Question about Toshiba Satellite A105 Notebook
Screen goes black, machine stops functioning, power light blinks yellow
With the laptop plugged in, after about two hours, the machine stops functioning. The power light blinks yellow, the screen is black.
This has been happening for about two weeks. When I close the cover and leave it alone for several hours, it functions again.
Steve
  • 1 more comment
  • Steve Sufian
    Steve Sufian Oct 05, 2008
    No. It's completely cool.
  • Steve Sufian
    Steve Sufian Oct 08, 2008
    Solution 3 is actually my response to amusedgeek's questions.
    The problem has occured both while I was using it and when I've left it a while. Often, it happens only after the computer has been on several hours, but once it occured within two minutes after I turned the computer on.
    When I first ran into the problem, I changed all the power options to
    "never"--the computer is supposed to be always on unless I turn it off.
    When
    the computer is in extended yellow blink mode, pressing the power
    button doesn't work. If it has been on battery, when I plug it in and
    then press the power button, it sometimes turns green and works. I
    don't recall but I think this is only occasional.
  • John Hong
    John Hong May 11, 2010
    When it shuts down, does it feel hotter than normal?
When I first ran into the problem, I changed all the power options to "never"--the computer is supposed to be always on unless I turn it off.
When the computer is in extended yellow blink mode, pressing the power button doesn't work. If it has been on battery, when I plug it in and then press the power button, it sometimes turns green and works. I don't recall but I think this is only occasional.
Posted on Oct 08, 2008
  • Toshiba Master
  • 787 Answers
Does it stop functioning while you are using it or have you walked away?
The computer could be going into a power saver mode.
Go to the Control Panel and try changing the power settings so that it is always on. See if this helps.
What happens if you press the power button and wait a few moments when it it blinking?
Posted on Oct 06, 2008
  • 661 Answers
Sounds like a thermal issue, (laptop getting too hot)
try this (or similar)
http://www.misco.co.uk/applications/SearchTools/item-details.asp?EdpNo=280872&sourceid=2459&CAWELAID=84125196
Posted on Oct 04, 2008
Monitor won't turn on after a few hours of being shut off
If it EVER works, then the problem is not a failed part, but a weak part. The most likely component type to give you such problems are capacitors. But very few repair techs know how to find such problems, and even fewer have the equipment needed to find the bad one(s) in-circuit. The failure mode is high ESR (ESR means Equivalent Series Resistance). The lower the ESR, the better. Capacitors with high ESR cannot stabilize circuits which demand high pulse currents, such as in switch mode power supplies.
Apr 24, 2017 | Generic Computers & Internet
Yellow led blink 8 times compaq m700
I'm not understanding what the problem is. If the battery is dead, and you remove it, how do you expect it to recharge? Why would you remove it? So, you take it out and nothing happens.So? What were you expecting to happen?
Before you do anything more, read the documentation that came with your laptop to learn how to care for your battery. The amber light usually blinks with the battery is running low. When you plug in the A/C adapter, the light usually becomes steady to indicate the battery is charging. At tleast until you remove it.
Hope this helps. Please rate this repsonse
Randy
Aug 31, 2012 | Compaq Armada M700 Notebook
Compaq 6735s notebook pc goes to HP screen, but wont boot
First you need to determine how many blinks you are getting when you try to power on the laptop.
Check the blinking codes below and reason behind that for HP Compaq laptops
Blinking battery power LED Battery Insufficient charge on the battery
Blink: 1 - Caps Lock/Num Lock - CPU CPU not functional
Blink: 2 - Caps Lock/Num Lock - BIOS BIOS corruption failure
Blink: 3 - Caps Lock/Num Lock - Memory Module error not functional
Blink: 4 - Caps Lock/Num Lock - Graphics Graphics controller not functional
Blink: 5 - Caps Lock/Num Lock - System board General system board failure
Blink: 6 - Caps Lock/Num Lock - BIOS BIOS authentication failure
Plz get back so I can suggest you the steps to resolve the issue.
Dreamkam
May 24, 2010 | HP Compaq 6735s Notebook
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
Dell Latitude d600 starts up, loads Dell screen, but stops there
try removing the battery . wait 30 minutes. plug the battery back in and try again.
Sep 12, 2009 | Dell Latitude D600 Notebook
No Power Toshiba A55-S1063
sounds like the powersupply might be bad try another one if that dont help then your board is bad -sorry
Jun 29, 2009 | Toshiba Satellite A55-S306 Notebook
Toshiba satellite a105 blank screen, blinking battery light
well to me either there is a issue with the power supply or the power cord. I have had a bunch of laptops where the power cords have to be a certain way or nothing will respond. this could be and since it is thinking that it is running in battery mode then it drains and then causes the laptop to turn off or go into hibernation due to the fact that the setting you set for the battery where probably on the "when plugged in" not the running off the battery mode.
it leads me to think that its the power supply because its the most common issue with this but I think that the best solution would be to either find someone that can test the power supply and find the break in the line or buy a new one to test ushally if you buy one from a store bigger named store outfit and use the power supply to test you can ushally get your money back or goto a local computer shop and get them to match up the power supply or see if they have a adaptor loose that can be used for testing.
These could be possible solutions but like I said I am almost 100% sure that its the power supply and not the laptop because even if the battery is not in the laptop the unit should still power up. on most laptops that is.
So that might be another thing that you would like to check but I highly doubt that it is that. because even a dead battery will allow the power adaptor to run on the laptop even if it dosent charge.
hope this helps and hope it works for you. let me know how you make out and if this made any sort of sence to you haha
Oct 12, 2008 | Toshiba Satellite A105 Notebook
Red power button & "lamp" indicator blinks
Having similar issue with my PT-44LCX65. Lamp blew and replaced it (last month), never figured out how to reset timer. Now red indicator light blinks once every 5 seconds and after about 4 minutes TV goes black.... Any ideas?
Dec 26, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Toshiba Satellite A105 Notebook Logo
178 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
