Question about Miele Touchtronic W1113 Washing Machine
Soap left in the machine
We out a small amount of detergent and there is residual at the end of the cycle???
  • 943 Answers
Hi thanks for the question replace your detergent to a low sud zing detergent. thanks the appliance doc
Posted on Oct 05, 2008
Why is water sitting in soap dispenser pullout drawer?
Water remaining in soap dispenser. In front loading washers made by LG (some Kenmore too), water may remain filled in the soap dispenser after the wash cycle. This may be caused by the siphon tube being contaminated by detergent residue. To clear it, remove the siphon cover from the tube, and clean them thoroughly, making sure that all residue is removed. Replace the cover and make sure it seats properly all the way down. This will ensure that the siphon starts and continues until the dispenser tray is emptied. A small amount of water, a half inch or less, remaining is normal. There is a video on YouTube that suggests buying a new detergent tray. Try cleaning it first. There are no parts that will break or wear out under normal use.
Jul 27, 2014 | LG WM2688HWM TROMM SteamWasher
Tip
Getting Rid of Front Loader Mildew and Odor
This advice is for that awful mildew smell associated with front loader style washing machines.
Place the washer on the hottest setting you have with nothing but bleach in the wash tub. Some newer models actually have a “Clean Cycle” available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
USE HE DETERGENT ONLY. Using regular detergent, or improper amounts of detergent can contribute to the build up of soap scum in which dirt can collect. Regular detergent is formulated to be used in a conventional wash tub with capacity of about 35 gallons. A high efficiency front loader only uses 5 to 7 gallons of water. So, if you use regular detergent in a front loader, you are, in affect, using about 5 times the concentration of detergent needed. This can cause oversudsing, premature wear on the pump motor and parts, premature wear on rubber seals, odor from sticky soap residue and skin irritations caused by soap residue left in clothing. Using improper detergent will also void the manufacturer's warranty. Make sure you READ all detergent labels some HE detergent is double (2X) and triple (3X) concentrated.
on Apr 05, 2010 | Washing Machines
Tip
This advice is for preventing or getting rid off that awful mildew smell associated with front loader style washing machines.
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a “Clean Cycle” available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
I hope this information is found to be helpful.
on Dec 09, 2009 | Washing Machines
When washing dark colors there is a soap residue left on clothes,i have tried using very small amounts of soap as well as different brands of soap
Try using white vinegar in place of liquid fabric softener. Half a cup at the rinse cycle in a full load will do it. Trust me, the smell of the vinegar will fade quickly as it works to break down the soap.
There are two other possibilities here:
You're overloading the washer with clothes - An overfull washer has the problem of not providing proper drainage before the spin cycle starts - Soap ends up getting embedded in clothes instead of being sucked out of the drain.
Or, You're using non-HE soap in an HE washer.
Hope that helps.
May 04, 2011 | Washing Machines
The fabric softner is not draining during the cycle
Normally caused by undissolved soap residue. Switch off machine from mains, Remove detergent drawer from washing machine, there might be a small plastic clip that need to be levered by hand before the drawer can come out completely. Soak detergent drawer in a tub of water, rinse under tap and wash thoroughly until all soap residue has been washed away. Replace drawer.
Jan 15, 2011 | Frigidaire ATF6000ES Front Load Washer
Black type residue being left on clothes
This is a common problem on washing machines, if you predominantly do cold washes.
Over a period of time, a washing machine will accumulate a buildup of Soap Scum (excess soap & softener residue) which can stick to the inside of the drum.
This black coloured soap scum occasionally breaks away from the drum, and attaches to the clothing fabric during the wash cycle.
You can rectify this, by doing the following:
Firstly, purchase a packet of CITRIC ACID from your local grocery store (usually found in the baking isle).
Do the following procedure before going to bed:
1) Do a HOT WASH without clothes (Hi water level, with HOT water) - allow machine to fill with hot water, then add the CITRIC ACID to the water. Allow the machine to complete a FULL wash cycle (i.e. allow machine to agitate for 30 mins or so, then drain).
2) Fill the machine again with the HOT water / CITRIC ACID solution, but this time allow it to sit in the bowl overnight (no cycle).
3) Next morning, set machine to spin & drain (i.e. to empty the solution)
4) Set machine to fill with FRESH HOT WATER ONLY (no citric acid), then set machine to spin & drain. This will flush all remaining residue left in the bowl.
Note: Soap scum residue is caused by using excess detergent/fabric softener. Hot Water flushing should be done every 6 months.
Contrary to what the detergent manufacturers state, you should follow Samsung's instructions by using HALF the recommended detergent.
Samsung machines prefer LOW SUDS, and you may find by reducing the amount of detergent used, you may even eliminate the buildup of soap scum.
"If this has helped resolve your issue, please rate this solution"
Oct 31, 2009 | Samsung SW62ASP Top Load Washer
Soap suds on the door at the end of a wash cycle. Miele E526
With all modern front loading washers, you might find that the amount of detergent you need is much less than what is recommended by the detergent makers!
First, be sure you're using the He (High Efficiency) detergent and try using only 2 or 3 tablespoons of detergent. If you've heavily stained clothes, be sure to pre-treat them rather than adding more detergent. That should also help with the extra soap left in the clothes after a complete wash cycle.
Give this a try and adjust the detergent as needed to get the best results for your situation.
Hope you find this Very Helpful and best regard!
Sep 22, 2009 | Miele Novotronic Premier 500 Front Load...
Suds residue left on clothes just washed
ck drain hose end of drain hose should be at least 36 ins from floor also be sure drain hose fits loosely in drain water may be siphoning out resulting low water level to wash/rinse ..also recommend using liquid detergent dry doesn't dissolve good in cold water and even though it may be recommended for front load the lower water levels used may not be enough to dissolve it properly
Nov 27, 2008 | Washing Machines
There is an odor after the cloths are washed
You have a build up inside the washer. When it gets wet, it smells. When it dries out, the smell goes away. To solve this, first use 3 tables (one package) of AhFresh, or washer magic, or whirlaway, set washer on tub clean cycle if you have that cycle, or if not, use the hottest and longest cycle you have. Run cycle with no clothes. Now, to prevent this from reoccurring, make sure you use only ONE TABLESPOON of detergent or less per cycle, and only ONE TEASPOON of fabric softener per cycle if you use it. These washers use only a very small amount of water per cycle, and you must adjust additives accordingly to prevent odor and other problems. This is the number one problem people have with their front loading machines, and is 100% preventable! NOTE: You probably have soap residue left in your clothes. Try washing them with no soap once with to see if you get any suds in washer. You should see none if there isn't any remaining residue. Bath towels are usually just used to soak up clean water off your clean body. Don't use soap when you wash them. They don't need it.
Oct 14, 2008 | LG Washing Machines
Slimmy scum left in bottom of washing machine after use
I posted this for someone with a similar complaint:
You can try a product called Affresh it's supposed to work quite well to maintian a clean washer. If you already have a smelly washer you should run a few cycles using Affresh. You also want to make sure you're using HE soap (it will have an HE oval shaped logo on the detergent bottle). If you're not soap residue will build up in the machine and start to smell.
Oct 05, 2008 | Washing Machines
Miele Touchtronic W1113 Washing Machine Logo
141 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
