Question about Kenmore 24.8 cu. ft. TRIO Bottom Freezer Refrigerator
Kenmore TRIO with a Buzzing then click
We have the same problem 8 to 10 seconds of humming then a click and silence for about 4 minutes then it starts again. Over and over for the last 2 days, temperature in both freezer and refrig is 47 degrees. Sears won't make any statement as to what the problem may be, even though I tried to discuss all the postings on the internet. They say they are unaware of any problems or recalls. Very uniformed or an IQ of 2, deliberate or not.
Any known problems with model# 59675522400 serial# 10886782ER
  • Anonymous Nov 27, 2008
    I have the same buzzing then click problem with my Kenmore Trio. Is the relay easily replaced or do I need a service call.
  • Anonymous Jan 10, 2009
    Hate to admit how dumb this makes me sound; but I had the same problem. Fridge ran fine, but there was a loud buzz that lasted about 8 to 10 seconds.. then silence... then a rattling sound.
    Drove me nuts for a over 2 weeks.
    Turns out it was the ice maker motor. I dont have the ice maker hooked up, and some how the lever got pulled down; so the motor turn on and try to fill.
  • 943 Answers
Hi thanks for the question . the relay on the compressor has failed. replace the relay thanks the appliance doc
Posted on Oct 05, 2008
  • pbroccar Feb 10, 2011
    Have the same issue (buzzing click) then eventually after 2~3 times the compressor starts. I have replaced the relay (came without a black plug at the back?) but it is still doing the same buzzing and click. What is the black plug for?(looks like some type of fuze) What are the symptoms of a compressor dying?
My Kenmore washer (series 90) stopped working in between the rinse and spin cycles. It will not drain (half full as we speak), agitate or spin. It will fill with water but once it reaches the proper water...
Something stuck in Pump. Pump on your model is driven by washer motor, so if Pump can't turn, motor can't work and will hum until it overheats and shuts down.
Sep 28, 2017 | Washing Machines
I have an kenmore elite "ultra wash" model 665. not sure the rest.. about 7/8 years old, making loud buzzing sound during wash cycles,starts about 5 minutes into the normal wash cycle. i removed the inlet...
I have the same problem as those who stated their dishes are not getting clean. If you listen to the wash cycle you should hear water sloshing around inside. If you hear just a humming sound the washer has no water. I have this problem. I had a tech come and he told me the water is syphoning out my drain and I need to change my plumbing, then he charged me $65. I have lived in this house for ten years. 6 with the washer that came with house and 4 with this Kenmore Elite. This problem started about 6 months ago. So what I have been doing is opening the door, after the humming starts and the sloshing stops, and adding about 2 L of water. It seems to wash just fine after that.
Jan 12, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
My Kenmore side-by-side refridgerator is making a loud humming noise. My Kenmore side by side refrigerator/freezer has been making a buzzing noise every few minutes. Now I realize that the freezer is no...
You need to clean your coils under the 'fridge,' and wait 24 hours, if it is not not getting cold, perhaps replace the freon. If that does not work, you need to call a repairman.
May 26, 2009 | Kenmore 57029 Side by Side Refrigerator
Noise & Clicking at regular intervals on working Kenmore 72214
yea that is the compressor relay, you will start to notice your food to thaw out and get bad. try to unplug for about an hour. if then it still does that call www.whirlpoolpartssurplus.com and get a relay kit.
May 06, 2009 | Kenmore 72212 / 72214 / 72219 Bottom...
Freezer quit working on '04 Kenmore Trio Elite 25' bottom
Can either be starting components for compressor, or Motherboard.
May 04, 2009 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Constant cycling every 4 minutes...then goes to defrost
you may have defrost problem you will have to call them
Apr 07, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore trio 596
no it wont work, you can try replacing the overload relay assy mounted on the side of the compressor(football sized motor) behind refrig. i would check your manual for warr. information depending on age you may be covered for faulty compressor.
Aug 07, 2008 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
KENMORE TRIO 2004 59675523400 REEFER/FREEZER NOT COOLING
It is the compressor that has failed. The hum is it trying to start and the following click is the overload protector opening. What is the temperature where the refrigerator is located? Allow the compressor to cool down before trying to restart it. If it still does not restart after it has cooled off it is done.
May 17, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Buzzing intermittent
It sounds like the ice maker. If you don't have the water hooked up, and the ice sensor bar is in the down position, the ice maker assembly will attempt to make ice continuously.
Solution is easy: raise the ice sensor bar until it clicks in the up position. It will lock in this position, and the ice maker will not cycle anymore.
May 04, 2008 | Amana ABB2227DE Bottom Freezer...
Trio: humming and temp in freezer rising
It sounds like the condensor fan motor is seizing up. This is the fan that cools the compressor down. Does the outside of the fridge feel excessively hot to touch? Can you feel air being circulated under the fridge or behind the fridge? It could also be a faulty defrost timer. Try to identify where the buzzing is coming from and if it is the condensor fan you can put a normal standing fan behind the fridge, blowing onto the compressor untill the repairman can get to you.
Oct 29, 2007 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Kenmore 24.8 cu. ft. TRIO Bottom Freezer Refrigerator Logo
427 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
