Philips DVD player: though I push the open bottom hardly, there is no response at all and the the tray does not open.
Buy a new one.
Posted on Oct 05, 2008
My vizio blue ray player will not open to insert disk though I can hear it trying
Look at the bottom of the unit, just below where the tray opens, look for a small hole. If its there, that's the manual release. Straighten a paperclip and push it into the small hole to release the tray lock.
Nov 09, 2014 | Televison & Video
Tip
How can you access the rubber belt when the tray is closed? I Can't ! I had the...
1)just open the player
2)remove the rubber belt connecting the dc motor
3)you can open the disc tray now
4)if there are any dust particles or obstacles in the door way just clear them up by using the cloth(dry cloth preferred)
5)if you have any greasy material like vaseline,oil,etc then just put that in the door for easy movement of the disc tray
6)if needed change the rubber belt which is connecting the dc motor
7) just reconnect the rubber belt again and then just fit all screws that s all
what s more your player s disc tray will start ejecting like the previous how you were using..
any doubts you can reply me
i am always here to assist you
thank you
bye
on May 02, 2009 | Samsung DVD-V4600 DVD Player/VCR
DVD ' s tray won't open when pres OPEN, DVD is inside
There are little gears to open the tray with a little rubber belt that drives it you should be able to open door and pull on tray to get disk out if not unplug it take top off push tray out Cheapper to replace player than to fix but little flap should pull down grab tray and pull
Feb 21, 2013 | RCA DRC247N DVD Player
The disc is stuck up in dvd player how can i open it up to remove the disc thanks
Remove DVD player from the mains. Look for the slotted opening covered with plastic cover at the bottom front, which can be opened easily by hand without much force. After opening it put a small flat screwdriver (locate the stud inside) & move it so that the tray will just open. Then pull the tray & remove your CD.
Aug 13, 2011 | Philips DVP3982 DVD Player
Philips DVP 5992 DVD player disk tray opens without a disk
it think you should open the unit up.get the cd.then try to play it again.
May 18, 2009 | Philips DVP5990 DVD Player
E1 (rear) error. DVD tray will not open.
there might be a possibility that as soon as the tray closed the dvd shifted inside the machine. the dvd is stuck yes which means that the tray wont open because the dvd is blocking the gear turning. if so you are going to have to take it to your Dealership to open up the player and remove the disk. you can try it yourself but it's not recommended. tray gears will have to be tested to see if the tray will open once the disk is out though
Mar 29, 2009 | Philips Magnavox DVD/VCR Dual Player
Philips dvdr3430v dvdrecorder/vcr combo -hacked into to make multi regional 2yrs ago now buttons on machine not responding to touch only works with the remote, therefore cannot open disc tray. please help
Keep pushing the "STOP" button on the Remote-controller will open the tray. This works mostly on all Philips DVD's. I tried on my recorder, it works.
Have fun!
Mar 07, 2009 | Philips DVDR3430V DVD Recorder/VCR
Just need to get disc out...
Looking at the front, flip the unit over. Near the top middle you will see a narrow ****.You will see a white piece of plastic under the ****. If you have a dvd tray pinhole tool, use the bent end and insert it into the **** and use it to push the plastic piece to the left and if you push it far enough, the tray should open. I also used a very small screwdriver at an angle to open the tray.
Dec 25, 2008 | Philips DVP642 DVD Player
I cannot open the DVD drawer on my Philips DVDR3480 DVD RECORDER – it just won’t open? The screen display just keeps saying ‘Error’. Any help is appreciated.
I have two of these dvd recorders and both have the exact same problem where the drive won't open. It opens fine when there is a disc in the tray. So I just unscrewed the cover, press the white part which would be over the center of the disc as it's trying to open, it should then open. Then just make sure there is always disc left in the tray.
Nov 26, 2008 | Philips Televison & Video
DVD player tray will not open
Maybe this will help someone look in the right direction. A friend gave me a KISS DP-1000 with the same problem: The TV showed the 'Eject' graphic, and nothing happened. There is no little hole that you can poke a paperclip in, like on a PC. I opened the player, and still could not find anything. Then I googled the model of the actual tray mechanism (DSL-710A). The datasheet said that it did have an 'emergency eject' machanism, operated by a Philips screw at the bottom of the tray. There are no holes at the bottom of the DP-1000, only a dimple that dead-ends. I broke through the bottom of the dimple with a small, flat, screwdriver, then enlarged the hole. I felt around with a medium Philips and it fitted into something. I twisted gently, and the tray popped out. Why KISS covered the 'emergency eject' screw is anybody's guess, but I am not buying any of their products.
Feb 25, 2008 | Televison & Video
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
