Question about Brother MFC-440CN InkJet Printer
Brother MFC440CN error 52
Hi:
Error 52 is showing up on my MFC440CN and I can not find any information about what it means or how to fix it
Thanks,
sjm264
  • Vincent Wright
    Vincent Wright May 11, 2010
    WHat do you to get the error 52?
BFixed
  • 104 Answers
SOURCE: brother mfc440cn help
The printer thinks there is a flash media card inserted in one of the slots in the front of the printer, If there is one there remove it.
Posted on Mar 07, 2008
SOURCE: Error 46 Unable to Init.
No need for part necessarily
SkipperOz solution pasted below
MFC-5440CN saved from the tip!
"Unable to Clean" message - found TrickyDicky's sltn 4 for various printers.
Went into maint mode as per sltn 4 - verified error 46.
"The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed."
Keyed in 80 - stepped through the items with "down" key and located Purge Counter.
"Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero
Press the Stop/Exit key to return to the initial stage of the maintenance mode.
Press the 9 key twice to return to the standby state."
This worked brilliantly - no need to tamper with any parts of the printer. Purge Counter reset did it all. Fully functional printer.
Thanks TrickyDicky for info on verifying the error code and purge reset
Posted on Apr 10, 2008
cene765
  • 787 Answers
SOURCE: error message one brother mfc-5440cn
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41 or 4F the print head is defective.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:
Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number
is over 6000, enter 2 7 8 3.This will reset the purge count value. Then restart the printer, hopefully without the
annoying cannot clean message.
Posted on Oct 28, 2009
komguy
  • 2306 Answers
SOURCE: Hi I have a Brother HL-6050D/N Error E60
E60 says the fan is not working, I would try first to blow it out, and after that look for a replacement fan.
Posted on Nov 27, 2009
SOURCE: machine error code 6A what that means?( Brother mfc 8440)
I argued on the phone with a BROTHER REP. that he should give the codes and directions to reset the machine, he refused time and time again, saying that this means physical damage to the machine an re-setting it is impossible to help, but i insisted, and it did fix the problem and the error went away.
here is what you should do, unplug for 10 sec. press and hold on the menu key while you plug it back in untill you see the screen "parameter init" press 99 and wait, this is what i did and it fixed the problem !!
Posted on Apr 08, 2010
I'm working on the 2004 Jeep Grand Cherokee 4.7 showing error codes
lashes 52 and 54 ,you do mean flashes ? What flashes ? Check engine light doesn't flash codes .
Apr 24, 2017 | Jeep Cars & Trucks
My brother printer has an error unable to clean 50
XXXXX XXXXX look on the printer, do you have these keys:
Menu/Set, Black Start, or Function?
Brother Printer Support
Sep 28, 2012 | Brother LC51BK Print cartridge, Inkjet...
"UNABLE TO PRINT 50" appears
Error: -------- Unable to Print XX
Problem: ------------ The machine has a mechanical problem. -OR- A foreign objects such as a clip or ripped paper is in the machine.
Solution: ------------- Open the scanner cover and remove any foreign objects inside the machine. If the error message continues, do one of the following: ?? (MFC-440CN only) See Transferring your faxes or Fax Journal report on page 139 before disconnecting the machine so you will not lose any important messages. Then, disconnect the machine from the power for several minutes and then reconnect it. ??
May 22, 2011 | Brother MultiFunction Center MFC-440CN...
Error 52 brother mfc 240c
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
CF
Jul 20, 2009 | Brother Multi-Function Center MFC-240C...
Unable to print 50
simple driver configuration problem linux is (the Cups printing system) is pretty universal just get your settings right or even cr even surrogate settings it should work
Nov 27, 2008 | Brother MFC-440CN InkJet Printer
Brother mfc440cn help
Feb 29, 2008 | Brother MultiFunction Center MFC-440CN...
Networking printer brother mfc440cn
Did you deactivate the firewall(s) when installing the machine?
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002000/000007/faq002007_000.html?reg=us&c=us&lang=en&prod=mfc440cn_all
and have a look around the faq, too...
Dec 19, 2007 | Brother MultiFunction Center MFC-440CN...
Error message 50
Confirm Success on a 440CN
1) Remove Plastic wire covers from inside printers, and release plastic stay on lower edge, tilt cover to 90 Degrees
2) make a note of where each connector goes
3) release the Ribbon and 3 Multicore cables, removing grounding screw, then remove scanner module by sliding it off the hinges at 90 degrees.
4) Remove Three Front Panel Screws, carefully leaver front panel upwards releasing front side clips.
5) Remove front panel by disconnecting ribbon and wireing on both sides.
6) Remove 6 Screws (2 on back, three at front and one middle right
7) Carefully remove speaker cable (Red Connector) and lift up plastic casing, leaving printer uncovered.
8) Re-Seat Encoder Strip into guide. (The Transparent strip)
9) Re-assemble in reverse and Hey Presto.
All Cured. Hopefully!
Nov 03, 2007 | Brother MultiFunction Center MFC-440CN...
BRother printer error code 41
The printhead is defective. Call brother hotline. Because this is a very common error (due to malconstruction on the mfc 3820 ) they might replace it for free. And when asked: OF COURSE YOU HAD ALWAYS RUN THE UNIT BY ORIGINAL INK CARTRIDGES!!!! :-) (take the ink carts out before sending or giving it to a service dealer!)
Oct 14, 2007 | Brother MFC 3820CN All-In-One InkJet...
Brother MFC-440CN InkJet Printer Logo
111 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
