Question about Mitsubishi WS-55809 55" Rear Projection Television
Mitsubishi 55 inch picture problem
I have a problem with my 55 in rear projection mitsu. I turn it on and I get a 3d effect after about 1-2 minutes of watching the tv. When it is shut off for a few minutes about 3-4 minutes and I turn it back on it is fine for the 1-2 minutes again and go back to 3d. I did notice that I still get okay color but it does only seem to have 2 colors. I have not tried to line up the colors yet due to I have never done it befor and would have to find my remote to do it. I was just wondering if I might have another issue going on with the tv.
Thanks
  • 3 more comments
  • drirules Oct 05, 2008
    I have the exact same problem. I hope someone out there knows what part I need to fix this. I had it fixed once before, but like a dummy I didn't pay attention to what the technician did.
  • mowermanbp Oct 05, 2008
    what i did i went in the front of the tv and turned off the red tube and the picture is not 3 d anymore. however the color is not right. at least i can watch the tv without getting a head ache
  • medimic Oct 11, 2008
    Has anyone figured this out yet? I am having the same problem but with a concave sceen as well.
  • cbolitho Dec 10, 2008
    Same exact problem as above. After a few minutes the screen gets all screwey and the colors appear not to be converged. It also seems to gets worse at it moves out toward the edges. I tried the convergence settings in the advanced menu but it didn't help.
  • Anonymous Dec 17, 2008
    I have the same problem you describe. When I rock the TV gently back and forth it is corrected. Sometimes it works fine for hours. I have read it may be a bad solder joint and can be fixed.
    Top Expert:
  • Mitsubishi Master
  • 25,330 Answers
That is an easy fix. There are bad solder joints in the convergence unit and line stage. For an experienced engineer, about 20minutes will find them all.
Posted on Apr 20, 2017
  • 87 Answers
SOURCE: Mitsubishi vs 5051 rear projection tv sound but no picture
No video but good audio Mitsubishi VS5051. Check R509 and R 519, 100 ohm resistors located on the main PCB near the flyback transformer. Also bad connections on any of the yokes and the vertical output IC will cause the same problem.
Posted on Nov 05, 2007
  • 3 Answers
SOURCE: Samsung HCM553W 55 in. Rear Projection Television - image duplicated
Hello, I am a Samsung TV repair man. What happened was one of your bulbs in your tv has burnt out. you have to contact your samsung repair phone line. how old is that tv? do you have a warranty? if you do, it might be repairable for free. I hope this info is useful!
Posted on Apr 20, 2008
Slinteriors
  • 8617 Answers
SOURCE: TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Posted on Jun 15, 2008
SOURCE: Mitsubishi 50 inch projection tv
you probably have a problem with the convergence board.
Posted on Apr 05, 2009
Slinteriors
  • 8617 Answers
SOURCE: blinking green timer light on front nearpower button keeps blinking, tv will not turn on, unplugged for 24 hours and tried again, also hit system reset and still nothing.
Thats a common problem when the caps on the DM need replacement. They will function fine untill power is interupted then the set will not complete the boot sequence when power is reapplied and the led will just continue to blink. Hers a link to the kit that will usually repair that issue the kit comes with instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
Posted on May 09, 2009
I have a Mitsu ~ HDTV 1080 #65511 all the colors are out of wack. I can not find a place to align them and no longer have the manual ..
Tv have colors lines R,G,B mis alignments,have colors shadows picture or 3D pictures look alike?Tv have problems known as a convergence pictures problems.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too,this parts on the convergence board must have be replaced.To fixed the convergence board to solved tv convergence pictures problems.The shops will cost u like $300-350 for parts and labors.
Jul 26, 2011 | Mitsubishi WS-55809 55" Rear Projection...
My Mitsu rear-projection WS-B55 was purchased in '03 or so. Now the screen is sometimes turning red. I can do a system reset, and the color goes back to normal. Then it eventually (maybe days later)...
No,pictures go all red?Pictures have colors shaded shadows or 3D pictures look alike?Yes,than the tv it is developing a problem known as a convergence problems it dying.The tv convergence board have problems,must be resoldering those 2 or replaced 2 STK covergence ICS and some or all of it resistors too.To fixed the tv convergence board,to solved the convergence picture problems.The shop,will cost u like $300-350 for diagnose the problems and do all the resoldering work or replaces those parts on the tv convergence board.
Apr 08, 2011 | Mitsubishi WS-55809 55" Rear Projection...
The top and bottom of the picture makes a rainbow effect toward each other in the center of the screen++++++++TV. model 3 ws55807 it's a 55 inch screen the problem occurs all the time. I have no TV repair...
This tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than this tv have a dead convergence board.The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.Fix the tv convergence board to solved the tv convergence pictures problems.The shop,will cost u like $300-350 for parts and labors.
Feb 08, 2011 | Mitsubishi WS-65807 65" Rear Projection...
My 55"mitsu medallion has a
Please define what you mean by a poor picture, 3 d looking or what?
SD TECH
Dec 27, 2010 | Mitsubishi WS-55413 55" Rear Projection...
Color & picture problem
need convergence ic stk392-570 or stk393-110
Jun 04, 2009 | Mitsubishi WS-55909 55" Rear Projection...
Out of focus
You have a convergence problem, probably the convergence electronics are going out or the TV has been violently moved and needs a mechanical alighnment. Small adjustments can be made from the menu.
May 17, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Black and white picture
you have the cables hooked up the wrong way
Nov 09, 2008 | Mitsubishi WS-55809 55" Rear Projection...
4 pin or 6 pin
It has neither. It is not firewire capable.
Jul 17, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Projection tv
This symptom indicate that your tv convergance ic faulty need to replaced ( change out all the two ic )it will solve the 3D effect problem,hope it will help.
Aug 03, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Tv wont turn on
This problem very well could be a DM board problem. I have a how to fix file if this is indeed your sets problem. Leave your email and I will send it to you. Good Luck
Jun 15, 2007 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
66 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
