Question about TruTech PVS12701 Portable DVD Player
Screen does not show picture, distorted image
The screen no longer shows a picture/dvd. It just has a distorted porthole as you would say that does not show anything, part is black and the rest is white. Was not dropped or anything like that but did go through xray at airport. Can that mess it up?
  • 3 Answers
If you go to 1800customersupport.com it has some good info. Alco Electronics is the maker.
Posted on Oct 30, 2008
DVD leaves 1/2 border on left side of screen in wide mode. what is Cinema aspect ratio for? Distorts Adjustment?
you have to adjust with the dvd players settings.
google your make and model #, manual and manual should show.
press the helpful button and follow me on fixya for more tips
Feb 01, 2016 | Proscan Televison & Video
How to zoom in on info
When TVs first appeared, they had an picture ratio of 4:3, which matched that of most movie screens at the time. Terrified of losing their business, movie studios struck back with "widescreen" films using 1.85:1 or 2.35:1 ratios. When widescreen TVs started appearing, they emulated those same ratios, but many TV shows (and some movies) were still in 4:3---and we were eventually left with a bit of a mess. Canny manufacturers, including LG, have solved the problem by allowing you to adjust the picture ratio on the TV to fit the program you're watching. If it's not set properly, however, your image will look distorted or cut off. A quick bit of troubleshooting can fix the problem easily.
  1. Press the "Menu" button on the remote and scroll down to the "Option" title (it should be second from the bottom ). Then select "Aspect Ratio." You should see a list of ratio options. You simply need to pick the one which fits the show you're watching.
  2. Choose the 4:3 ratio for older movies and TV programs. You should see a pair of bars on the left and right side of the screen. (That's okay: the bars keep the program in the same proportion in which it was filmed.)
  3. Select the 16:9 ratio for widescreen movies and for more recent shows to match their longer width. For some movies, you may see black bars and the top and bottom of the screen. Again, that allows the movie to be shown in the manner it was filmed.
  4. Pick "Set By Program" to automatically switch the LG TV between 4:3 and 16:9 to match whatever show is on at the time.
  5. Select "Horizon" to horizontally expand the image onscreen. It will fill the whole screen---eliminating the black bars to the left and the right---but it may look distorted.
  6. Use the "Zoom 1" option to zoom the image forward. That will eliminate the black bars at the top or the bottom of the screen, though you will cut off the edges of the image.
  7. Pick the "Zoom 2" button to select a midway point between "Horizon" and "Zoom 1." The picture is stretched, but not as much as with "Horizon," and fills the screen, but doesn't cut off as much as "Zoom 1."
  8. Use the "Cinema Zoom" button to enlarge the picture to fit the screen. This option allows you to adjust the proportion to your liking, rather than use the set proportions of the other aspect options.
  9. Exit the menu when you are done and watch your programming normally.
Feb 04, 2011 | LG Televison & Video
Lines and distortion across screen when on. If picture is taken it shows those lines and distortion
It is known problem of ccd imager chip failure in Canon A60 camera and ccd imager chip will be replaced to fix this issue.
Canon offers ccd imager chip replacement free of cost, click Canon CCD Imager Advisory for details.
Thanks.
Apr 17, 2010 | Canon PowerShot A60 Digital Camera
The lcd screen distorts & my pictures show up pink on the display screen on my ixus 500
If the menus and icons look normal, but images are distorted or discolored, you may have an image sensor (CCD) problem. See Canon's service notice regarding this issue here. Canon will repair your camera at no cost regardless of warranty. Contact them at your regional Canon service agency.
Mar 26, 2010 | Canon PowerShot S500 IXUS 500 Digital...
Canon A75 - viewfinder shows- purple distorted picture.
Its bad ccd imager in camera and this part will be replaced.
Canon will repair Free of Cost A75 camera as per announced scheme.
Click Canon CCD Imager Advisory for details.
Mar 15, 2009 | Canon PowerShot A75 Digital Camera
Horizontal hold?
possible bad solder connections at the horizontal drive transformer connections, could also be a bad capacitor in the horizontal circuit look for Capacitors that are bulged or show signs of leakage.
Aug 20, 2008 | Mitsubishi VS-60707 60" Rear Projection...
PURPLE LINES SHOWING ON SCREEN WHEN ATTEMPTING TO TAKE PHOTOS
Your camera likely needs a new CCD imaging sensor. It is a cute little thing and is very expensive to replace. I've seen deals to repair any digital camera on eBay and I would check for a local repair person in your area. You can use the search on this site to see who might be close by. I have an A310 doing the same thing.
Jan 04, 2008 | Fuji FinePix S5000 Digital Camera
Camera showing/taking distorted images
According to many respected sources with far more expertise than myself, the symptoms you are describing also fall within the realm of Canon CCD failure. In Canon's Service Notice: CCD Image Sensor Advisory, they outline the most common symptoms (distorted images, LCD showing only a black screen, etc.). They have conveniently limited the description to the bare minimum. More symptoms of the failing CCD include: pictures appearing on LCD show up with severe color variations (pink-purplish or green tint), colored "streaks" or "lines" throughout pictures, and wavy distortions in image. Most of these symptoms include the color variations, but not always. The lines or waves can appear in any direction and with varying degrees of severity. Some LCDs do not go black, but turn totally purple. Here is a link to a very informative article that should clear up any questions you might have.
Digital Camera Repair Blog
If nothing else, call the Canon Customer Support Center at 1-800-828-4040. They will ask questions to identify whether or not you are having the same symptoms as described in the Product Advisory. I have been through this twice, and both times they were very nice and very helpful. Even if you don't qualify for the free repair, it didn't cost a thing to find out.
I hope this has been helpful.
Nov 20, 2007 | Canon PowerShot S1 IS Digital Camera
DC400 Screen only showing slanted multicolorlines
No this is clearly a CCD sensor problem ( CCD generates image in v-cams and still digital cameras ) if the sensor is outputting too much noise then your image will be distorted just like yours is. If the sensor is outputting nothing then camera shows blank screen ( also notice that with this problem you can playback OK ). Replace CCD block.
Sep 06, 2007 | Audiovox DC400 Camcorder
TruTech PVS12701 Portable DVD Player Logo
99 people viewed this question
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
