Question about Uniden BC80XLT Handheld Scanner
Bc-100xl antenna replacement
I replaced a broken antenna on my bc-100xl with an 800MHz antenna and can't get any reception. Is this antenna compatible with my old dog?
  • free2andrew0 Jan 02, 2009
    it want pick up anything
The solder joint had broken loose from the positive post on the bnc jack....Antenna works but not on frequencies below 230 MHz....I'm still in the dark as to the compatibility of this antenna with this old low frequency unit....oicu812
Posted on Oct 05, 2008
1996 Toyota Camry. Need to replace broken antenna to get radio reception. Is this replaceable?
You can replace the whole assembly. It could be catered from junk yard, new Toyota parts store or car radio shops. After market antennas are also available which could be put to work after a little effort.
Apr 14, 2014 | 1996 Toyota Camry
I took my 2006 Trailblazer through the car wash and the antenna broke off. I have replaced the antenna, antenna mount and cable that leads to the radio. If I'm in the bigger town where I live radio...
Did you replace the antennea with the EXACT same one,or did you get an aftermarket one ? Did you replace/reinstall the rubber/plasitic gasket that sit's under the base where the antennea mount's on the truck ? If you answered yes to ALL of these question's,then your problem lie's in the cable itself. Be sure that you have the CORRECT one (cable) because where the cable connect's to the antennea there can be no play (looseness) or you WON'T get the proper signal.
Mar 28, 2011 | Chevrolet TrailBlazer Cars & Trucks
I am having very poor FM reception with my Bose Radio wave system. Is there an external antenna that can be attached?
The power cord is the antenna and it should be stretched out straight for best possible reception. You could experiment with re-orienting the Bose, too.
There is a threaded 75-ohm coaxial FM External connector. You could probably get a compatible FM antenna at an electronics store.
See the manual, Page 10
Dec 25, 2010 | Bose Wave Radio
The FM antenna is insufficient. I there a way to improve reception? Another antenna that will fit?
To improve reception, use a 75 Ohm outdoor antenna instead of an indoor antenna. Disconnect the indoor antenna before replacing it with an outdoor antenna.
Dec 14, 2010 | Insignia 200W Stereo Receiver
No gps signal on my tomtom one
the antenna is the cause if the gps is not having signal or reception.
Check the antenna is broken or well fixed. If not, you will have to replace the antenna.
Take care.
Jul 21, 2010 | Tomtom ONE XL GPS
Poor reception
Usually has to do with the antenna. Could be broken or loose whip, shield is broken underneath base. If the antenna checks out then you may need to have the radio calibrated or replaced.
Nov 11, 2009 | 2001 Chevrolet Impala
Lost radio reception in 1991 Chevy Silverado
IT IS THE ANTENNA WIRE THAT RUNS FROM THE ACTUAL ANTENNA MOUNTED ON YOUR TRUCK TO THE BACK OF YOUR RADIO.THIS WIRE IS POSSIBLY BROKEN OR CORRODED.REPLACE THIS WIRE OR RUN A COMPLETELY NEW ONE.
Aug 01, 2009 | Car Audio & Video
No audio output from a Uniden Bearcat BC-100XL Scanner
does the speaker have static when you open the squelch?
Mar 27, 2009 | Uniden Radio Communications
Uniden BC80XLT Handheld Scanner Logo
299 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
