Question about Rinnai Unvented Gas Zone Heater. 99% fuel efficient: Blower with Thermostat
Rinnai 606tra error code 31
Any ideas on this error code heater is new second season sat idle unconnected thru summer install in new location now error code 31
will not ignite seems like ignighter not clicking i have two of these
other unit working fine manual is no help lists 4 error codes any others it says call so im here instead
    Problem Solver:
I didnt fix it i did pay my 10.00 and what i got in return was i think , was an expert telling me to read the manual
Posted on Oct 05, 2008
    Problem Solver:
Since the e mail you sent to me was do noy reply i will try to get my point across here.
i posted my question on your 10 buck forum the answer i got was read the manual and now after posting on your free forum the reply i get is to try posting in the 10 buck forum. sound like a run around to me
Newly installed rinnai rhfe-1004fa gas heater will not start up
I don't know what's the matter with fixya site it's getting to be a real pain in the as>
Dec 07, 2014 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
My Rinnai 1004F giving me error code 99
This fusible link may be open. Try jumpering the two leads and see if the unit operates. If it does replace the fusible link. Do not operate the unit without the fusible link for an extended period. It is a safety device and is there for a reason. Hope this helps.
Jan 04, 2014 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Our rinnai R94LS will shut off after running several minuets and shows error code#10. I'll turn it off for several minutes and turn back on, run system for several minuets and it will shut off again and...
Tankless computer is not working.
Error 10 is blocked flue or inadequate air supply. Or failed PC motherboard, or failed sensor etc.
Get more fresh air to unit. Check if bird built nest on flue pipe. If flue exits side of house, look for obstructions nearby that can slow the exit of poisonous vent byproduct into the air you breathe. For example trash cans and boxes or parked car etc.
http://waterheatertimer.org/pdf/Rinnai-installation-and-error-codes.pdf
Call service technician who is qualified to work on tankless computer. This will be a well-seasoned veteran of computer technology and plumbing expertise ... a plumber who knows how to fix computers lol.
This person will catch unit up on required yearly maintenance, and check specialized operation conditions needed for tankless computers to function properly.
If tankless computer is older than 5 years, then compare it to your 5-year old laptop, and assume same level of glitches and problems.
Solve any tankless problem yourself, today, for $385 by installing tank type heater from local box store:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Gene
h
Aug 29, 2013 | Rinnai Water Heaters
Error code 31, heater not working, red light flashing
There is something wrong with the room sensor. Wires cut, shorted or disconnected.
Tom
Oct 03, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Toyo laser 73 error code EE8. What does that mean?
All error codes are explained on the lower left side of the heater. The EE8 message is for the combustion blower motor. If your stove has been unused for the summer you may get away with just spinning the blower wheel by hand to free it up. If this does not work you are in for a new motor or assembly. Either way you need to clean the blower and heat exchanger.
Tom
Aug 23, 2010 | Rinnai Toyostove Direct Vent Heater:...
Rinnai 1004 F Error Code 11
Code 11 is that the unit is trying to light but does not sense a flame after 5 seconds. Usually means you have run out of gas if you are bottled gas. Check your bottles are turned on if you are on LPG, you might need to change over manually. Have you anything else on gas?
Jul 01, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai tankless water heater code 12
12 - Flame Failure or Poor Ground
1. Immediate code 12 is usually a defective gas valve, power supply problem, or defective fan motor wiring harness.
2. If code 12 occurs after a few seconds it indicates that proper operation was established, but then stopped unexpectedly.
3. Verify that fuel is being supplied to the unit.
4. Check for proper electrical ground. Unit must use a grounded power supply.
5. Check for flue blockage on inlet or exhaust.
http://www.foreverhotwater.com/service-codes.php
Dec 31, 2008 | Rinnai Webstone The isolator EXP tankless...
Error code 12
Error code 12 is a genaric "Flame Failure" code. I suspect that the flame is not hitting the flame sensor or that the sensor is bad. You will need to get to the sensor located on the far left hand side of the unit. If you have the owners manual, it's part #123. Remove it and clean it off. Make sure it is placed back in the heater properly aligned and all the way in. Then try and light it. If it does not stay lit, it may need to be replaced but check out the burner tray for debris not allowing the flame to travel all the way to the sensor. You will have to remove many parts to get to the burner assembly.
Jan 05, 2008 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
Rinnai Unvented Gas Zone Heater. 99% fuel efficient: Blower with Thermostat Logo
199 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
