Bunn NHB Coffee Maker
Problem for Bunn NHB Coffee Maker
Cracked plastic
By jasper1427 on Oct 04, 2008
It looks like the plastic in the water reservoir is on our Bunn NHB coffee maker has a crack in it. I would prefer to buy a replacement and install it myself as to not having my coffee maker. Could this crack be causing a water leak? Can it be replaced? Help!
Thank you,
Rob
Same Problem
May 23, 2009
-   Same problem here. The plastic reservoir has a crack and leaks water everywhere. Had this machine for 11 months now. I can't quite figure out how I cracked it as the dern thing is never moved.
I'm calling BUNN to see what options I have.-   lulubee
May 09, 2009
-   On my Tassimo the plastic water container has broken plastic at the float, so the float just floats out, do they not do replacements -   josephcoombs
Feb 22, 2009
-   I have a cracked resevoir in my GRX-W bunn coffee pot.CanI buy a replacement resevoir for it?-   jcsalen
Best Solution
posted on Feb 12, 2009
Very Helpful)
furnoptn
Rank: Guru
Rating: 89%, 69 votes
Yes- this is a very common problem with the Bunn home coffee brewers. However, there are no replacement parts available. Your only hope to get a replacement pour-in tray is to get ahold of yopur local Bunn repair center and see if they have a machine that broke down for some other reason and rob the tray from that. You can get a list of Repair centers in your area from www.bunn.com
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Bunn NHB Coffee Maker
Questions and Unsolved Problems for Bunn NHB Coffee Maker
Do you recommend Bunn NHB Coffee Maker?
Answer
Answer
How much water do I put in resivior to start the coffee pot.
Answer
I have a small water leak at the back of the coffee pot. Water is coming from inside the coffee pot.... (More)
Answer
when water is put in the maker, it will leak about a cup. can it be fixed
Answer
my bunn coffee pot is leeaking water out the holding pot, then it onloy makes half a pot of coffee... (More)
Answer
my bunn is leaking water out the back
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Bunn NHB Coffee Maker:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
