Question about Sanyo DS20425 20" TV
My Sanyo DS20424 comes on and then quickly turns off
I can press the power button three times and the TV comes on and quickly turns off. If I unplug the TV for 5-10 seconds, I can then turn it on three times as above. This is repeatable.
The manual's "Helpful Hints" states -
1. Problem: TV turns off automatically
2. Check these conditions: Check signal (Cable/Ant.) connections; Power surge feature
3. Try these solutions: Press POWER key; The sleep button may have been set; Unplug TV momentarily
Thank you.
Please note that is a Sanyo DS20424, not a DS20425.
  • 4 more comments
  • Anonymous Oct 18, 2008
    I have the same problem with the DS20424. I was playing XBOX 360 on it and it just turned off. I can turn it on three times every time i unplug it but it will not stay on. I don't see a picture, just a black screen for maybe 5 seconds.
  • Anonymous Oct 27, 2008
    My Sanyo DS20425 just started doing the same exact thing. Haven't had the thing on for more than 20 hours since I've owned it, purchased brand new. Turn it on, attempts to come on, one second later shuts off. Will do this 3 times, then will not come on at all until unplugged and left alone for a few minutes.
  • dorynmatts Nov 26, 2008
    my sanyo DS20424 comes on then turns off quickly but doesn't even show any thing on screen.I can only tell its turned on by the sound
  • Anonymous Dec 26, 2008
    Same thing here
  • heckflan May 13, 2009
    the tv comes on and goes right back off its a sanyo 20"
  • pmparker458 May 18, 2009
    I have the same problem with my Sanyo.. I turn it on sound comes on picture just lights up and it switches off. It seems to turn off quicker on the next 2 attempts then it will not turn on at all. I unplug it and replug it and it is the same game all over again. Shouldn't Sanyo fix these through a recall? It appears many people are suffering from the same problems and that is the ones who have searched for answers others either took their sets to shops back to the store or chunked them..
  • 556 Answers
SOURCE: Stuck on Channel searching!!!
the problem is we have no cable-none at all. The tv is used only for playing DVD's. solution check dvd to tv wire or socket if it is ok then play dvd in another tv if it works fine then problem in tv. for that check tv tuner & its circuit for loose. check tuner itself
Posted on Sep 23, 2007
rey jr
  • 149 Answers
SOURCE: TV SHUTDOWN
hi there, there is a power supply section problem, do some test, automatic shutdown means a power supply section problem. ty
Posted on Jan 10, 2008
  • 79 Answers
SOURCE: Sanyo DS24205 24'' TV Not Recieving Signals.
Ok, cable connected is good. Can you move tv to another connection or run another cable from a working source. Maybe go into setup of tv and check input.
Posted on Nov 17, 2008
rjdadio
  • 8 Answers
SOURCE: Sanyo 24" flat DS24425 suddenly turned off, won't turn on
Solution to the won't turn on or turns on and turns off in 3 seconds thing...as my Ds24425 did.
First thing is very important...unplug the TV and let it set for 24 hours before you proceed.
The voltages inside a TV are EXTREMELY HIGH and LETHAL....so proceed with caution!
Place the set face down on a towel on a table and remove the back cover....hex screws around the perimeter and 1 phillips screw near the inputs.
The main board will slide up and out. unplug the degausing coil "white plug with two wires" and the speakers connector. This will make it easier to turn the board and take a look.
What I found with mine was a bad electrolytic capacitor. You can identify I bad cap "capacitor" by examining the tops of each one for bulging or signs of overheating "melted or bubbled plastic covering." The cap in question was C626 with a value of 1000uf, 16volt. I replaced with a 1000uf, 35volt and it works perfectly. The cap is located about center of the board. Carefully unsolder the cap and remove, make sure to install the new cap with the proper polarity...the board is marked with a dot indicating the negative lead of the cap.
Be sure to reattach the white plug and speakers connector and slide the board back into the plastic grooves. Then replace the back cover and test. Good luck! ...Daddio
Posted on May 24, 2009
SOURCE: My Sanyo TV Model number DS20425 will not stay on.
look for d482 to be shorted if it is ecg 552 will replace and r482 will be open too iused a one ohm 1 wat res to replace so far it working just fine
Posted on Dec 04, 2009
How to reset lamp w/o remote panasonic pt-52lcx16
Instructions
    • 1 Pressicon1.png the "Power" button on the TV remote control to turn the Panasonic rear-projector TV on and display a picture on the screen.
    • 2 Press the "Menu" button. The "Main Menu" will appear on the screen. Press the "Option" button.
    • 3 Press the "Enter" button. The "Optional Menu" screen will appear. Press the button to select "Lamp Runtime."
    • 4 Press the "Enter" button and hold it for about three seconds. The "Lamp Runtime" will change to display "Time Reset (Powericon1.png Off)."
    • 5 Press the "Power" button to turn the TV to the off position.
    • 6 Unplug the power cord from the electrical socket. Wait about one minute and plug the TV into the electrical socket
Read more: http://www.ehow.com/how_7201809_reset-lamp-timer-panasonic.html#ixzz33LeXpAsl
Jun 01, 2014 | Toshiba 37WLT66 37 in. LCD Television
Sanyotv com
Sanyo TV Service Menu Method 1
1.Unplug the power cable.
2.Press and hold the {MUTE} button on the remote control while plugging the power cable back into the outlet.
3.Keep pressing the {MUTE} button until the TV powers on with the Service Menu displayed.
4.Use the {CH+} {CH-} buttons to select menus.
5.Use the {VOL+} {VOL -} buttons to change settings.
6.Some menus might have sub-addresses. Use the numeric buttons {0} to {7} to adjust sub-item data.
7.Press the {MENU} button or turn the TV off to exit.
Sanyo TV Service Menu Method 2
2.Press and hold the {VOL -} button on the TV while plugging the power cable back into the outlet.
3.Keep pressing the {VOL -} button until the TV powers on with the Service Menu displayed.
Sanyo Projector Service Menu Method 1
Factory Menu Access
1.Press and hold the {SELECT} and {INPUT} buttons on the Projector at the same time for about 10 seconds.
2.The Factory Menu will be displayed.
Service Menu Access
1.Press and hold the {MENU} and {INPUT} buttons on the Projector at the same time for about 10 seconds.
2.The Service Menu will be displayed.
Use the {UP} {DOWN} {LEFT} {RIGHT} buttons to move through menus and change values.
To exit, turn the Projector Off.
Sanyo Projector Service Menu Method 2
1.Press & hold the {MENU} button on the Projector for about 10 seconds.
3.Use the {UP} {DOWN} {LEFT} {RIGHT} buttons to move through menus and change values.
4.To exit, turn the Projector Off.
Jul 20, 2013 | Televison & Video
My sanyo modle DS20424 has sound but not picture. We have DISH and their info shows up on the tv when the satelite is on, just no picture. Help??
I would first see if set works with a DVD etc directly hooked to one of the rear audio/video inputs.
If so I would next unplug the dish box and wait and then power it up again to see if it will reboot and cure this issue--you can also contact them....
If getting the on screen Menu but nothing else it is either a signal issue or a problem in the set---If using a receiver also reboot it as well.
May 21, 2012 | Sanyo Televison & Video
I need a code to program a remote for a sanyo tv
all you need to do is press the code search button until the red light is on then press tv button...then point the remote at the tv and continue to press the power button until your tv turns on/off...then press enter. Be patient...it may take any wear from 2 or three clicks up to 100 clicks....but it will eventually operate your television....be careful though...if you press the power button even 1 more time after it turns your tv on or off...you will have to start all over....Good luck! and if this doesnt work..you can always buy a universal remote from any department store..some are as cheep as 5.00. and they all come with program guides.
Nov 03, 2011 | Sanyo DP42849 42 in. HDTV
Remote not active with the tv
unessr
I have provided instructions on how you can program your remote to your TV. Without knowing the brand TV you have, I have provided a link with the codes you can try.
Program to TV:
  • Remotes: Basic (Television Only)
    1. Turn the Television On.
    2. Press and hold the TV Power button for three seconds until the LED flashes.
    3. Enter the three-digit code using the buttons on the number pad.
    4. Press OK. Note: The LED will flash three times.
    5. Test functionality with the TV.
    6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Power Scan:
  • Remote: Basic Remote (Television Only)
    3. Press and release the TV Power button.
    4. Press and release the Up or Down Arrow on the remote until the television turns off.
    5. After the television turns off, press and release the OK button.
    6. Test functionality with the TV.
    7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
The link for the remote codes are at the bottom of the page. Select your receiver type and then your TV brand to get the codes.
http://www.dishnetwork.com/SupportSection/remote-setup
I hope this helps.
Ray Calo
DISH Network
Apr 16, 2011 | DISH Network IR Remote Control
I have dish network and an apex 1225 dvd player. i do not have a remote for the dvd player. i do however have a dish network platinum remote control. i am in need of the code to link this remote control to...
Try the steps below these processes are called a power scans, there is a different type for any equipment needed. This should take 5-6 minutes per item to program.
For DVD/VCR's:
1.) Press and hold the correct VCR/DVD button (about six seconds) until all mode button backlights come on, then release.
2.) Press 222 pound (#) then record three times.
3.) With the desired equipment on, press and hold the VCR/DVD button until all mode button backlights illuminate (about 3 seconds), then release.
4.) Press and release the Power button.
5.) Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
6.) Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
For TV's:
POWER SCAN
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
For any other equipment:
Power Scan AUX
1.) With the desired equipment on, press and hold the correct AUX button until all mode button backlights illuminate (about 3 seconds), then release.
2.) press 0 for a TV, press 1 for a VCR/DVD, press 2 for any other device, then press *.
Press and release the large red Power button.
3.) Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
With any of these methods verify the code works by trying several different functions for that equipment.
Daniel Busa
DISH Network
Customer Service
Mar 20, 2011 | Apex Digital AD-1225 DVD Player
WHAT IS CODE FOR TV SANYO?
Hello
If you wants to get into the service mode of Sanyo TV. do one moung the folloing procedure. If you are in need of universal remote code for Sanyo follow the extented solution. Your post is not clear, that is why I answers for both.
To get in to the service mode adjustments
[1]
* Press and hold the {MUTE} button on the remote control while plugging the power cable back into the outlet.
* Keep pressing the {MUTE} button until the TV powers on with the Service Menu displayed.
* Use the {CH+} {CH-} buttons to select menus.
* Use the {VOL+} {VOL -} buttons to change settings.
* Some menus might have sub-addresses. Use the numeric buttons {0} to {7} to adjust sub-item data.
* Press the {MENU} button or turn the TV off to exit.
[OR]
* Press and hold the {VOL -} button on the TV
* Keep pressing the {VOL -} button until
Universal remote codes:
Three digit universal remote code for sanyo are:
004/ 013/ 049/ 108/ 110/ 180/ 209
Four digit universal remote code for Sanyo are:
0049 0097 0110 0004 0268 0012 0108 0180
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
OK.
Jan 25, 2011 | Televison & Video
The book shows 0154 as the code for my sanyo tv ,it does not work .
Hello
If you are looking for its service menu, there is no code, but some doings is necessary as follows.
Two proceedings are given. One amoung them will surely open your TV to service mode adjustments.
To enter the service menu do the following. Most of the sanyo sets will get positve results with this.
OR
* Unplug the power cable.
OK
Jan 24, 2011 | Sanyo Televison & Video
Photosmart c6180 repeatedly turns off about every 10 seconds
Solution one: Press and quickly release the Power button Follow these steps to turn on the product correctly.
  1. Remove any memory cards or USB drives from the HP product.
  2. Press, and then quickly release the Power button (c01602202.gif ) to start a Power On/Off cycle. Do not hold down the button . Figure 1: Press and quickly release the Power button c01941590.gif Illustration of pressing and releasing the power button
c01733891.gif If you press and hold the Power button too long, the product might turn on and then turn off without restarting. The product might also appear to be turned off in Powersave mode. In either case, press, and then quickly release the Power button (c01602202.gif ) to turn on the product. Solution two: Check the electrical connections and outlet Follow these steps to make sure that all the power systems work correctly.
  1. Unplug the power cord from the electrical outlet, or the power strip or surge suppressor. Power module Power cord c00745315.gif Illustration: Power module c00057913.jpg Illustration: Power cord
    NOTE: The power cord detaches from the power module. The term power supply refers to both the power module and the power cord.
  2. Carefully inspect the power supply for visible damage. c01733891.gif If the power cord or power module shows any damage, contact HP to replace the power supply.
  3. Disconnect the power supply from the back of the product.
  4. Wait at least 30 seconds, and then plug the disconnected power supply into an electrical outlet. Do not use a power strip or surge suppressor. c01733891.gif If the green light (LED) on the power supply does not light up, contact HP to replace the power supply.
  5. Reconnect the power supply to the product.
  6. Press and quickly release the Power button (c01602202.gif ) to turn on the product.
  7. If the product still does not turn on, connect the product to an electrical outlet in another room, and then quickly press and release the Power button (c01602202.gif ) to turn on the product.
    • If the product turns on , the electrical outlet in the original room caused the issue.
    • If the product still does not turn on , continue with the next solution.
Solution three: Make sure that other devices are not causing the issue Follow these steps to make sure that devices plugged into the HP product are not causing the problem
  1. If the parallel and universal serial bus (USB) ports of the HP product have other devices plugged into them, unplug those devices.
  2. Press the Power button (c00636182.gif ) to turn on the HP product.
  3. Monitor the HP product to see if it turns off again.
  • If these steps resolved the issue , there is no need to continue troubleshooting.
  • If the issue persists , see the next step.
Solution four: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 21, 2010 | HP Photosmart C6180 All-In-One InkJet...
Mitsubishi projection tv picture and sound turn off but the power button remains on with no picture or sound turn tv off real quick and then back on and works for 2 mins then turns off again what could be...
Here's the basic troubleshooting:
  1. Make sure that no front panel buttons are inadvertently stuck in an "engaged" position.
  2. Disconnect ALL devices from the TV.
  3. Press the SYSTEM RESET button and hold for 10 seconds. Proceed if the problem still exist.
  4. Press and hold POWER and MENU buttons simultaneously for 20 seconds. Proceed if the problem still exist.
  5. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours.
  6. If it still shuts down, press the DEVICE and MENU buttons on the front panel simultaneously and hold it for 5 seconds to activate the Error Code Operational Check. The status LED indicator will then flash denoting a two digit code.
  7. Count the number of flashes then pauses for about a half second then flashes again. The first number of flashes indicates the first digit of the error code and the second number of flashes indicates the second digit of the code. For example, if the error code is "35", the LED will flash 3 times, pauses, then flashes 5 times. The error code is repeated a total of 5 times.
Please let me know the code you got and I'll tell where the problem lies and how to fix it.
Dec 01, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Sanyo DS20425 20" TV Logo
2,231 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
