Question about McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK
39cc McCulloch chain saw
The saw has no power. I mixed new gas at 32:1 gas/oil mix and still can not get the saw to run right. If I feather the choke when it bogs down, it will keep running. It barely idles. If it is idling, and I hit the throttle it will bog out and I have to try to restart it again.
  • mrgoodwrench Oct 04, 2008
    I would love to see the carb adjustment instructions for this saw. It is a McCulloch MS1839AV. This would be of EXCELLENT assistance. Is the gas/oil mix correct at 32:1? Thanks
  • 42 Answers
I have the same exact saw as you and I was having the same troubles except I had to keep pumping the primer bulb to keep it running. I didn't want to go by a new saw because I knew I could fix it, as I am skilled in small engines, but have never actually taken a chainsaw apart. I dug into it and found that the fuel line that comes out of the side of the carburater and leads into the fuel tank with the fuel finlter on the end looked cracked a little. So i trimmed the end of it off and thought that it would work. It didn't! So I took it back apart (took the carb all the way out) and found that that fuel line was totally rotted underneath the carb and every time I pressed the primer bulb, fuel shot out of a large crack where the fuel line was bent. After I replaced that everything was running great. If you have any more problems, feel free to contact me. John
Posted on Mar 07, 2009
  • Mark
    Mark May 01, 2014
    I have a 39cc McCulloch chainsaw too and I have the same problems John describes. I have to keep pumping the primer bulb to keep it running. The fuel line looks fine. How can I test it? Can the carburetor be the problem? I adjusted the low an high speed fuel adjustment screws at the middle. Please help me with my problem Thank you
    Scholar:
  • 76 Answers
The issue sounds just like a carburetor problem. I had a saw that did the same exact thing, and found that I hadn't been adjusting the carburetor properly for years. I managed to find the instructions on-line, and then it ran like a dream, just every time I store it, I have to go back through the motions again.
Let me know if you need adjustment guidance and I will see if I can dig up anything.
Posted on Oct 04, 2008
  • J. May Oct 04, 2008
    I am sorry that I cannot be of better help. I could not find the exact manual, but here is a link to another owners manual that describes how to adjust the carb. on a different McCulloch chain saw.
    McCulloch
    -Manual">http://www.scribd.com/doc/3097717/CHAINS...McCulloch-Manual
    Generally, the gas/oil mixture would depend on the saw. I have seen up to 50:1 mixes. I know that if you have oil seepage through the muffler than the mixture is a little too oil lean (it is usually brown or green and it is the oil burning off). Actually 32:1 sounds about right. A friend of mine who owns a small engine shop told me that you always use good quality, high octane gas, a good mix, run a 2-cycle engine hard (no partial throttle squeezes), and never use mix that has sat up for a few months.
    Here is a local small engine shop in my area. The owner's name is Gary. He is very honest and knowledgeable. If you need further help, I am sure he can better direct you. His number is 501-771-6885 -Manual">http://www.scribd.com/doc/3097717/CHAINSAW-McCulloch-Manual
I am installing a new primer bulb and find I have 3 hoses 1 from the bulb to the carburator and one to the fuel tank . The third hose comes fron the fuel tank , where does that one go ?
Posted on Aug 25, 2009
Saw will run at idle (rough) but will immediately bog down at high speed.
is the chain sharp ? could the bar (chain rides on this) maybe be bent (even slightly) , could the auto oiler not be working ? loss of power issues that are not a fuel flow problem sometimes are these above , also I do assume that you have tried a new fuel filter , its inside the fuel tank on most models , one other thing , ive had some success using automotive fuel cleaner in saws before , a 50/50 mix of gas /cleaner is usually strong enough also don't forget the oil on 2 strokes , never run a two stroke without oil in the fuel
Aug 01, 2015 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Oil level in motor of 3200 mcculloch chainsaw
This a 2 cycle engine where fuel oil is mixed with the gasoline. The mix is 40:1. If you attempt to run straight gas in this engine you will destroy it as would using regular oil.
The oil tank on this saw is for the lubing the chain and needs topping off every so often as you use the saw so that the chain stays oiled.
With the original McCulloch manufacture being out business parts are very hard to come if you can even find them.
Dec 03, 2014 | McCulloch 3200 Bar & Clutch Cover
I mixed correct oil,gas, but still runs bad,acts like wants to bog out
Plugged air filter or exhaust,maybe?
Fuel restriction?
Nov 12, 2012 | Garden
Oil,gas mixture for a McCulloch 610 chain saw
Always use good quaility two stroke oil designed for use in chainsaws ( not out board motors ) and mix at 40-1, oil quaility has moved on greatly so it is acceptable to use less oil than was once needed.
Nov 10, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
The chain saw is brand new. It starts OK but after I make one cut it stalls (Every time).
Do you have the proper gas-oil mix? It should be 40:1, which is 3.2 oz of oil/synthetic oil to 1 gallon of fresh gasoline. Make sure you push in the choke after starting it. Also make sure the chain brake is off (chain should move freely by hand when the saw is TURNED OFF.) If gas mix is right, choke is turned off after starting and brake is off, take it back to the dealer/store.
Aug 29, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
What is the fuel/oil mix for a mcculloch 14inch chainsaw 2.0 cib?
If you use newer synthetic oil it covers a broad range of fuel/oil ratios with one mix. it will allow you to use one fuel mix for all your 2cycle equipment
Aug 22, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
New 18" Poulan Pro 42 cc saw, mixed up new gas
Don't use stabil. Use a modern synthetic saw oil (50:1 fuel to oil ratio) available at home centers, hardware stores, and saw dealers. Mix the oil and fuel in it's own container and be sure to shake the container thoroughly just before filling the tank each time to prevent oil starvation. If it becomes apparent that the carburetor adjustments are wrong, you will need to see your dealer for adjustment. Good luck!
Dec 18, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
XL UT # 10655A Serial # HL1490086 XL 2 Serial # 40152376 Recently bought these 2 saws and have gotten 3 answers for the gas/oil mix. Can you tell me what is the right mix??
Run what ever fuel/oil mix you are comfortable with. A run lean condition is most often caused by an undetected air leak leaning out the mixture to failure. A couple of ounces of 2-cycle oil will not prevent its occurrence. If an owners manual (OM - I tried) is ever located it likely says 32:1. Most modern saws recommend 50:1:
Oil Mix Ratio:
In the early to mid 90s Dolmar, Echo, efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear
Sep 18, 2010 | Homelite Garden
Fuel mix
Quick check with mfg (DAGS mcculloch) yields: 40:1 with their 2-stroke oil and 87 octane.
I've run one (with 14" bar) for years on same 50:1 mix I use in other saws with no problems- synthetic oil and regular gas. One of these saws is now 30 yrs.old. And ... no smoke-cloud, nor port/muffler mung.
With new saw, you might want to use more oil for first few hours. Just remember that doing so leans the fuel mixture.
Aug 02, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK Logo
2,291 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
