I am connect to a Time Warner cable modem and WRT54G2 an am able to coonect to the internet with no problems but I then remove the Desktop top PC to another location and install a wireless lyknsys adapter I proceed to connect to the router but I cannot get via WEP key with no problems but I get the message "cannot associate an access point"
  • 661 Answers
Your wireless router may not be enabled or you may have mac address filtering on. (which blocks unexpected wireless connections)
you need to log on to your wireless router and check the configuration of your wireless security settings
Posted on Oct 04, 2008
I have a modem cable connection with time Warner cable but router isn't connecting to modem what can I do
I install Linksys routers all the time. Usually the first thing I do, is update the routers firmware. Many times I find that if the Linksys router doesn't automatically get a connection from DHCP, updating the firmware usually solves it.
To update the firmware:
Connect just to the cable box so you have an active internet connection.
1. Go to: http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G2/download
2. Select your router version (can be found on the sticker near the model number) and download the latest firmware to a spot you will remember.
3. Now connect the router to your cable modem and computer.
4. Access your routers configuration page (If you don't know the address try: http://192.168.1.1 or http://192.168.0.1).
5. Log-in - if you haven't changed the username/password the default should be a blank username with the password "admin".
6. Click "Administration"
7. Click "Firmware Upgrade"
8. Click "Browse" and choose the firmware file you downloaded in step 2.
10. Click Upgrade. Be patient and let it do its thing.
See if you connect after that. If not, let me know and I will walk you through the next steps.
Regards,
KYTechnology
Mar 04, 2011 | Linksys WRT54G2 Wireless Router
How can I install a wireless router to RCA cable modem DCM425 installed by Time Warner?
From the back of your modem, follow the ethernet cable to your PC (in). Mark or remember this location. Remove this cable from the PC and insert it into the INTERNET port on your router. Then take another ethernet cable (usually supplied) and insert one end into the ETHERNET port of the router, and the other end into your PC (where you originally removed it. Remember to check all connections and plug in the modem. You should now be good to go! If your PC has an installation Wizard, you can browse thru it as well.
Jan 07, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
I DONT HAVE A SETUP CD AND I DONT KNOW HOW TO INSTALL MY ROUTER CURRENTLY AM USING MODEM
Very simple, follow the steps.
1. Power on your router (Linksys)
2. Coonect router to your PC using Ethernet/LAN port
3. connect router and modem using Internet/WAN port
4. open internet explorer in ur pc, type 192.168.1.1 or 192.168.0.1 in address bar. press enter
5. ask password and username : admin/admin (all small letters)
6. if u have broadband connection, select PPoE and enter ur ISP account name & passowrd.
just save settings, restart the router and its done.
Id solved pls Vote for me.
Sep 24, 2010 | Linksys WRT54G2 Wireless Router
Router Won't connect to internet
The cable modem sometimes register the hardware MAC address of the connected device. So your PC may be registered and it won't accept the router now. Connect the WAN port of the router to your cable modem and power the modem off and on again. It should re-register the connected device and now your router should work.
Jul 30, 2009 | Dell TrueMobile 2300 Router (000001)
Not recognized by cable modem
Turn everything off for 2 minutes, cable modem, router and pc.
Turn on modem and wait 2 minutes for the modem to sync to TW.
Turn on router after 2 mins and wait until the router syncs with the modem.
Turn on PC
It sounds like your router lost its connection to the cable modem, which happens from time to time. TW will not help with your router. I worked for a cable co and the router and modem losing sync was the at least 70% of the calls. FYI cable doesn't use DSL,just the phone co.
May 19, 2009 | Zoom X6 Adsl Modem/router Rohs...
I have Time Warner Cable for internet and Vontage cable for my phone thru my internet. I'm trying to connect a Linksys router for my wireless laptop. I also have a Netgear switch connected to Time Warner...
If you purchased a Linksys wireless roter then you shoul not need the switch anymore-
Try going directly from your time warner modem into the Interner/WAN port on the router and then plug your desktop computer and the vontage phone system into 2 of the ports on the router. After everything is hooked up you will probably need to power cycle for it all to work correctly.
Please power cycle in this order:
Reboot modem - then Router- then Vontage phone system.
Hope this helps
Apr 09, 2009 | Linksys -Cisco Wireless-G VPN Broadband...
Can't connect my Netgear WGR614v7 to Time Warner Cable Internet
I have just bought a Netgear WGR14 v9 and I was wondering if anyone knows how to set it up with Time Warner. We just swithced from Bellsouth to Time Warner and I don't know how to set it up?
Jan 11, 2009 | NetGear WGR614 Router
I installed Netgear wnr834b on time warner cable. it works for a minute but then power and link lights go orange and i lose connection. have replaced router but still same thing. also replaced modem and...
If you already replace the modem and the router so it only means that the problem is with your Time warner internet connection line , did you already contact time warner and let them check your internet line to make sure the signal from them is strong and working fine if not contact them...
Oct 24, 2008 | Computers & Internet
Unable to open hotmail and citibank website
I take it you are using Broadband.
How is your laptop coonected to the internet. Is it plugged into a ADSL modem or or have you got a wireless coonection.
need more info.
Oct 11, 2008 | HP Pavilion dv9000z Notebook
Dynex wireless modem
Your expert Geokohler helped me fixed the problem and soved it for me. I sent an evaluation giving him a "fixit" rating.
Jul 21, 2008 | Dynex DX-E401 Router
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
