We have a Magnavox AS642 tuner,cassette player, and CD player combination. The radio and cassette player still are working, it is the CD player that won't recognize a CD to play. A message will come up saying one disc, I then push play and it will say NO disc found. I have tried to play the cleaning CD and have tried to blow out any dust that might be in it. what can I do now to get a CD to play? Thank you Jeanie
How to get the laser unit repaired/ replaced on my portable CD player?
Most likely cheaper to replace than repair. The labor cost for such a fiddly repair would be more than a new unit.
Jan 22, 2016 | Magnavox 45 Esp Jogproof Portable Cd...
When i buy sony cassette tape, it records good on just one side of a cassette. the other side rather outside mic or inside off radio is very low almost impossible to hear up close.
Hello
Check and clean the mechanism parts of your casette player mechanism. Look whether there is dirt accumulated on the capstan shaft and pintch rollar of the mechanism. This is the main cause of tape slip and irregular output from it. OK.
Sep 22, 2011 | Philips Magnavox MCS225 17...
CD player has never worked Does not recognize
try cleaning the lens, if still dooest work try to adjust a tiny trimmer resistor in the board near the lens
May 05, 2010 | Marantz PMD-351 Combination CD Player /...
Where can I buy a power cord for my Magnavox portable cd/cassette player?
use the player direct power from the net other wise you have to buy a adapter with the power out for your device can be used universel
look first up how manny voltage you need 6 or 9 or 12 volt if you now thad buy a adapter with at least 1 or 2 amp how more how solid they are
Oct 31, 2009 | Philips Magnavox MPC421 Portable CD Player...
No video output from Magnavox VCR (MDV560VR)
You need to tune a chanel on your tv to the vcr signal, using an RF cable (aerial cable between vcr and tv). That is if your tv has an analogue tuner.
May 09, 2009 | Philips Magnavox DVD/VCR Dual Player
I have a JVC stereo system, cassette, 5 disc cd, tuner, I recently repaired an amplifier problem as one of the output IC's was burnt out. The set works fine if on radio mode. But the cassette and CD player...
I used to fix a lot of these type of units. It wsn't unusual for a wired or ribbon cable to either not get reconnected or not make good contact in it's socket. Also if it was a ribbon cable it good be put in backwards.
Dec 16, 2017 | Audio Players & Recorders
Olds Cutlass factory radio/cassette, radio doesn't work.
When you say tried different radio and it didn't work, does this mean the tuner acts like it is functioning, but you hear nothing out of the speakers?
If so, this stinks of a bad ANTENNA...
Mar 05, 2009 | 1987 Oldsmobile Cutlass Supreme
External tuner
if it's possible attach a free-view box to it.
Jul 29, 2008 | Philips Magnavox DVD/VCR Dual Player
I have a bose stereo in my 96 nissan Maxima that works poorly
there is a problem in the tape drive - possibly a bad belt- thats why the cassette adapter keeps ejecting itself- most add on xm tuners have the ability to broadcast its signal wirelessly-you press the menu button then turn the tuner to select the menu option that you want then press on the tuner control again to choose broadcast (fm signal and which channel you want to broadcast to the factory radio-try www.xmradio.com for more detailed info
Apr 16, 2008 | Car Audio & Video
104 people viewed this question
 Grubhead
Grubhead
