Question about OKI Office Equipment & Supplies
Paper jam on Okidata 4250 - OKI Office Equipment & Supplies
5 Suggested Answers
Soulvisitor
  • 1113 Answers
SOURCE: Okidata C9500 DXN--Printing Issues
Your asking a bit much
1) - Power ON printer while holding both the + & - buttons until “OKIUSER” message appears in LCD.
2) - Press + or – button until “ENGINE DIAG MODE” is displayed.
3) Press "ENTER", displayed will be "DIAGNOSTIC MODE XX.XX.XX S-MODE"
4) Press + or – button until “NV-RAM INITIAL” is displayed.
Half way, dont stop too long it will time out....
5) Press "ENTER" again.
6) Will appear "TABLE 1" message.
7) Press "ENTER" until "EXECUTING RESET" message appear. .....
..........the "NV-RAM INITIAL" message will BLINK.
Tada....This procedure reset TONER, DRUM, FUSER and BELT...life counts
8) power OFF printer, wait 10 sec, and power ON again..
To access Service Mode in C9300 power ON printer with 0, 1, 6, 7 at same time...you can do some good damage in there!! (I warned ya!)
Resetting consumables for OKI C7300,C7500,C9300 printer I think!
1. Hold buttons 0 + 1 + 6 + 7 on startup.
2. Press button 0 several times until "DIAGNOSTIC MODE xx.xx.xx" shows.
3. Hold buttons 2 + 3 until "ENGINE DIAG LEVEL 4" shows.
4. Press button 1 to scroll to "COUNTER SET".
5. Press button 2 to scroll through menu items (button 6 scrolls backwards)
6. To alter the value of an item, first press button 3 to select the digit to be altered. The selected digit will slowly flash. (Button 3 moves to the right through the digits. Button 7 takes you to the left.)
7. Then press button 2 to increase the value of the selected digit. Press button 6 to decrease the value.
8. When the changes have been made hold buttons 1 + 3 + 5. The screen will flash three times and then an * will appear on the right of the screen. The new value is set.
9. To leave the counter set menus, turn the printer off.
IMPORTANT
Each colour toner counter shows life as percentage used. So a toner showing 30% has used up 30% of its toner. 100% would indicate a near empty toner. This is the reverse of the toner life shown from the "usage menu" when the printer is in normal operation, which shows the toners as a percentage life remaining. You will want toner showing 00%. note:this is oposite of what you see in user mode
Some models exhange these steps
3) HOLD 0 + 4 "ENGINE DIAG LEVEL 2" shows
4) Press 1 to cycle to "fuser unit"
5) 2 to scroll to TONER
REST IS SAME WE WANT TO SET WHAT i GUESS IS AT 100% TO 0%.
Posted on Nov 19, 2007
Printerguru
  • 10 Answers
SOURCE: hp 4250 paper jam erro
Is it a new or refurbished fuser? Where exactly does it jam. By trays, registration or before fuser? Problem can be with various sections. Need to know more.
Posted on Feb 13, 2008
rey17
  • 66 Answers
SOURCE: HP 4250 down (paper jam without paper)
hi,
the fuser of that unit is in the back, you can saw it by sliding out the back cover. you can pull it by unlocking the 2 lock on side of it..
try to locate the sensor of the fuser assembly.and also try to see if they pick up very well both tray 1 and tray 2..
hope it would help you..
Posted on Oct 29, 2008
  • 630 Answers
SOURCE: on my hp c 4250 printer jams every time i print
Clean the rollers and check for pieces of paper in the feed path.
Posted on Jul 20, 2009
  • 95 Answers
SOURCE: okidata c9500 paper jams between
If you are getting jams in the fuser or right after it the fuser is probly bad. I think there is a mylar upgrade that attaches to the toner sensor arms under the top cover(not an easy fix). It is also possible the drum unit or the toner cartridge could be bad.
Posted on Aug 09, 2009
How do I reset paper jam on my okidata 7300 when there is no paper present I inspected top bottom and front no torn pieces visable, including duplexer Hamilton
The jam indicator clears when the jam is removed. If you don't see a jam but it still indicates one the a sensor is dirty, popped out, or bad.
Jan 03, 2010 | OKI C3400n Laser Printer
Okidata c5510 error message ADF paper jam there is no paper in the feeder or on the glass
the adf sensor is not working. see if it is stuck or actkivated somehow.. it might need to be replaced in this case it sounds. could be paper dust though.. check it out and clean it up.
Thanks!
Stan Skaggs
Nov 18, 2009 | Okidata Multipurpose Feeder For All...
Okidata C6100 getting an error 391
It means paper jam in the 1st paper tray. Check above the pickup roller sometimes, paper will get jammed in there good.
Jul 08, 2009 | OKI C3200n Led Printer
Paper jam on a laserjet 4250
Is the paper tray set to the proper size? and are the tray guides snug against the paper?
Apr 14, 2009 | HP Office Equipment & Supplies
Fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
Paper jams consistely and then continues to feed, even if only printing one page
check your paper size setting on your print menu. i had this problem when i set the paper size smaller than the printer is able to handle (3x5 card) ... i just switched to 4x6 and don't have any problems.
Oct 24, 2008 | OKI C5100n Laser Printer
Okidata-B6200-
Check the reg sensor for dirt etc and paper setting is correct in the paper tray
Sep 24, 2008 | OKI B6200 Laser Printer
hi,
Aug 05, 2008 | HP 4250 Monochrome LaserJet Printer
MY PRINTERS KEEPS PRINTING OVER TOP OF ITS SELF
Hi amyellis, please click on this link below which will take you to okidata ML320Turbo's page. http://my.okidata.com/PP-ML320Turbo.nsf?
Download the pdf manual for you're ML320Turbo.
For English click here: http://my.okidata.com/mandown.nsf/1fe7d58578ca7f99852569af0042834b/e08d475cb4b6bf4a852569590039ffc6/$FILE/ae320tug_07.pdf
Once opened click the + sign next to Index. Than click the + sign next to Paper. Than click the + sign next to Paper jams. Follow the instructions to clean out paper build up within the printer. This is the most likely reason the paper is not moving.
Within the pdf file in the upper left hand corner is a small icon that looks like a gray floppy diskette. Click it & save the manual to you'r PC drive. You may need it from time to time.
Good Luck!
Have more questions? Please feel free to ask.
Mike
May 14, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Hp 4250 paper jam erro
Feb 12, 2008 | HP LaserJet 4250dtn Printer
73 people viewed this question
Top OKI Office Equipment & Supplies Experts
Soulvisitor
Soulvisitor
WTF Chuck.....
WTF Chuck.....
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
