Question about Canon PIXMA MP530 All-In-One InkJet Printer
Installing cartridges I can not figure out HOW to install the ink cartridge, I can't even see where they go.
    Genius:
  • 1,124 Answers
Would like instructions for installation of new ink cartridge in 6500A printer
If you have trouble viewing the video or to view the video in a different size, click here to play the video on YouTube Step one: Open the All-in-One
  1. Press the Power button (c01602202.gif ) to turn on the product, if it is not already on.
  2. Open the cartridge-access door. The carriage moves to the center of the product. Wait until the carriage stops moving before proceeding. Figure 1: Open the cartridge-access doorc01638336.gif
Step two: Replace the old cartridge
  1. Press in the tab on the front of the cartridge, and then pull it out and up to remove it from its slot. Figure 2: Remove the cartridge from its slotc01495178.gif
    CAUTION: Do not lift the gray latch next to the carriage to install the cartridges. Doing so can result in incorrectly seated ink cartridges and printing problems. The latch must remain down to correctly install the ink cartridges.
  2. On the replacement cartridge, pull the orange pull-tab straight back to remove the plastic wrap. Figure 3: Remove the plastic wrap c01493650.gif
  3. Twist the orange cap counterclockwise to snap it off the cartridge. Figure 4: Remove the orange cap c01495123.gif
  4. With the cartridge contacts facing the printhead, slide the cartridge into the correct slot. The color-coded icons on the cartridge and in the printhead indicate the correct slot. Figure 5: Insert the ink cartridge c01493652.gif
  5. Press down on the ink cartridge until it clicks firmly into place. Figure 6: Press the cartridge into place c01493653.gif
  6. Repeat these steps for each cartridge that you want to replace.
  7. Close the cartridge access door. The carriage moves to the right side of the product.
Jul 27, 2011 | HP Officejet 6500 Wireless All-in-One...
Even with a new cartridge inserted, the printer does not print properly. The printer does not indicate that a new cartridge is needed. How do I clean the printer head? It is a HP Photosmart C3180 al in...
Step one: Complete the alignment process If you have already installed new print cartridges, follow these steps to complete the alignment process.
  1. After installing a new print cartridge, wait at least 20 seconds for the print cartridge alignment process to start.
  2. Wait for the print cartridge alignment process to fully complete.
  3. Make sure that the alignment page has printed on plain, white paper that has no other printing on it. If you need to create a new alignment page, load the tray with letter or A4 unused plain white paper and turn the product off and on again to create the page.
If an alignment page does not print when the product is turned on or off, the issue is resolved. If an alignment page continues to print when the product is turned on or off, you should replace the cartridges with new HP cartridges. Continue to Step two: Remove the print cartridges. Step two: Remove the print cartridges Follow the steps below to remove the cartridges. NOTE: When you remove and install the same print cartridge, the unit will not align the print cartridge as the unit remembers the alignment values for that print cartridge.
  1. Press the Power button to turn the product on. The Power button is lit when the unit is on. Figure 1: Power button lit c01336350.gif
  2. Make sure that the paper tray is down, and letter or A4 unused plain white paper is loaded in the paper tray.
  3. Lower the access door until it stops. Make sure that the print carriage moves to the right side. Figure 2: Lower the access door c01336351.gif
  4. Wait until the print carriage is idle and silent, and then using your thumb, lightly press down on a print cartridge to release it. Figure 3: Print carriage c01336352.gif
    • If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
    • If replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.
    Figure 4: Proper position of the print cartridges c01336353.gif 1 - Tri-color print cartridge 2 - Black or Photo print cartridge
  5. Pull the print cartridge toward you and out of its slot.
Step three: Install the new print cartridge
  1. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. Figure 5: Remove the tape c00312625.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00312564.gif
  2. Slide the new print cartridge forward into the empty slot. Then gently push on the upper part of the print cartridge forward until it clicks into the socket.
    • If you are installing the tri-color print cartridge, slide it into the left slot.
    • If you are installing a black or photo print cartridge, slide it into the right slot.
    Figure 6: Print cartridge locations c00652788.gif 1 - Print cartridge slot for the tri-color print cartridge 2 - Print cartridge slot for the black and photo print cartridges
  3. Close the print cartridge access door. Figure 7: Closing the print cartridge door c00652789.gif
  4. If you installed a new print cartridge, the print cartridge alignment process starts after about 20 seconds.
  5. The unit aligns the print cartridges. Recycle or discard the print cartridge alignment sheet.
If you have completed all the steps listed above and are still experiencing a problem, service the product. Cause The product aligns the print cartridges every time at cartridge installation or replacement to ensure the highest-quality prints. The alignment page continues to print when the product is turned on or off, or when a print job is started, for any of the reasons below.
  • The automatic alignment process is not complete.
  • The ink cartridges are not properly installed.
  • One of the ink cartridges is defective.
  • One of the ink cartridges is low or out of ink. Black and all three colors must be available.
  • Protective tape on a new ink cartridge has not been removed.
  • Contacts on the ink cartridge are not meeting the contacts in the carriage correctly.
  • Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
  • The product needs to be serviced.
Aug 28, 2008 | HP Office Equipment & Supplies
My hp d2360 is not working properly and i bought new cartridge but printer wasnt recognize the cartrige..
Please follow the steps below to install the Cartridge:
Install or replace the print cartridges
  1. Turn the printer on. The cartridge cradle will not move if the power is not on.
  2. Open the printer cover. Figure 1: Printer cover openc00658567.gif
  3. Wait until the print cartridge cradle moves to the center of the printer and is idle and quiet.
  4. If you are replacing a print cartridge, press down on the print cartridge to be replaced, and then slide it out of the print cartridge cradle. If you are installing print cartridges for the first time, go to the next step.
    NOTE: HP recommends using a print cartridge protector to store an opened print cartridge for later use. Figure 2: Print cartridge being inserted into a print cartridge protectorc00658568.gif
  5. Remove the new print cartridge from its packaging and carefully remove the plastic tape. Hold the print cartridge so that the copper strips are on the bottom and facing toward the printer. Figure 3: Removing the protective tapec00658569.gif
    CAUTION: Do not touch the print cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections. Do not remove the copper strips. They are required electrical contacts. Figure 4: Print cartridge facing upc00658570.gif 1 - Ink nozzles 2 - Copper contacts
  6. Slide the print cartridge at a slight upward angle into the cradle until the cartridge snaps into place. Figure 5: Installing the print cartridgec00658571.gif
  7. Repeat steps 3-4 for the remaining print cartridge.
  8. Close the printer cover. The printer automatically prints a calibration page.
Mar 07, 2011 | HP Deskjet D2360 InkJet Printer
I don't know how to install the cartridgre on my new printer J 3680 Could you please tell me how? Thanks,
Follow the instructions below to install the print cartridges for the first time. Installing print cartridges Step one: Install the print cartridges Follow these steps to install the cartridges.
  1. Open the cartridge door. The carriage moves to the far right side of the product. Figure 1: Open the cartridge doorc01133347.jpg
  2. Remove the new cartridge from its packaging and, being careful to touch onlythe black plastic, gently remove the plastic tape by using the pink pull tab. Figure 2: Remove tape from cartridgec01107115.jpg 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections.Do not remove the copper strips. They are required electrical contacts. Figure 3: Do not touch the ink nozzles or copper contacts.c01107116.jpg
  3. Slide each new cartridge forward into the empty slot. Then gently push theupper part of the cartridge forward until it clicks into place.
    • Insert the tri-color cartridge into the left slot.
    • Insert the black cartridge into the right slot.
    Figure 4: Insert the cartridgec01107117.jpg
  4. Close the cartridge door.
Step two: : Align the print cartridge The product prompts you to align cartridges every time you install a cartridge. You can also align the cartridges at any time from the control panel, or byusing the software you install with the product. Aligning the cartridgesensures high quality output.
  1. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
  2. Press OK. The product prints an alignment page.
  3. Place the alignment page print-side down on the scanner glass.
  4. Press OK to scan the alignment page. When the scan finishes, the alignment is complete.
NOTE: If you have colored paper loaded in the input tray when you align the cartridges, the alignment will fail. Load unused plain white paper into the inputtray, and then try the alignment again.
Sep 13, 2010 | Office Equipment & Supplies
Whats the meaning of error in canon e5 error?
"E5: The ink cartridge(s) is not installed. / The ink cartridge(s) cannot be recognized.
The ink cartridge may not be installed properly, or an unsupported ink cartridge may be installed.
Install a recommended ink cartridge.
Make sure to install both ink cartridges even when you set the machine to use only one ink cartridge in printing.
If one of the ink cartridges is missing, this error can occur."
Jul 22, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Won't print after replacing cartridges
The following text copied from HP website to tackle this problem. minimtop.gif Follow the instructions below to install the print cartridges. NOTE: If you are installing ink cartridges in the unit for the first time, be sure to use only the print cartridges that came with the unit. The ink in these cartridges is specially formulated to mix with the ink in the print head assembly at first-time setup. s.gif Installing the print cartridges minimtop.gif
  1. Verify that the unit is on.
  2. Open the ink cartridge door. Figure 1: Opening the ink cartridge door c00718797.gif
  3. Squeeze the gray tab below an ink cartridge slot to release the gray latch and then lift the latch. Figure 2: Lifting the latch c00721793.gif 1 - Ink cartridge latch for the black ink cartridge 2 - Ink cartridge latches for the color ink cartridges NOTE: The ink cartridge areas are color-coded for easy reference. From left to right, the ink cartridges are black, yellow, light cyan, cyan, light magenta, and magenta.
  4. Remove the new ink cartridge from its packaging.
  5. Hold the ink cartridge by the handle and then slide the ink cartridge into the empty slot. NOTE: Make sure that the ink cartridge is inserted into the slot that has the same shaped icon and color as the ink cartridge. The copper-colored contacts should be facing the printer as the ink cartridge is inserted. Figure 3: Inserting an ink cartridge c00721795.gif
  6. Press down on the gray latch until it clicks into place. Figure 4: Closing the gray latch c00721796.gif
  7. Repeat steps 3 through 6 for each ink cartridge that needs to be replaced. NOTE: All six cartridges must be installed. The printer will not work if an ink cartridge is missing.
  8. Close the ink cartridge door. Figure 5: Closing the ink cartridge door c00718798.gif
s.gif s.gifHave a Good Day
Jul 17, 2009 | HP Photosmart C4580 All-in-One InkJet...
Printhead problem (black/yellow) on HP L7780
When you removed the paper it's possible your damaged it and that's why the message is not going away. Did you try to put the cartridge back in to make sure it had not come out of position and just remove the power cord for a minute then plugging it back it.
Here are the steps to make sure you properly change the cartridges and the heads...
Install the ink cartridges and printheads Step one: Install the ink cartridges All four ink cartridges must be correctly installed for the HP All-in-One to work. Follow the steps below to Install cartridges:
  1. Open the ink cartridge cover.
  2. Remove each ink cartridge from its package.
  3. Align each ink cartridge with its color-coded slot and then insert the ink cartridge into the slot. To ensure proper contact, press down firmly on the cartridges until they snap into place.
  4. Close the ink cartridge cover.
Figure 1: Installing cartridges c00841893.gif 1 - Open the ink cartridge cover. 2 - Remove the ink cartridges from the packages. 3 - Install the ink cartridges. 4 - Close the ink cartridge cover. Step two: Install the printheads Follow the steps below to install the printheads.
  1. Open the top cover of the printer. Figure 2: Open the top cover c00848391.gif
  2. If the carriage does not move to the left automatically, press and hold the Resume button (c00847980.gif ) for three seconds. Wait for the carriage to stop moving.
  3. Remove the cardboard cover from the printhead carriage. Figure 3: Remove the cardboard cover c00848392.gif
  4. Lift the printhead latch. Figure 4: Lift the printhead latch c00848393.gif
  5. Before installing a printhead, shake the printhead up and down at least six times while the printhead is still in its packaging. Figure 5: Shake the printhead while it is still in its packaging c00847983.gif
  6. Remove the new printhead from its package, and then remove its orange protective caps. CAUTION: Do not shake printheads after the caps are removed. Figure 6: Remove the printhead from its packaging, then remove the orange caps from the printhead c00847984.gif
  7. Insert the printhead into its color-coded slot. The label on the printhead must match the label on the printhead latch. Press down firmly on the printhead to ensure proper contact. Figure 7: Insert the printheads in the correct color-coded slots c00847985.gif
  8. Pull the printhead latch all the way forward, and then press down to ensure that the latch is properly engaged. You might have to apply some pressure to engage the latch. Figure 8: Close the latch c00848394.gif
  9. Close the top cover. Figure 9: Close the top cover c00847987.gif
Step three: Align the print heads Whenever you insert or replace a printhead, the printer automatically aligns the printheads to ensure the best print quality. If the printer does not print the alignment page automatically, start the alignment process manually. To start the alignment process manually:
  1. Press the Setup button on the control panel Setup and the number 6 on the keypad or scroll to Tools .
  2. Press 4 on the keypad or scroll to Align Printer . The alignment process starts.
Dec 01, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
New Cartridge error message
Follow the steps below to remove and replace the empty ink cartridge.
  2. Open the ink cartridge door. Figure 1: Opening the ink cartridge door c00819080.gif
  3. Squeeze the gray tab below an ink cartridge slot to release the gray latch and then lift the latch. Figure 2: Lifting the latch c00819081.gif 1 - Ink cartridge latch for the black ink cartridge 2 - Ink cartridge latches for the color ink cartridges
    NOTE: Theink cartridge areas are color-coded for easy reference. From left toright, the ink cartridges are black, yellow, light cyan, cyan, lightmagenta, and magenta.
  4. Pull the ink cartridge toward you out of it's slot to remove it. Figure 3: Removing an ink cartridge c00819082.gif
  5. Remove the new ink cartridge from the packaging.
  6. Hold the ink cartridge by the handle and then slide the ink cartridge into the empty slot.
    NOTE: Makesure that the ink cartridge is inserted into the slot that has the sameshaped icon and color as the ink cartridge. The copper-colored contactsshould be facing the printer as the ink cartridge is inserted. Figure 4: Inserting an ink cartridge c00819083.gif
  7. Press down on the gray latch until it clicks into place. Figure 5: Closing the gray latch c00819084.gif
  8. Repeat steps 3 through 7 for each ink cartridge that needs to be replaced.
  9. Close the ink cartridge door.
after Doing this all Follow the next step :-
Please Try This, I am sure it is going to workout.
Resetting the All-in-One
Press the On (fa37665.gif) button to turn off the unit.
  • Disconnect the power cord from the back of the unit.
  • Connect the power cord to the back of the unit.
  • Press the On (a477fdf.gif) button to turn on the unit.
Oct 21, 2008 | HP Photosmart C5180 All-In-One InkJet...
Ink cartridge problem! The following ink cartridges appear to be missing or damaged.
hi!!!!
try to clean the nozzle of your cartridge with the alcohol
or solvent used cotton
or replace the cartridge
try to email me ronaldsuboc@gmail.com
Sep 18, 2008 | HP Photosmart C7280 Printer
Black ink full won't print on pages
Here is resource page and "No cartridge " error info:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.html?reg=us&c=us&lang=en&prod=dcp110c_us
Why does my machine's LCD show "NO CARTRIDGE" even though I have already installed all the ink cartridges?
Description:
If the message "NO CARTRIDGE" remains on the LCD after you have installed the ink cartridges, then one or more of the cartridges may not be properly installed. Verify that the cartridges are installed correctly by following these steps:
Note
    Cartridges that have already been installed are no longer vacuum-sealed, so it is very important that these cartridges remain upright. If a cartridge is removed from the machine and placed on its side, air may be introduced into the ink supply tubes. As a result, repeated cleaning will likely be required before normal print quality is restored.
  1. Unplug the machine from the AC power outlet, wait approximately 10 seconds and then plug it back in.
    If the date and time appear on the display, the issue is resolved. If the display continues to show NO CARTRIDGE, continues to Step 2.
  2. Open the scanner cover by lifting it from the right-hand side until it locks securely into the open position.
  3. Remove the black ink cartridge by pulling the white plastic hook (locked over the edge of the ink cartridge) toward you, then lifting the cartridge out.
  4. The LCD should prompt you to install the black ink cartridge.
  5. Reinstall the black cartridge. Press down FIRMLY on the top of the cartridge until it is fully seated. Push the white plastic hook towards the cartridge to verify it is fully latched over the cartridge's top edge. Repeat STEPS 2 - 4 to verify each that of the color cartridges (magenta, cyan and yellow) is installed properly, then continue to STEP.
  6. Close the scanner cover. The unit should begin cleaning automatically.
  7. Good luck, Joe
  8. Please remember to rate all Techs who assist you for free :)
Jul 31, 2008 | Brother DCP-110C All-In-One InkJet Printer
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
99 people viewed this question
old marine
old marine
