Question about JVC KD-G820 CD Player
Nothin works When i instalded my JVC KD-G820 it worked for about a minute, then nothing started to work except the clock on the display and then that eventualy turns off. Ive checked all the wirring, and all the fuses, and everything was correct, but it still wont turn on.
    Problem Solver:
  • 10 Answers
Did you reset it? theres a little hole near the right side (with the fac plate off) i had to reset mine when the radio just went static nothing would play.
Posted on Jan 19, 2010
SET CLOCK ON JVC KD-200
Press and hold SEL (select) for more
than 2 seconds.
"DEMO," "CLOCK H," "CLOCK M," "DIMMER,"
or "AMP GAIN" appears on the display.
Set the hour.
1 Select "CLOCK H" (hour) if not shown on
the display.
2 Adjust the hour.
Set the minute.
1 Select "CLOCK M" (minute).
2 Adjust the minute
Sep 28, 2014 | JVC Car Audio & Video
How do i turn off demo mode? And set the clock?
  • Press and hold (SEL) button
  • Then turn the control dial to set "Demo/Link" to off
  • Setting the clock
  • Press number button 4 (Clock). "Clock Hr" (hour) appears. Then, turn the control dial to adjust the hour.
  • Press the >>' /\ (fast forward button) to select "Clock Min" (minute). Then, turn the control dial to adjust the minute.
  • Press the >>' /\ (fast forward button) to select "24H/12H". Then, turn the control dial to select "12Hours" or "24 Hours" time display mode.
  • Exit from setting by pressing the (SEL) Button
Hope that helps, don't forget to vote.
Nov 16, 2010 | JVC KD-G820 CD Player
How do i change the time on the JVC KD-G430?
  1. Press and hold (S) SEL Button
  2. Canceling the display demonstrations Select "DEMO," then "DEMO OFF"
  3. Setting the clock Select "CLOCK H" (hour), then adjust the hour. - Select "CLOCK M" (minute), then adjust the minute.
  4. Press and hold (S) SEL Button to finish
Nov 16, 2010 | JVC KD-G430 CD Player
I just installed a jvc kd g825 and i have a iphone 4 when i plug it in it says reading file and starts charging my iphone but wont play any thing any solutions?
I had a similar problem after I updated my iPhone 3g's software to 4.0.1. I read that if you turn off your iPhone, then with your car/stereo turned off, plug in your iPhone. Now turn on the car/stereo which will turn on your iPhone automatically and "re-initialize" the relationship with the iPhone. This worked for me. Hope this helps. If not, check the Apple forums.
Aug 11, 2010 | JVC KD-G820 CD Player
My jvc kd-g820 will not produce any sound and not accept cd
try to find the reset a little indent on the face or hole when you remove the face and push in for 2 to 3 secs with a pen or paper clip. Then try your cd again. Still dont work check to see if you have another cd jammed inside and your trying to put two cds at once.
Ok for your no sound problem. a bad speaker, short speaker (one 1 speaker shorts out all will not work cause the radio is in a protective mode), factory amp needs to be turned on, bose system or amplified system in car needs to be rewired to bypass factory amp), buy special car harness to make factory amp compatible with aftermarket radio, late ford models the back speakers are crisscrossed.
Next time please give car info and type of system you got in it so I could narrow down the possible problems a little bit easier.
Apr 08, 2010 | JVC KD-G820 CD Player
Set the clock
Step by step included, change clock on JVC KD-s590 KTC- 4th Mar 2005 4:00 Setting the clock:
1 Press and hold SEL (Select) for more
than 2 seconds.
“CLOCK H”, “CLOCK M”, “SCM LINK” or
“LEVEL” appears on the display.
2 Set the hour.
3 Select “CLOCK H” if not shown on the
display.
4 Adjust the hour.
5 Set the minute.
6 Select “CLOCK M.”
7 Adjust the minute.
8 Press SEL (select) to finish the setting.
Dec 03, 2009 | JVC KD-S590 CD Player
Cannot set clock on my JVC KD-G335
You need to hold the sel button down for a little while then it will change displays thats when you use youe right seek button until you hit the Clock H to change the clock hour or Clock M to change the minutes when you hit it you use your volume control button to change the time.
Jan 04, 2009 | JVC AM FM CD DET FACE CAR STEREO
Can't set clock
hold down the SEL key and then scroll (TRACK FW or TRACK BW) to the Set Clock option. Then use the Up/Down arrows to set the time and hit Done.
Dec 26, 2007 | JVC KD-G820 CD Player
How do i set my clock on my jvc kd-820 radio?
Hey hold the SEL button then use the next button till clock comes up. then use your valume nob to adjust.
Dec 10, 2007 | JVC KD-G820 CD Player
My jvc kd-g820 is not redinf files from my usb drive
Hey make sure there capable with your deck i have this deck and downloaded the manual and lernt i cant use a 8g usb stick and it reads most mp3s
Jul 26, 2007 | JVC KD-G820 CD Player
JVC KD-G820 CD Player Logo
138 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
