Question about Kenmore 24 in. 16352 / 16354 / 16359 Built-in Dishwasher
Film and food residieu remains on upper rack
After completing the Wash cycle and drying the dishes in the top rack , have a white residue and food particles baked on them . some glasses i had to throw out because the film would not come 0ff. insight in to this matter would be kindly appreciated
openaccess_@hotmail.com thanks
Hi, is the wash arm underneath the upper basket turning freely and is it not blocked with any food particles? I've had items out of my dishwasher with a similar problem and it's been when the upper wash arm has been blocked or a spoon has fell through and prevented it from turning and washing properly.
Good luck.
Posted on Oct 04, 2008
Leaves food residue on dishes, mostly glasses and only on top shelf after every wash.
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Jan 16, 2011 | Whirlpool 24 in. GU1200XT Built-in...
I've had my dishwasher (GU2455XTSB3) for almost 2 years. The first year and half were great. I always use the same cycle (with options) and it took approximately 1.5 hours to complete. Now it takes over 3...
heatman101
Oct 23, 2010 | Whirlpool GU2455XTS Built-in Dishwasher
Food residue left behind on my dishes on the top rack. The addition of a rinse agent doesn't seem to help. Suggestions?
heatman101
Oct 17, 2010 | GE Nautilus 24" Built-in Dishwasher
Maytag model no mdb8951aws. My dishwasher doesnt clean properly. There is a residuesomehing like food stuck inside cups & bowls specially in upper rack .i dont stack dishes.tried everything but no...
heatman101
][\][\0-0-
Jul 05, 2010 | Maytag 24 in. MDB8951AWS Stainless Steel...
Hello, Recently my dishwasher has been leaving particles of food residue in glasses or other glass items. This is a particular problem when using the top rack, but the problem sometimes is also on the...
heatman101
Jul 05, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
My dishwasher leaves white residue on cups of the
heatman101
Feb 15, 2010 | Kenmore 24 in. 17033 Built-in Dishwasher
The items on the top rack never come out clean. there is always food residue left. it seems that the final rinse doesn't get to the glasses. we need to rinse them all out before the drying cycle starts...
heatman101
Jan 04, 2010 | Amana 24 in. ADB2500AW Built-in Dishwasher
The dishwasher doesn't clean properly
Lots of possibilities...
1. the sprayer arm might be sticking and not moving, or moving very little. Check to see if you can spin it by hand. Listen when the machine is running and you should hear the sound of the spray changing as it rotates. Check for items that might be jamming the arm like silverware, cups, jar labels, etc.
2. the little holes in the sprayer arms could be clogged. Need to remove the arms and clean them.
3. If it has a spray arm in the top rack, check to see that the piping for that is not broken or missing any pieces.
4. Any filter screens inside the plumbing could be clogged. This would slow down the spray and result in the dishes not getting rinsed properly. Check the inside of the machine for any foreign objects (see #3 above).
5. The machine might not be emptying between portions of the cycle. After the wash cycle, see if it is draining by either checking for water coming out of the drain hose or by opening the machine before it should start filling up for the rinse cycle.
6. Machine could be overloaded. Or loaded with extremely dirty dishes. Or with foods that are hard to clean like grits or oatmeal.
7. The machine could be improperly loaded. Bowls or platters blocking the spray. Tall objects like glasses and jars should not be loaded into the corners of the racks. The corners do no get a lot of spray and tall items can end up dirty.
Dec 22, 2009 | Neff 24 in. S5555X0GB Built-in Dishwasher
Maytag dishwasher quiet series 400. Dishes have hard stuck on grit and food particles after rinsed and dried.
Very common problem is soap build up in these machines. Try putting it into a wash cycle with no dishes, and no soap. Let it wash for about 5 minutes, and then open the door. If you see alot of soap suds, then soap build up is the problem. Try doing a couple loads with no soap, and no dishes, and throw a cup of vinegar into the machine halfway through the wash. Repeat as necessary. This should solve your problem.
Mar 14, 2009 | Dishwashers
Dishes not getting clean
brittgee, there has been a number of service flashes on this model. One that has to do with the upper spray arm assy. Complaint is poor washability; gritty glasses, food redeposited on glasses, especially in the corners. They redesigned the upper spray arm to improve water spray to all corners of the upper rack. The new part number is 8269022. They also redesigned the third level spinner for more consistant rotation and better washability. This was also under a service flash. Part number.8193768. Other reasons for poor wash would be; low water temperature, rinse aid disp. not working, loading etc. Catriver...post back.
Nov 25, 2006 | Kenmore 24 in. 15933 Built-in Dishwasher
Kenmore 24 in. 16352 / 16354 / 16359 Built-in Dishwasher Logo
472 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
