PICTURE TURNED PINKISH FOR A COUPLE OF MINUTES. i TURNED SET OFF FOR A FEW MINUTES. WHEN I TURNED IT BACK ON PICTURE COLOR WAS NORMAL BUT THE HD IS NOT CONSTENTLY CLEAR- SOLIDS ARE NOW FUZZY
  • 10,594 Answers
This seems some lose connections or cold solder joints in TV.
Please mention tv model and brand to help you out.
Posted on Oct 04, 2008
Power turns off and on every few minutes
This model had some odd problems--answers to a few questions might suggest what is wrong
When set is on does brightness come up very slow or is somewhat darker when on?
that might indicate a lamp issue----set will detect if screen not bright enough etc.
With set on is picture normal? (no unusual color in back ground on screen or such? set is prone to light engine failures--the engine communicates with other parts of the set--something not right it shuts down.
My final thought is a power supply problem----this is not a easy set to get apart to service or look for things---for the most part the entire front screen has to be removed to gain access to the boards. Note the lack of many rear screws on the unit.
Nov 07, 2012 | Hitachi 50V500 50 in. HD-Ready LCD...
The picture is like a milky white, we have tried resetting all channels but no good
Try this, unplug all cables from the set, switch off at the mains, wait a couple of minutes, then switch the power on, and turn on your set do not put any cables back in, you should get a snowy picture up when you turn it on as normal. if you do replace turn the set back off plug all of the cables back in and turn the set back as normal, you should have a normal picture. post back if you dont.
Feb 05, 2010 | LG 37LG30 37 in. LCD HDTV
Non-hd channels only. color is washed out with
try component cables and see if you get the same results.
Oct 24, 2009 | Panasonic Televison & Video
I have a samsung2333hd and want to connect a dvd player using the connections marked pr(red) pb(blue) y (green) when i connect them all i get a redish pink screen then when i connect two of them i get...
OK no problem here. I can help. First reconnect the DVD Player to the tv using the Compoment cables. Match Green to Green,Red to Red and Blue to Blue.. If this is done correctly then you will have normal looking picture. If the picture looks like it is missing the RED color then switch both Red cables. The pix should look normal. Then connect the RED and White audio cables to the audio inputs . Now the Pinkish color is a result of the DVD Player not being set to the "Progressive" setting in the DVD Player Menu. It will help to connect a set of COMPOSITE cables from the DVD Player to the TV's Composite Input. Those are the Yellow,Red and White inputs on both the tv and the DVD Player. This will allow you to see the DVD player menu in case you cannot see the menu while in the Component input. The Pinkish picture should go to a Normal picture.
Jul 04, 2009 | Samsung Televison & Video
Plasma "warm up" is now up to 30 minutes and climbing
put a towel across the top of the tv so it can heat up faster and you will get your picture. be carefull!!
Jan 26, 2009 | Televison & Video
Picture loses all normal color & changes to snowy blues & greens
Not sure what causes it but it can be fixxed by your local repair guy, I just had mine fixxed for under a hundred bucks, he takes the back off and with a tiny screw driver adjust a few screws to near brand new perfect picture.. and it has been good ever since
Dec 01, 2008 | LG RU-52SZ30 52" Rear Projection...
Picture quality on PT-50LC14
clean out the housing (where the lamp is) the go through your menu and check the tv settings ie...color temp, picture, contrast, ect...try resetting it back to the default and go from there
Nov 09, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Picture looks like a Colored Negative
so, how can i fix this problem with my tv. the tv comes on but the colors look fuzzy..help!!
Oct 27, 2008 | Syntax Olevia 50" Rear Projection...
Philips 28PW6515-05 flat screen TV
You have a bad connection on the CRT board thats mounted on the end of the picture tube it sounds like, or the socket on that board that plugs into the TV set is intermittant or has a bad solder connection on it. Good Luck
Mar 27, 2007 | Philips 28PW6506 28" TV
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Electro Med Services...
