Question about Linksys Wireless-G WRT54G Router
Wireless router hookup...
I have been connected to the router and it was fine, I recently had to recover my computer and lost all my info, I am trying to reconnect to the wireless but it is asking for a password I don't have anymore, what can I do....??
    Problem Solver:
  • 35 Answers
You need to access the setup of the router and verify the wireless security key.
1. First connect your computer to router (wired)
2. Access the setup of the router (OPen IE Enter 192.168.1.1 Default ip add of linksys router)
3. It will ask for username and password -Just leave username blank and password admin-
-If you changed the router password then you can use your own password
4. You will be directed to user interface of the router (setup page)
5. Look for wireless TAB, after clicking wireless TAB look for WIRELESS SECURITY TAB (Its a small tab under wireless TAB)
6. When You are already under wireless security TAB -Look for Shared Key if you are using WPA and key 1 if you are using WEP-
7. Shared KEY for WPA and Key 1 for WEP- Just use the value of shared key or KEY 1 as you network key-
Goodluck!!
Posted on Oct 04, 2008
  • Linksys Master
  • 6,487 Answers
You need to use a working computer with the router then access the router setup page that way you can get the wireless security key, then follow this step:
Open a web browser like internet explorer or Netscape. Enter the ip address of your router in the address bar of your browser. In the picture above the address bar has http://www.google.com in it. Just replace all of that with the ip address of your router. By default the ip address should be set to 192.168.1.1
You should see a box prompting you for your username and password. Enter your username and password now. By default the username is blank, and the password is admin. Click the Ok button to log in to your router.
When you're already on the Linksys router setup page, click on Wireless tab and look for a sub tab that says Wireless security and there you can find the security key that you're looking for..
Hope that helps..Don't forget to rate the solution FIXYA thank you...
Need passwword for belkin wireless router
By default, Belkin routers do not have a password,just click on Submit to log in..But you should check check your Belkin router setup documents.
If you forgotten or lost router password cannot be recovered. It can only be reset by hard resetting the router.
Sep 11, 2012 | Belkin (F5D7230-4) Router (587009)
Lock my router
You can reset you router to it's factory default settings:
Have you somehow lost your D-Link router's password? Perhaps the easiest way to gain access to your router's admin interface is by restoring it to the default factory settings, however, if that is not possible, try method number two via the master password. If you lost your WEP password, visit this post for more info - Recover Lost WEP Wireless Network Password Key.
I hope this information will be helpful. Thank you for using FixYa!
Jul 17, 2012 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Lost connectivity after power outage
If this is a printer WITHOUT WiFi or bluetooth - and you have it connected to another computer (Print Server) via a USB cable - you need to make sure you can see that computer from the other computer you are printing from. Use the network explorer - if you can see the computer and the printer you should be able to print to it.
Sometimes, it may be secured with a password. I found if I can map a shared drive from my laptop to my print server then I can print again. So see if you can see the printer and printer server computer from the other computer. If so you may need to add that printer again to you printer list.
May 01, 2017 | Zonet ZPS3611 Print Server
My laptop cannot hookup to the enternet with my dlink wireless card
To connect to your wireless router, it needs the router’s wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router’s wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
To access the Internet you need to connect the DSL or cable modem to the WAN (Internet) port on the wireless router.
Nov 29, 2009 | Computers & Internet
Belkin N1 Wireless router wont fully connect to laptop
if you connect your xbox and it works than it is not your isp
go to your network setup and try it with fix ip and DNS to you vista laptop wirless card /fixed card ip setup
goodl luck get back if this does not work with more info on your network setup
Jun 12, 2009 | Belkin (F5D8231-4) Wireless Router...
Network has suddenly dissapeered
This is just a problem with the wireless settings of the router, you can try first to reset the router by pressing the reset button for 20 seconds while power is ON and then after that you should be able to find the default wireless name of the router which is linksys, after you reset the router just need to reconfigure it back...
Jan 04, 2009 | Linksys Wireless-G WRT54G Router
Trying to hookup a wireless router to HP 1100
DSL uses PPOE, which may be different than what you had previously. Cable, for example, uses TCP/IP.
Re-set the router to defaults, and follow the instructions for PPOE, which should be in your manual or setup disk. Your ISP may have this info on their site, or you can get it at the Netgear site:
www.netgear.com
Oct 17, 2007 | 2wire HomePortal 1100 Router...
Linksys Wireless-G WRT54G Router Logo
107 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
