My Canon i250 won't print a text file in black ink, although it will print in color. When I do a "maintenance check," the black seems to work o.k., and it has no problem printing a PDF file in black ink, as well.
I tried removing and cleaning the print head, replacing the black ink cartridge, but nothing changed.
Is there an affordable way to repair it, or should I just replace the whole printer?
Same problem here. Won't print black. Will print color.
I've tried 4 new color black cartridges - and same result - won't print in black.
-   kissit929
Mar 11, 2009
-   PRINTER WILL NOT PRINT BLACK USING ANY PROGRAMME.
I AM ABLE TO PRINT SAVED WORK IN ANY COLOUR BUT BLACK.
I HAVE CHANGED THE BLACK INK AND CARRIED OUT THE MAINTENANCE BUT IT WILL NOT PRINT BLACK WHEN UNDER TEST.-   Guest
Mar 02, 2009
-   Suddenly neither cartridge will print on the i250.
So I removed the print-head, (flip up the guard which holds the ink cartridges, then remove the ink-cartridges, and then pull the holder which is the printed-head toward you a little and it lifts out)
I saw underneath it was a little inky, so I dabbed it with a bit of distilled water on tissue (do that at your own risk cause I don't know what it says in the manual).
Put it back, tried again.... same result... no black ink.
However I then tried another new ink cartridge... the 5th I'd tried.. cheap one I got on ebay.
AND IT WORKED.
I looked at the other black-cartridge boxes I'd tried, and the USE BEFORE DATE = 08.2008
The new one I tried, and the one where it got back to printing black in perfect working order... was USE BEFORE DATE = 05.2010
I think the black ink must have dried up in my older cartridges... but I honestly had expected them to last out a bit longer past their USE BEFORE date.
When printing off photographs from computer have consistant lines through photos. The quality of...
(More)
When printing off photographs from computer have consistant lines through photos. The quality of print other than the lines is good.
My photosmart 2610 makes a noise when idle. The noise is like a clicking as if the ink cartridges...
(More)
My photosmart 2610 makes a noise when idle. The noise is like a clicking as if the ink cartridges are aligning. Is there anything I can do?
