jun 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Get error code f02
Long Drain
to resolve
Mar 02, 2009 | KitchenAid KHWS02RMT 3.7 Cu. Ft. Ensemble...
Drain
This should solve the f/02 problem.
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. After 4 minutes the "Sud" error should be displayed, then 4 minutes later the F02 error code. Press PAUSE/CANCEL twice to clear the display.
Then
Sep 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
66 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
