Question about Magellan MAESTRO 3100 98083401 GPS Device
Magellan maestro 3100 failed update
Help please...I went to update my magellan maestro 3100 and the update failed and the unit is unusable.
  • 1 more comment
  • rvda Jan 25, 2009
    Ok, I have the same problem, but I did not back up because I had nothing of "mine" stored on it. Does anyone have a the info that should be on the backup that I can copy?
  • queenethdebr Feb 07, 2009
    My back up failed an now I do not have the backup files or the usbtrans? I have nothing when I turn my unit on? Any one that can help??? Please. Thanks
  • Anonymous Apr 12, 2009
    I wanted to update my firmware, and now my GPS does not work, except to show the Magellan sign and nothing happens beyond that.
Go to Tech support at www.magellamgps.com tell them what has transpired and ask for 2.18 Update Recovery Files. This fixed my problem. Took a few email exchanges but I thought the responses were very quick.
Posted on Mar 13, 2009
  • 3 Answers
Maybe has a memory issue. Did you ever get it to work?
Posted on Mar 09, 2009
  • 3 Answers
To make the Guest solution clear, you copy USBTRANS (it should contain 1 file: UNIT.DAT ) from your backup SD card to your Maestro 3100's SYS folder.
Posted on Oct 29, 2008
If you followed the procedure closely, you now have an SD card with your backup on it. The backup consists of two folders: BACKUP, and USBTRANS. Insert the backup SD card in your PC's reader slot.
With the Maestro 3100 connected to the PC, you can see the file structure for the GPS, and a separate file structure for the blank SD card needed for the update. Look at the file structure for the GPS and you should see a handful of folders including SYS.
  • Start the upgrade program, following the procedures.
  • Click the NEXT button at the bottom of the procedures screen.
  • Immediately copy the backed up USBTRANS folder (and all contents) to the SYS folder on the GPS.
  • The update should now find the Maestro 3100 and proceed with the update.
I just got my Magellan Maestro 3100 GPS unit. I let it charge today and tonight I went to go do the available update. However, during the update, the update stopped and it told me that the USB port could...
hi simple181
you can if your computer can still see your gps and if you backed up your files before you did the update. if not, i do have the files, but your computer needs to see your 3100 and you need to do a few things before you start.
its alittle nerve racking if your computer cant see your gps, specifically the tfat (not the sd card)
#1 does your computer see your 3100
Bill
Standing Member of G.O.T.
Please Support Our Troops
Aug 14, 2010 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan maestro 3100 stuck at bootup screen
did that just happen all of a sudden or did you try and update the 3100 and it failed to boot after that...if you didnt try to update it...turn the 3100 on then use a paper clip to depress the reset on the left side bottom of the gps and let it restart.
if that fails, let me know and ill help you further
bill
Jul 15, 2010 | Magellan MAESTRO 3100 98083401 GPS Device
Blue Screen with a black progress bar
i asked yesterday what for error message were you getting, but you havent replied so maybe you missed it. the dos box you are refering to is part of the update process for the 3100. run the update again and be patient, this update is huge and takes about 30-45 minutes to complete.do not remove usb cable untill directed to do so then the unit will reboot numerous times to install the update. do not attempt to touch the gps until you see the screen with the time zone. if that fail hopefully you copied the files before you tried to update it. if the update fails again, let me know and ill show you how to restore your 3100
Aug 17, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Hi My Magellan Maestro powers up with the Magellan screen and the bar scrolls but thats all it does? Carl Lucas Aberdeen MD
i just replied to a fellow with the same problem and since your problem is same, ill post what i wrote him/her but try a hard reset 1st..turn the gps on then locate the little pin hole on the side, using a paper clip, push reset....if that fails, try the 2.18 update if you havent already.
updates for any magellan can be found HERE
but read below first before getting the update
i cant stress enough that patients is a must here. this update is huge 1.75GB
follow the instructions below whether you have updated your gps already or not!
There are few ways to solve this problem. i assume you installed the 2.18 update for the 3100 and assuming you tried the reset already, try and run the update again and follow the directions to the letter..make sure the battery is fully charged (i also keep mine plugged in if the update doesnt say not to) and do not try and run the update across a network. this update is huge 1.75GB and can take an hour or so depending on the computer..do not interrupt the update process. if you do not have the 2.18 update read me file, i can try and post it here, but its in PDF and dont think i can post that
if all else fails, magellan will fix or replace for free any of there gps that were rendered inoperable due to one of there updates.
either solution will work but magellans going to tell you to run the update again anyway before sending it back.
i gave you the 2 easyest ways to fix it,but
there are other ways to get it running again, but if your not comfortable copying and moving files...youll make it even worst then it is.
hope this helps.
bill
Comments: Jul 19, 2009 - here are a few key points, but read the full update guide before trying the update again.
hope this helps
NOTE: This update is COMPATIBLE ONLY with Windows® XP.
Before Beginning:
Check to make sure you have everything required for updating your unit:
• Magellan Maestro 3100 GPS
• PC running Windows XP
• A Blank SD memory card (16 MB to 2GB)
• USB cable
• Paper clip or similar object (for resetting your unit)
EACH OF THE FOLLOWING POINTS IS CRITICAL TO THE UPDATE PROCESS
1) The battery of your Maestro 3100 must be fully charged before beginning the update.
NOTE: It takes between 3 and 4 hours to fully charge the battery with your vehicle power adapter. Check System Settings to ensure the battery is fully charged.
2) Your Address Book will be erased during the process. Please back up your data to an SD memory card.
a. Insert a blank SD memory card
b. Select User Options
c. Select Backup and Restore
d. Select Yes to confirm
3) Do not connect your Maestro 3100 to your PC until instructed to do so by the Update Wizard.
4) Close all other applications while performing the update.
5) Disconnect all Pocket PC devices from the USB ports on your PC.
6) Insert a blank SD card (16 MB to 2GB) into your Maestro 3100.
7) Perform a hard reset on your Maestro 3100 by pressing a paper clip or similar object into the hole marked reset.
Update Process:
1) Launch the Magellan_Maestro_3100_2_18.exe file.
2) Select Next on the Welcome screen.
3) Turn on your Magellan Maestro and connect the USB cable.
Aug 03, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Mine isnt telling me where to turn at all
make sure the gps in not muted. check the mute on and the sound turned up on the map screen and also check the sound in the options/system/ sound, if they are both ok and the try a hard reset 1st..turn the gps on then locate the little pin hole on the side, using a paper clip, push reset....if that fails, try the 2.18 update if you havent already. READ UPDATE INFO BEFORE UPDATING,VERY IMPORTANT
i cant stress enough that patients is a must here. this update is huge 1.75GB takes atleast 30 - 60 minutes depending on your system.
hope this helps.
bill
hope this helps
Before Beginning:
• USB cable
Update Process:
Jul 30, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
My magellan maestro 3100 screen says Venus0 UT R06?
you have what is refered to as BRICKED YOUR UNIT! this is not for the faint at heart to repair as it involves alot of moving, coping and pasting files but im going to give you a link that you can follow to restore you unit. 1st i must say that if this occurred after you updated the 3100, magellen will repair or replace any unit that was renedered inoperable after their update. i suggest you call them if that is the case.
Hours: Monday through Friday, 6:00 a.m. to 5:00 p.m. PST/PDT
Telephone: 800 707 9971
the below link will instruct you as to how to restore your unit if magellan is no help.
GpsPasSion Forums
please let me know if this was helpful or you need further help...bill
Jul 14, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan maestro 3100 frozen on blue screen tried power on and off and reset button still frozen black bar at bottom of scren stays on blue screen
hope this helps.
bill
hope this helps
Before Beginning:
• USB cable
Update Process:
have you updated the maps on it? if no try and update the maps also do a firmware check to see if you need an update.
Nov 25, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan GPS
Online at Magellan website you can update your magellan maestro 3100
Mar 25, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan Maestro 3100 stuck on
If you followed the procedure closely, you now have an SD card with your backup on it. The backup consists of two folders: BACKUP, and USBTRANS. Insert the backup SD card in your PC's reader slot and open a "file explorer" aka "Windows Explorer", not to be confused with "Internet Explorer". You will use Windows Explorer to click and drag the USBRANS folder to the Maestro.
With the Maestro 3100 connected to the PC, a couple of Explorer folders will open and you can see the file structure for the GPS in 1, and in the other one a separate file structure for the blank SD card needed for the update. Look at the file structure for the GPS and you should see a handful of folders including "SYS".
SUMMARY: copy USBTRANS (it should contain 1 file: UNIT.DAT)
  • from your BACKUP SD card (not the one in the Maestro)
  • to your Maestro 3100's SYS folder.
Feb 25, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan MAESTRO 3100 98083401 GPS Device Logo
1,608 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
