Question about Henry Numatic "" Canister Vacuum
Can i use a 110 vacuum cleaner on 240
I have a 110 volt vacuum cleaner. can i plug it into my home supply of 240 volts without using an adaptor? or can i flick an internal switch to change it?
    Problem Solver:
  • 17 Answers
The answer is no to both questions. you will fry the motor as it was made for 110v only.
Posted on Oct 04, 2008
My vacuum is now erratic and shuddering in its movements repeatedly re vacuuming in same place. Just had it serviced 2 months ago.
Hi, I don't know if it's the same problem that I had with my Roomba, but it sounds very similar. It was a broken wheel drop sensor (switch) on on wheel. I ordered one from EBay for $4.00, and had it running again like New.
Jun 04, 2014 | Samsung NAVIBOT SR8845 VACUUM CLEANER FOR...
Nothing happens
it could be the wiring coming from the vacuum itself you might have to change it.can be brought at any electrical wire store have you checked the plug wiring is it all intact or has some came out from the terminals?
Apr 06, 2014 | Electrolux Z4735AZ Gazelle 1900W Upright...
Digital inverter generator has no 240 volt output
Most power inverters are strictly single-phase. Meaning true 120V or 240V, and no splitting or duplication. It sounds as if your inverter is a single phase 120V, and likely is not stackable on the AC side.
I recommend looking for a Low Frequency Split Phase power Inverter if you want both 240 and 110 volts.
Aug 09, 2013 | Vacuums
It came with a american plug and when we put a converter to australian plug on it it only shows 220w instead of 240 which is what we have in australia. Don't want to plug it in and it blow up on me.
I think you mean 220 volts, versus 220 watts. The difference between 220 & 240 volt equipment is usually just a matter of nomenclature -- no significant difference in terms of operating the equipment.
The vacuum is 110 / 120 volt since it has an "American" plug on it. If the plug is swapped for an "Australian" plug (or adapted) and plugged into the wall, the vacuum will be connected to 220 volts -- this would destroy the motor.
You would need a transformer to step down the Australian voltage to 110 / 120 volts. If you plug it in without a transformer, it will surely burn up the motor.
More info, let me know.
Charlie
Mar 30, 2011 | Vacuums
How to use 220 volts sewing machine to 120 volt plug, were can find a transformer?
If the sewing machine came from a forigen country, Check radioshack. They might have an adaptor there. but be ready to spend some $. but if it is an industrial sewing machine, have an electrician put in a 220 volt outlet. Don't cheat. Your home will be put at risk from fire.
Aug 12, 2010 | Vacuums
Wattage for Kirby Sentria G10D
The conversion of Amps to Watts is governed by the equation
Watts = Amps x Volts
For example 1 amp @ 110 volts = 110 watts
your case 7 amp @ 120 volts = 840 watts
unless you are running it at 230v but I don't think you can
I would look for one rated for Volt-Amps instead of watts
It's best to round up to be safe add 40 - 60 watts
Don
Apr 25, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Sentria
sounds like the motor burned up. not sure if travel adapters will handle a large load like a motor, around 8 or amps. power needs in US are 110 volts ac, 60 hertz.
I believe UK is 220 volts and 50 hertz.
usually when a vac is brought to europe you must change motor.
Jun 13, 2008 | Kirby Vacuums
Voltage
no!   It will be ruined if you try that.
Oct 16, 2007 | Kirby G6 Bagged Upright Vacuum
Henry Numatic "" Canister Vacuum Logo
155 people viewed this question
Top Henry Vacuums Experts
Gerry Harvey
Gerry Harvey
Chris Nomland
Chris Nomland
Are you a Henry Vacuum Expert? Answer questions, earn points and help others
