Question about Sunbeam 5891 Bread Maker
I find a part approximately 4" long, stainless steel stuck in the strofoam, has a hook on end, what is this part for????? Thank you. mimi1@bvunet.net
Breadmaker came with a part I do not know how to use..instructions book does not mention it...about 4 inches long with hook on end....
    Scholar:
  • 74 Answers
After some searching, it appears that the "hook" is intended to be used to help get the paddle out of the loaf in case it gets stuck.
Hope this helps.
Posted on Oct 17, 2008
What size hole bit for soap dispenser to drill through stainless sink? I have 3/4 " will that work? Instructions do not have those details
measure the outside diameter of the dispenser bottle(part of bottle which will go through hole) and drill hole approximately 1/16 inch larger. link below could help
How To Drill Hole In Stainless Steel Sink Build com
press helpful button
Jan 09, 2016 | Home
Frigidaire 24 in. FDB4315LFC3 STAINLESS STEEL ERROR CODE UO
Hi Mark, thank you for your post!
Error code UO commonly means that the vent is in an open position. While your Frigidaire dishwasher is in wash cycle, the main control board is not receiving signal from the vent assembly.
Before reaching out to a professional, let's try resetting your dishwasher. This can be done by flipping the household circuit breaker off. It is important to wait approximately ten minutes and then turn your dishwasher on. This often clears most false-error codes. If resetting the power does not correct the issue, a professional will need to check the wiring between the vent assembly and main control board.
Best of luck!
Jan 18, 2014 | Frigidaire 24 in. PLD3465REC Stainless...
How to replace bulb in garrity stainless steel pen light
I have a Garrity stainless steel flashlight that is approximately 6 inches long. It uses two AA batteries. The light is turned on and off using a push button on the back (push on, push off). The head-end turns to "focus" the light. The lamp, itself, is incandescent. It is 9/16-inch long, including the two 1/4-inch wire leads. The flashlight was purchased 11 years ago, and the lamp just burned out. When I called Garrity, they said they no longer had replacement parts for these flashlights. Which is strange, given you can use Part 2A001 Mineature Bulb G1.27 Base bulbs available from Bulb Town in Jacksonville, FL, as replacements. They work like a champ! If you have any questions, ask to speak to Melinda.
Apr 13, 2013 | Garrity Replacement Bulb
Mercedes stuck in 4 wheel low
What speed was being driven when you this was attempted?
Feb 03, 2013 | Mercedes M-class Ml Ml350 Ml500 Ml55...
The bottom panel (on the outside of the dishwasher) will not stay in position - it keeps falling down. There does not appear to be any brackets or hooks to hold it in place. Thank you
if you are talking about the stainless steel panel they are usually glued on. there is some history of the glue letting loose on stainless appliances
Oct 24, 2010 | Asko D1776 Stainless Steel Built-in...
Just bought a vintage Citizen Super Crystal Date stainless steel watch. Serial No. on back is 00625090. Can you provide the approximate or exact date of production? Thank you.
We cannot tell you from the serial number what the model watch you bought is . But you can call Citizen watch 800 321 1023 extension 4234 and give them the serial and they will be able to tell you the model and year the watch was produced.
Oct 14, 2010 | Watches
Making a loud squeal or hum during
Sounds like a motor with bad bearings. In that unit it would be the water pump or condenser fan motor. If the sound is coming from inside the unit it is the water pump.
Nov 08, 2009 | U-Line SS95 Stainless Steel
Duet GHW9150W0 Washer - Stainless Steel Washer Bin Arms Broken
I HAD THE SAME PROBLEM. I CALLED THE 800 NUMBER AND HAD WHIRLPOOL SEND ME ALL OF THE PARTS THAT WERE STILL UNDER THE EXTENDED WARRANTY THAT I PURCHASED. WHIRLPOOL SENT ME EVERY PART, INCLUDING THE STAINLESS TUB, THAT WAS STILL UNDER WARRANTY. I NOW HAVE REPLACED ALL INTERNAL PARTS EXCLUDING THE MOTOR.
Jun 07, 2009 | Whirlpool GHW9150 Duet Washer
How to clean stainless steel
You say your new oven...and DW have stains...I will assume (if that's OK) that you have a stainless steel oven...and are washing stainless steel in the DW...but you are having streaks and or white...spots or deposits...Sounds like hard water...you may try a localized..(just for the DW and kitchen sink area) filtration system...to reduce hardness of water...(is this well water)..if so you definitely need filtration...if you don't already have it.
Here are some issues and or cleaning techniques for stainless steel.
stainless steel is known for its ability to be a clean surface that resists corrosion and rust. Dirt, dust and grime, however, put stainless steel at risk for corrosion and rust. Luckily, stainless steel responds well to cleaning, never wearing out from excessive cleaning, as long as certain rules are followed. 1. Water and a cloth.
Routine cleaning can be accomplished by using warm water and a cloth. This is the least risky option For cleaning stainless steel. Dry with a towel or cloth to prevent water spots. Wipe in the directions of the polish lines.
2. Mild detergent, (dish washing liquid) and cloth.
For cleaning that needs more power, mild detergent and warm water can do a great job without damaging the stainless steel. Make sure you rinse the surface thoroughly to prevent staining and spotting. Towel dry to prevent water spots which can be caused by minerals in water.
3. Glass cleaner for fingerprints.
Fingerprints are one of the biggest complaints about stainless steel, but can be taken care by using glass cleaner or household ammonia. Rinse thoroughly and towel dry. There are some newer types of finishes for stainless steel that resist fingerprints, a must if your pint-sized helpers leave their mark on your stainless steel appliances.
4. stainless steel Cleaner.
If you’ve had staining or scratching, or need to polish your stainless steel, a stainless steel cleaner may be a good option. Some of these cleaners and polishes can help minimize scratching and remove stains. They also can polish stainless steel surfaces nicely. Read the directions on the stainless steel cleaner and test in an inconspicuous spot. Be sure to rinse thoroughly and towel dry.
If this does not help please clarify...with specific model #'s and walk me through (step by step) what the specific problem is and how you address it....Thank you and I hope this helps.............
Good Luck...........The Fang.
Mar 06, 2009 | GE Nautilus 24" Built-in Dishwasher
Sunbeam 5891 Bread Maker Logo
191 people viewed this question
Top Sunbeam Kitchen Appliances - Others Experts
Are you a Sunbeam Kitchen Appliances - Other Expert? Answer questions, earn points and help others
