Aprilaire 600 Humidifier Logo
Posted on Oct 04, 2008
Reinstalling drain spout
I removed the drain spout from the scale control insert, and after cleaning everyting can't seem to get it back in. I'm afraid to force it.
Thanks for any help
Anonymous
Level 1:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Nov 06, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
15
Questions
Helped
3270
Points
38
GO TO THE MANUFACTURERS WB SITE!!!!!!!!!!!!!!
What is proper procedure for running vinegar through my Hankscraft cool mist humidified?
Not sure why you would want to. Vinegar is typically used to remove calcium scale that remains after a heating element or electrodes boil off water. The Hankscraft 240 doesn't boil the water off. All the minerals in the water go out the spout with the mist.
How to clean sunbeam humidifier swm5250
CLEANING AND MAINTENANCE INSTRUCTIONS (from the manual):
The following maintenance procedures must be routinely followed in order to ensure proper, efficient operation of your humidifier. The unit WILL NOT WORK CORRECTLY if it is not cleaned properly.
When the unit is in use, daily and weekly maintenance is recommended. Regular weekly cleaning prevents scale buildup on the heating element and base. It also prevents micro-organisms from growing on the base. This ensures that maximum efficiency will be achieved.
We cannot over-emphasize how essential proper cleaning is to the maintenance and continued use of your unit and to the the avoidance of algae or bacteria build-up.
DAILY MAINTENANCE
Allow to cool before maintenance.
1. Before cleaning, set the control to OFF (O) position and unplug the unit from the electrical outlet.
2. Remove the water tank then unlock the misting chamber by rotating the safety lock towards the front of the unit. Lift mist chamber from the unit's base.
3. Empty water and minerals from the base and place in the top rack of the dishwasher. This will remove any sediment and dirt that has accumulated in the base.
NOTE: It is imperative that the base is cleaned properly. The base is dishwasher safe (top rack ONLY) for easy cleaning.
4. Wipe the heating element clean with a soft cloth after it has had a chance to cool.
5. Replace misting chamber and engage safety lock. The Electronic Thermal Control Heating element is lined with a coating that is designed to provide the easiest cleaning and prolong the operating efficiency of the humidifier. DO NOT use any metal or hard objects to clean the Heating Element. Never use detergents, gasoline, kerosene, glass cleaner, furniture polish, paint thinner or other household solvents to clean any part of the humidifier.
WEEKLY MAINTENANCE
Remove Scale: Allow to cool before maintenance.
1. Repeat steps 1-5 in the Daily Maintenance section.
2. Clean the tray by partially filling the base with one 8 oz. cup of undiluted white vinegar. Let solution stand 20 minutes, cleaning all interior surfaces with a soft brush. Dampen a cloth with undiluted white vinegar and wipe out entire base to remove scale.
3. Rinse with clean warm water to remove scale and the white vinegar solution before beginning to disinfect the tank.
Disinfect Tank:
1. Fill tank with 1/2 teaspoon of chlorine bleach and 1/2 gallon of water.
2. Let the solution stand for 20 minutes, swishing every few minutes. Wet all surfaces.
3. Empty the tank after 20 minutes, and rinse well with water until the bleach smell is gone. Dry with a clean cloth of paper towel.
4. Refill the water tank with cool water; replace the housing and water tank. Repeal ALL Operating Instructions.
I have a Whirlpool AD70U dehumidifier with type 3 controls. I have the fan set to auto and the humidity to normal. The unit drains into a floor drain. It seems dry in my basement yet the fan seems to run...
If it's set for Continuous Mode the fan will run all the time. It does so, in an effort to keep recycling the air. Once it senses a rise in humidity, the compressor turns ON. Check the settings, to be sure it's where you think. Also, check and clean the air filter, if necessary. Before removing the filter, be sure to turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet. If you wash the filter, it most be completely dry, before reinstalling it. Do Not operate the unit without the air intake filter installed.
Make sure you are maintaining at least 12" - 18" clear air space around the entire unit.
To further assist you, in case you have misplaced your Owner's Manual. I have included a link to it, that you can download and print for future reference.
https://www.whirlpool.com/digitalassets/MLPDF/Use%20and%20Care%20Guide%20-%201188826.pdf
I hope this helped you to further troubleshoot and solve the problem.
Have aprilaire #760 ,changed water panel, and turned furnace on and water started pouring out of the bottom of furnce? lots of water---
Typically, we find that the most common reason that you start to see leaking from the humidifier is that the water panel is not changed frequently enough. We do recommend that the water panel be changed once every humidifying season. We find a majority of our customers do this maintenance typically at the start of the humidifying season.
Here are the things to check when troubleshooting a power humidifier, which is leaking:
1.Position Of Unit On Plenum
Is the unit level (let to right)?
Is it plumb (front to back)?
2.Feed Tube
Is the Feed Tube tightened or is there a crack in the tube?
3.Position Of Scale control insert-
Is the base of the scale control insert sitting firmly in the drain spud at the base of the housing?
Does the bottom of the scale control insert have a taper to it to direct water to the drain spud?
Is the Scale control insert positioned correctly? The scale control insert has a front and a back. The back of the water distribution tray has an indentation in it to allow for clearance of the nozzle, which is attached to the top of the base. If reversed, and forced into place, the water distribution tray will break off the nozzle attached to the water feed tube and potentially the housing, causing water to leak
4.Water Panel Assembly-
Are there aluminum strands hanging out of the scale control insert?
Is there a gap between the top of the water panel and the water distribution tray for air to go through?
Is the colored dot on the water panel, up?
Is there a consistent coating on the Water panel, or are there shinny spots or clumps of coating?
5.Water Entrainment (Water Blowing out of the Humidifier)-
Are there signs of entrainment? Mineral build-up on fan blade, shroud, inside of cover?
Is the static pressure in the plenum over .4w.c.? If so, entrainment and leaking could occur.
6.Missing Orifice
If there is no orifice in the unit, the water entering the system could flood the panel. To check
for proper water flow, a quart jar should fill at the drain line in about 2 ½ minutes for a red or blue orifice, 5 minutes for a white or yellow orifice.
7.Drain line-
Is the drain line plugged?
Does it have a good downward slope?
Is it teed with any other drain lines?
If the above items do not resolve the existing leaking we would recommend contacting the customer service line at 800-334-6011 for further technical support.
Regards,
Tracey Hadju
Customer Service Specialist
Research Products Corporation
www.aprilaire.com
Fan motor seems to be running backwards. Installed in 1999.Always maintaned. Overall worked OK until this past year. Many problems with water leakage. When I opened and checked fan direction, it was moving...
The fan on the model 700 does rotate backwards compared to your typical fan operation. This fan will pull air from the duct verses pushing air into the duct. There are several things that may cause your humidifier to leak. The most known reason for leaking is the water panel/filter is not being changed frequently enough which should be at least once every heating season. You also want to confirm that you are utilizing an authentic Aprilaire water panel.
  • Is the Feed Tube tightened or is there a crack in the tube?
· Is the base of the scale control insert sitting firmly in the drain spud at the base of the housing?
· Does the bottom of the scale control insert have a taper to it to direct water to the drain spud?
· Is the Scale control insert positioned correctly? The scale control insert has a front and a back. The back of the water distribution tray has an indentation in it to allow for clearance of the nozzle, which is attached to the top of the base. If reversed, and forced into place, the water distribution tray will break off the nozzle attached to the water feed tube and potentially the housing, causing water to leak
· Is there a gap between the top of the water panel and the water distribution tray for air to go through?
· Is the colored dot on the water panel, up?
· Are there signs of entrainment? Mineral build-up on fan blade, shroud, inside of cover?
Steam not released through spout but trapped
is the spout clogged? Try running vinegar through it, CLR is a good product, but may stay the plastic, if not eat it, so I recommend vinegar to clean the deposits that plug things up, it may smell a bit, but usually works. Once cleaned, use distilled water to keep it from happening again, or just clean regularly with vinegar.
1helpful
2answers
When furnace cycles on the humidifier overflow spout has a tremendous flow of water that pours all over basement floor. Is there a valve problem ? I can connect a drain tube from this overflow spout to the...
If the water stops when the heater is not running then the humidifier is working fine. I know it seems like alot of water but that's how it's designed.
2helpful
2answers
I need to know how to clean the base of my humidifier.
ask at http://manualfox.com/link/sunbeam.htm
They will find it for you.
4helpful
Humidifier does not reset
According to Holmes, one of the causes of the Reset light staying on is scale buildup on the heating element.
2. Clean the base by partially filling the base with one
8-oz cup of undiluted white vinegar. Let solution stand
the tank.
it has had chance to cool.
If the scale has really built up it might take longer than 20 mins for the vinegar to get rid of it and you might need to refresh with new vinegar.
Your Manual can be found at this link:
http://www.holmesproducts.com/Manuals/Holmes/HM5250-UC_English.pdf
Good Luck.
2helpful
Need to clean the filter
http://homeappliance.manualsonline.com/manuals/mfg/vicks/v3100.html
This is the link to your manual.
Daily Maintenance
1.
Turn switch to OFF position and unplug the cord from wall outlet.
2. Lift the Water Tank from Base. Carefully remove the Water Tray from the base being
careful not to damage the delicate Wicking Filter. Empty excess water from the Water Tray
without removing the Wicking Filter. Remove the Tank Cap and drain any water from the
Water Tank. Rinse the Water Tank with lukewarm water after each use. Wipe accessible
surfaces of the Water Tank and Water Tray clean with a soft, damp cloth.
3. Do not immerse the Base in water. For storage, wipe dry with a soft, clean cloth. Keep
water away from the Air Outlet.
4. Do not leave water in the Water Tank or Water Tray when unit is not in use as it may
result in the build up of mineral deposits and bacteria that can inhibit the output
efficiency of the humidifier. Please note that if water remains in the Water Tank for more
than a day or two, bacterial growth is possible.
5. Replace Water Tray with Wicking Filter. Then replace the Tank. Humidifier is now ready for
use.
Weekly Maintenance
Removing Scale
1.
Remove the Water Tank and empty any remaining water from the Water Tank.
2. Turn switch to the ON position, either low or high speed, and operate Humidifier until the
Wicking Filter is thoroughly dry.
3. Turn switch to the OFF position and unplug the cord from wall outlet.
4. Remove Wicking Filter from the Water Tray by carefully lifting straight up taking care not to
tear filter.
5. Remove the Water Tray from the Base. Fill Water Tray with undiluted white vinegar. Let
stand for 20 minutes.
6. Dampen soft, clean cloth or sponge with undiluted white vinegar and wipe out Water Tray
to remove scale. Do not use soap, detergents or abrasive cleaners.
7. Rinse the Water Tray thoroughly in clean warm water or put in top shelf of dishwasher to
remove scale and vinegar before disinfecting the Water Tray.
Disinfecting the Water Tray and Tank
1.
Fill tank with 1 teaspoon of household bleach in 1 gallon of water. Let stand twenty (20)
minutes, shaking vigorously every few minutes, drain and rinse with clean water until the
bleach smell is gone. Dry with a clean cloth or paper towel.
2. Wipe the Water Tray with a soft cloth dampened in the bleach and water solution. Rinse
the Water Tray thoroughly or place in dishwasher before proceeding.
3. Wipe all exterior surfaces of the Base with a soft, dry cloth. Do not immerse the Base in
water or use water to clean the base. An electric shock may result or the humidifier may
be damaged.
Hope this helps.
Good Luck.
Top Aprilaire Humidifiers Experts
Paul Carew
john h
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
