Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
Craftsman air compressors
I have a 2hp/4gallon compressor.I turn the valve all the way open,but can only get 40psi,and it keeps on running never increasing pressure.It maybe the filter,if you think it is can you please tell me where to find it.Also,I've noticed hot air coming out of the back.It is stronger on one side than the other,is this normal to do that.I have a roof to do this week,and can't afford to buy or even rent another one.Thank you for anyones help.
  • 2 more comments
  • viper17 Oct 07, 2008
    I have same problem and it's not the filter? Drained the water. Still nothing above 40PSI
  • Anthony  Cappadona
    Anthony Cappadona Oct 12, 2008
    I have the same problem on mine (15gal 3hp). After replacing the regulator and that didn't work. I took apart the plastic housing and found that the copper tubing coming from the pump to the tank has a rubber piece at the head has failed. This tubing just rests in it. Doesn't look like it would be too much. But you would possibly also need to replace the head gasket also minimal in cost.
  • road2runner Feb 23, 2009
    craftsman Model# 921.153101, 3 gallon 1.5 hp
    It pumps up to 40psi and then just keeps running. I checked oil level it was ok. I checked air filter it was ok. The tank holds pressure fine while running and when turned off. It is not overly hot only warm.
    I checked for air leaks all around unit could not find any.
    I purchased this in 2005 and have only used it a handfull of times to pump up tires and blow dust off stuff. It still looks like it came out of the box. The filter had now dirt or dust present.
    Does anybody have an answer?
    thabluetzel@gmail.com
  • road2runner May 06, 2009
    Craftsman 3 gal Air Compressor, 1.5 hp, Horizontal Model #921153101
    It won't pressure up. It use to pressure up to about 40lbs but now it won't pressure up at all. I have checked for leaks and found none. I have taken the head off and inspected the reeds and they are fine (not broken just some oil on them, very minor). You turn it on and it just runs with no air pressure movement. I check the check valve it was ok.
    I turned the machine on with check valve out and it is blowing air into the tank. It pressures up a very small amount because I can pull the ring on the relief valve and air blows out.
    What do I do next. I went to sears service center and they told me no techs on site. Have to send in and it cost $30 and then plus repairs with no guarantees it will be fixed. They offered me a reconditioned on at $80. A brand new one cost $99. Should I just throw it away and go to walmart. Or is there someone that can help.
    Thank you
It is definitely the little spring steel flappers in the head. They are similar to the reeds in a 2-stroke motorcycle engine -- if you've ever had one. They open up a little to let air in on the down-stroke and close off the air intake port on the upstroke. Probably just a piece of one has broken off and it will allow the compressor to pressurize the tank somewhat depending how much of the flapper has broken off. You will notice that your air gage needle on the compressor pulsates when it comes up to the maximum pressure it can attain with that piece missing.
There are two different sets of the flappers in the head -- one for air intake and one for allowing the newly compressed air into the tank. Buy them both and a new head gasket or "O" ring.
Good Luck, Richard
Posted on Mar 14, 2009
  • Mike Schminke
    Mike Schminke Dec 16, 2016
    Where do you buy the reeds? I can't find the Bronco listed on Clarke website.
Well I can't promise you this is the answer on yours, but I have the same compressor and it would pump up to about 60 psi and just sit there and run. I tried everything and ended up taking the compressor off the pancake and turn the compressor until the piston is all the way to the top. Take the 4 small bolts out of the head and there is a valve plate between it and where it mounts on top of the piston. Be careful not to damage the o'ring that is between them. There are three little pancake looking flappers under the valve plate and chances are one of those or more are broken off, causing it to bleed by and not pressure up to the normal 125 psi. If it's not that and not the little rubber isolator that hooks on the end of the feed line that goes into the head, I can't imagine what else it could be. Either one of these things can make it bleed by, causing it not to pressure up correctly. You might have to replace the head gasket when you do this. The valve plate is about $14.00, and the head gasket is $8.00 and the isolator gasket is somewhere around $2.50. I really hope this helps, and I have a feeling that it will if you haven't already gotten it fixed. Let me know if this does the trick.
Posted on Feb 12, 2009
    Scholar:
  • 121 Answers
On the air intake is located the air filter Unfortunately it sounds like your valves or regulator is weak not allowing it to build pressure
Posted on Oct 07, 2008
Based on these posts I decided that my reed valves were bad so I took off the cylinder head. Turns out the seal on the piston had folded over on one side and scored the cylinder badly. The whole cylinder was badly scored. My guess is that I didn't clean the air filter enough? That may have led to scoring and the subsequent breakdown of the teflon coating which eventually destroyed the piston ring? I frequently used it in very dusty conditions, doing bodywork and such.
The good new is that the reed valves are fine. :)
Posted on Mar 17, 2009
Maby more infomation about your question in Denair air compressor
Posted on Nov 02, 2011
I don't think its the filter,
first make sure the drain valve is closed, although the hot air coming out may indicate you have a ruptured seal.
You can order replacement parts by going to Sears.com and clicking on the parts link.
You can also order by phone a 1-800-4my-home 1800-469-4663
Posted on Feb 20, 2009
  • drasser Feb 15, 2011
    I have the same problem with a 921153101 craftsman compressor, when I opened the head everything looked fine untill I took the small brass plate off the top and noticed that the gasket had blown out inbetween the air intake side and the tank fill side. I bought all the parts gasket kit piston 2 sets of reeds etc from melco on ebay for $52 including shipping. Havent put the gasket in yet so I can check but I am pretty sure thats what was wrong.
When the air is left out, the compressor will kick the electric outlet breaker off. Why?
Posted on Feb 01, 2009
I have a Craftsman (919.176820) 2HP, 12 gal. compressor. I starts fine the first time, it reaches full pressure and cuts off. When the pressure drops and it tries to start again, the motor lugs and trips...
Your tank check valve is stuck/broke. It's on the tank end of the line from the pump to the tank. It is supposed to close when the pump stops to keep air in the tank and let the system bleed pressure out of the pump so the motor can start when there is pressure in the tank. The part you need is CAC-437-2 and is available through searspartsdirect.com.
Feb 22, 2012 | Craftsman 33 gal Air Compressor 6 hp...
I have a model# 919166442 air compressor that all at once quit building air pressure. when it gets to 40psi the engine keeps running but air pressure wont rise
There is a check valve that has gone bad,this allows air into the tank,and does not allow the air to go back toward the compressors head.This can also cause the compressor to lock up.
May 17, 2011 | Craftsman 15 gal Air Compressor 3 hp UMC...
I have a 2hp 4gallon master craft oil less air compressor,and would like to know where I can get a new compression ring for this unit.I would also like a compressor parts list which includes pump break...
did u try here www.searspartsdirect.com they carry a lot of stuff that would suprise you. I just wonder if the compressor is even worth repairing compared to a new one or just buy a new compressor head providing the motor is in good shape from graingers, or nothern tool.
Oct 26, 2010 | Garden
Craftsman compressor
these small compressors do not have a long life especialy if they are run for more than 15 min /hour , bet no body told you that when you bought it the ones with an iron barrel are better so to problem
1 piston rings worn or broken / replace
2 daft i know but air leaks/ when it is running you carn't hear a leak cos of the running noise,run it up as high as it will go switch off and listen /repair leak
3 sticking or passing valves , these are located in the cyl head /take filter unit off,run it when it comes up to 40 psi put your hand close to the inlet port if the inlet valve is passing you will feel a sort of chuff chuff on your hand ,switch it off ,if you can hear ,and feel air coming out of the inlet port the Exaust valve is leaking ,sadly these small comps are difficult and bloody expensive to get spares for"they want you to buy another one " so depending on the amount of use it has had it might not be woth while repairing hope this has been of some help
merlin v12
Aug 17, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman compressor runs for 10 sec. and shuts off.
I have a Craftsman 2hp/12 gallon Air compressor that does basicly the same thing, will start, run for about 3 seconds and stop. I replaced the pressure switch but still have the problem. Any suggestions?
Apr 08, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Ec12 hitachi air compressor will not build pressure higher than 40psi
most likely the the reed valves are stuck or miss aligned. Worse case senerio your piston seal blew causing this not to build pressure. Read manual on how to disassemble head. to remove should be 4 bolts and your copper line, just be careful of the reed valve plates, they are thin steel that sit into the head. Put back the same way you took it apart.
Feb 28, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
2,636 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
