Question about Kitchen Ranges
Kitchenaid Microwave Bulb Replacement
Hello Master_Tech,
I see that you were able to help another DIY'er with replacing their microwave bulb. My microwave has to be pulled to access the bulb. Kitchenaid offered ZERO help with this. I can't figure out how to pull the microwave. If possible, please describe the procedure, and/or point me to the service manual that describes it.
Thanks very much for your help.
Best Regards,
Joe
  • Joe Redshirt Oct 04, 2008
    Sorry, I forgot to mention the model! It is a Kitchenaid KEMS308GSS0. The bulb is a Whirlpool 4375348.
    Thanks,
    Joe
I just replaced the bulb on my KEMS308GSS2 and it wasn't too difficult. The bulb was $36.45 delivered from A-1appliance.com.
To change the bulb first turn off the power, then remove the plastic grills above and below the microwave unit. The bottom grill comes out easily, but the upper grill has a flange which makes it difficult to reinstall unless the flange is sawed off or the control panel is partially removed. To remove the control panel open the lower oven door and remove the screw at the bottom of each trim piece. Remove the trim pieces and then the two screws securing the control panel. With the two grills removed take out the two screws below the microwave which hold it in place. carefully slide the microwave out about half way, remove the insulation pad over the bulb and replace the bulb.
Posted on Dec 10, 2008
KitchenAid KCMC155J 1000 Watts Convection / Microwave Oven - how to change the light bulbs - can this be done without having to call a tech?
Look for a small cover on the outside of the cabinet in the place where the bulb is. They are usually secured with a single *****. It is the only part of a microwave oven that is consumer serviceable! Remove the cover and unscrew the bulb, replace and refix the cover.
your manual is here but doesn't mention the bulb
http://www.manualslib.com/manual/88077/Kitchenaid-Kcmc155j.html#manual
KitchenAid KCMC155J Use Care Manual
Mar 11, 2013 | KitchenAid KCMC155J Convection/Microwave...
Replace the bulb on a kitchenaid kems377d
The installation guide for KEMS377D is from Whirlpool for KBMC140. Follow the instruction how to remove the microwave from the cabinet.
Feb 24, 2012 | KitchenAid KEMC377K Convection / Microwave...
How do you change the bulb in a Kitchenaid microwave Model KBMC140HSS03
Hello & Welcome to FixYa
To replace the light bulb first remove the screws located on the vent grill at the top of the microwave, tilt the grill back and then pull away to remove. After this open the light cover , you have to remove the screws so that you can discard the old light bulb and then replace it with a new one. Please get back to me if you have any other questions.
Kevin
Jun 10, 2011 | KitchenAid KBMC140HSS Convection/Microwave...
Burnt Bulb on Kitchenaid Micro KEMC378KBL04
Hello there if you go to the website for the manufacture of the microwave you will have a downloadable operators book..
Also just to let you know i just replaced my mother in laws and all i had to do was to remove the outside case and the bulb was on the top left side not hard at all the bulb cost me about 6 bucks now works well...
I hope this helps you out .
best regtards mike
Jul 20, 2009 | Microwave Ovens
Need to replace light bulb in kitchen aid microwave
KitchenAid wants $58 for the replacement bulb. I bought it for $1.99 from www.lightbulbsdirect.com and it works just fine. The Item number is Q5G412V. It is a halogen 5-watt, 12-volt bipen G-4. Replacing the bulb requires some dismantling of the microwave. At first I was nervous about removing so many parts to get to the bulb but in the end it really wasn't so bad. The only tool I needed was a Phillips screwdriver. I surfed the net a eventually found instructions left by a friendly Blogger that guided me through the whole process. KitchenAid engineers were so STUPID when they designed this microwave. It takes two hours to replace a bulb that should take 5 minutes. Oddly enough, replacing the bulb in the normal oven below the microwave oven is a piece of cake.
Jan 19, 2009 | KitchenAid KEMC308 Electric Double Oven
Kitchenaid microwave bulb
You can download the owner's manual and installation instructions here.
You can also download the parts manual here. It has handy exploded views. The bulb is shown on page 5 and is ref # 75.
You will need these instructions, because to replace the bulb, you will need to pull the microwave down from the wall mount and remove its cover.
Always unplug a microwave before removing or installing any bulbs.
And it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
If you don't find a replacement locally, check here.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Oct 05, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Microwave bulb replacement
The oven will need to come down from the wall so the outer cover can be taken off. Then you'll see the light socket(s).
It's recommend due to the weight and awkwardness of the oven that two people do this job.
If you don't still have your installation instructions, you can download them here, but you should use you full model number, as opposed to the base KEM378.
This uses a fairly common halogen bulb, but I'm not sure of the wattage. It should be marked on the bulb or on a tag near the reflector.
Aug 30, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Kitchenaid KBMC147HSS0 Bulb replacement
If it's the one that lights the cooktop, it's normally beneath the bottom cover.
In some cases, it's located in a compartment behind the grille that goes across the top of the unit.
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. It may help. It's at http://207.234.249.73/mwd/ge_lamp_replacement.jpg
Please let me know if that helps or not.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 29, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
LIght bulb burned out
I a Kitchen Aid Buit-in microwave (KEMC308KSS01) with the same problem - light went out. Can you send me the instructions on how to replace the bulb? Thank you! dlhamilton@comcast.net
Jan 23, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Kitchen Ranges Logo
270 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
