Question about SVA-USA VR-20 20 in. HD-Ready LCD Television
Can't get all the cable channels
We have the SVA VR20 hooked up to our Comcast cable and it only shows 12 channels and we have the full through channel 72. What do we do to get all the channels? We just connected the unit directly to our cable tv line.
Thanks!
    Problem Solver:
  • 10 Answers
Was this problem resolved?
Posted on Oct 02, 2009
Help. I got a used TruTech t200d for my nine year old. we were able to hook up and play on playstation 2, but are unable to get the tv to pick up the comcast channels. we do not have the trutech remote...
U able to go into the tv Menu?Yes,goto SETUP changes Pick CABLE and scan for channels for the Comcast CABLE channels.Or Try website like Remotes.com to buy an original tv remote.
Mar 04, 2011 | TruTech T2000D TV
Can't hook up Comcast cable box into tv. It is an HD comcast cable box and I am trying to hook it up to my childrens princess tv/dvd combo. I can't figure it out. Please help.
I assume this TV has no Audio In and Video In, from your Cable box there's an antenna out or cable out, connect that to your TV's antenna in, and make sure that your TV is tuned in to channel 3 or 4, try those two channels. You can only change channel thru your box, your TV channel is alway's on channel 3 or 4.
Jun 26, 2010 | Disney Princess TV/DVD Combo
SVA-VR20 Light is green when power is pluged in however tv is not on/ the screen is black!
Do you get sound? if you do, then the problem can be in the backlight inverter board or in the power supply section that supplys the power to the inverter board.
Oct 30, 2009 | SVA-USA VR-20 20 in. HD-Ready LCD...
How do you hook up to the comcast digital unit to
tune your tv to channel 3 if you're coax cable, if you're using rca or component cable then tune your tv to the proper input on your tv.
Jun 26, 2009 | Apex Digital AD-1500 DVD Player
Loss of VCR Channels due to Digital Switchover
Comcast is full of it.
If you have a cable box, plug the box directly into the cable feed, then place the VCR inline between the cable and the TV. Leave the VCR on Channel 3 or 4 and use the box to select the channel. You could also use the video and audio out lines from the box and run them to the VCR.
Jun 18, 2009 | Zenith VCS442 VHS VCR
Will not record digital channels
first make sure the cable is running through you vcr then make sure you vcr is set to either channel 3 or one of the inputs
May 06, 2009 | Philips MWD2206 DVD Player/VCR
Took toshiba off comcast control and now ct-90157 won't work
We found the manual at home and was able to program the t.v. to recognize all the channels from cable and store them.
Jan 26, 2009 | Toshiba CT-90157 Remote Control
No Non-Hd sound
I had the exact same problem on a brand new Insignia 26 " LCD with DVD. Comcast tech was able to fix it by changing the Comcast box diagnostics. Here is what he did. Using the Comcast remote with the TV on - press power, cable, menu in that order. A comcast diagnostic srceen will appear. Select Additional HDMI options, then audio options. Change the audio options to L-PCM. Press power again to exit the diagnostics. That will fix it and you get to use the HDMI cable.
Jun 19, 2008 | Insignia 26 in. LCD Flat-Panel HDTV
Channel issue
Do you have a lot loose connection inside tunner. Need be re solder. Do this and TV will be ready!!.
Apr 17, 2008 | RCA F27442 27" TV
Sound Issue
Try with another set or two may be Comcast problem or a bad
cable If problem is isolated to TV then the mode sw may be
suspect antenna, cable ....
Nov 15, 2007 | RCA 14F512T 14" TV
SVA-USA VR-20 20 in. HD-Ready LCD Television Logo
105 people viewed this question
Top SVA-USA Televison & Video Experts
Henry  Thomas
Henry Thomas
Tony
Michael Galve
Michael Galve
Are you a SVA-USA Televison and Video Expert? Answer questions, earn points and help others
