Won't turn on
Won;t turn on I used a new power cord = nothing I tried HP solution to reboot - no help Is there a reset switch? Its only a little over a year old and I hate to pitch it.
  • 8 more comments
  • Jnoscarjsc Oct 04, 2008
    led not flashing -- printer was turned off by the power strip and would not come on again
    printer will not turn on. the power cord has power the light on the end of the cord turns on when rebooted but goes out when pluged in I have followed HP instructions for this problem but did not work they suggested that if rebooting did not work then to have the printer serviced
    the modle is hpphotosmart c5140 all in one
    HP photosmart c5140 will not turn on new power cord has a green light on end that lights upwhen rebooted but goes out when plugd in
  • Jnoscarjsc Oct 05, 2008
    hp photosmart c5140 all in one will not turn on , your last coment was blown fuse . where is a fuse?
    HP photosmart c5140 all in one printer will not turn on. unable to get into the computer i I would have t0 completely dismantle it
    hp photosmart c5140 all in one printer will not turn on. I'll get back to you tomorrow. I micht come up with another clue to help you help me.
    hp photosmart c5140 all in one. Yes I have bypassed the surge protector. I think there must me a reset button, but it is not in plain sight. I believe I will try to find a service rep.
    I have checked the continuity on the power supply. HP photosmart c5140 all in one. there is no led indicators flashing in the printer
  • Jnoscarjsc Oct 08, 2008
    Won't turn on HPphotosart c5140 all in one. I was able to remoive the back and a side, Looking for a fuse or a reset button there was none. I won"t be taking the printer to a repair man , the cost would be prohibitate. Thanks for your helpm, I"ll be pitching it. John
    President:
  • 2,712 Answers
Seems to be an issue with the circuitry/wiring on the power board in the printer. Try plugging the printer directly into the wall socket and see if this changes anything.
Should that fail to resolve the issue, the only other option is to either get the printer serviced, or purchase a new one (whichever works out cheaper for you).
Cheers!
IrishDruid
Posted on Oct 05, 2008
    Genius:
  • 1,148 Answers
Look i would start out by taking the back cover off ,,check to see if the fuse is blown,,if not go to ,,hp customer care/chat,,they will get to the bottom of it,, there helpful,,good luck
  • 749 Answers
Have you tried bypassing the surge protector alltogether and plugging it straight into the wall?
  • 6,487 Answers
You need to completely dismantle this printer and check all parts that is casuing it not to power ON, and you may need also to replace some parts inside your printer thai is busted already...
Hope that helps........
  • Mark Gil
    Mark Gil Oct 05, 2008
    No problem feel free to contact us back for the update on your problem...
  • 928 Answers
I was able to fix someones printer about a week ago. I just had them remove the power box on the printer itself then connect it back up although you have to open up the printer to do this. DO NOT DO THIS IF YOUR UNIT IS UNDER WARRANTY. Its possible that its just a loose connection.
Posted on Oct 04, 2008
  • 1,879 Answers
Fuse blown
  • 1,183 Answers
HI,
Could you give us the model number for the printer, so that we can help you better here .
Thanks
Proton
  • Mandeep  Singh
    Mandeep Singh Oct 05, 2008
    Apologise , for not being able to accept your request, i lost my internet connection yesterday , due to some technical glitch. If there is no activity on the printer after , doing the steps that all the previous techs have told you to do and the there is no indicator light on the printer , like the power LED not turning green. The mostt likely failure on the printer is the NON PFC power supply on the printer. HP doesnot supply or service parts on the printer. You might need to get in touch witht he local tech , if they a powert supply to the printer. Otherwise it would be a better proposition to replace the printer.
    Thanks
    proton
    Genius:
  • 3,422 Answers
HI,
Click on the link below to open a webpage with title "The Printer will not Turn On, No Light Indications"
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=bpd05351
  • Priya darshan Oct 04, 2008
    Please let me know if you need any more help
    Master:
  • 479 Answers
Its because of short tracking on the board
  • tech gurus Oct 04, 2008
    can i hve the model number of ur printer too so that i can tell u if the particular board can be repaired or not
  • tech gurus Oct 05, 2008
    get your board repaired it will cost u near to $25 plus service charge.for cleaning servicing and reparing.it does not have any thing like fuse inh it it has a black colour chip which gets heated up and creates problem in the boars.and there is nothing like anything you can do it yourself.it is compulsary to get it repaired.the only chance of repair it manuall is if there is moisture on the mainboard you can clean it and the printer will start as normal.but still servicing and cleaning is required.
    Scholar:
  • 155 Answers
Have you tried connecting it to another outlet? If still nogo, I would suggest taking to a repair shop.
  • 1 more comment
  • Rachelle Aviles
    Rachelle Aviles Oct 04, 2008
    You may also want to check this link. If the problem is the circuit board, it has step-by step instruction if you are planning to do it yourself.
  • Rachelle Aviles
    The instructions in the link is for a HP deskjet 1220c though. You may want to post the model so we can be more specific.
  • Rachelle Aviles
    The circuit board could have shorted out. Explains why the light indicator on the power adapter turns off as soon as you plug it in. Yes, you need to have it serviced.
    Brigadier General:
  • 3,614 Answers
Is there any led indicators flashing on the printer...?
and may i know what happen before you got the problem on the printer...?
  • micromaster
    micromaster Oct 05, 2008
    test and check the continuity of the printer power adapter. it can be a short on this.
Digix bd 500. worked fine for a couple Weeks. now it froze up and won't turn on. the power lite is dimly blinking. but still won't turn on. is there a way to reset without turning on? I have check...
1) test the outlet wall for 120vac 2) test the power cord for open 3) test the power switch tv for defective 4) power supply inside faulty repair.
God bless you
Jul 25, 2013 | Televison & Video
My textbook 7p won't turn on
This tablet does t reset with the power button unlike other Android devices. When you hold down the on/off switch, it only drains the battery. If you see the color indicator still charging, allow a full charge.Then, only stay put and pulse the button for a moment quick and let it rest few seconds to try again and again. Only when u see a light coming out of the screen, and I recommend you do this with the power cord on, you hold the power switch down until the rebooting is iniciated. Let go til it is finish and see where the problem is. More likely, like mine, the Settings stop working and needs tune up for the CPU. Never leave an application running when closing your system. With or without internet connection.
Apr 20, 2013 | Tablets & eReaders
Wireless LAN button won't switch off.
Most Netgear routers have a recessed button on the back or bottom panel, marked "Reset" or "Restore Factory Settings". Because the button is recessed, you will require a thin tool to press it. Most people use a straightened paperclip.
  1. Power up the router, and wait for it to complete booting up, typically about one minute.
  2. Press the Reset or Restore Factory Settings button until the test or power led starts blinking. This takes about 20 seconds. Release the button.
  3. Wait for the router to reboot.
  4. Log in with the default password. If the reset was not successful, try these additional steps AFTER the router has finished rebooting.
  5. Unplug the router's power.
  6. Press and hold the Reset button. While the button is held down, reconnect router's power.
  7. Continue to hold the reset button for 20 seconds after reconnecting the power.
  8. Wait for the router to reboot.
  9. Log in with the default password.
Apr 17, 2013 | NetGear N600 Wireless Dual Band Router
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this time
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the hom
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
I have an hp m8425f and the tower won't turn on,
Remove the Power Cord, then press and hold the power button for 30 seconds. After 30 seconds, plug the cord back in and press the power button. If it works, you had a Static Charge Buildup that had to be released.
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.If the above two steps fail, pull the main power plug that comes out of the power supply and plugs into the motherboard. The end that plugs into the motherboard is probably about two inches long, Grab the release latch on it and press it while pulling up to unplug it. Wait 30 seconds then plug it back into the motherboard. Push it back in firmly.
Try turning on the system.
Apr 04, 2012 | HP Computers & Internet
Why won't my printer print after I installed the software? It says its ready but nothing will print
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 18, 2011 | Lexmark PhotoJet Z705 InkJet Printer
Looks like dead. when powering on, control panel shows "self test" and then nothing shows up on the panel and printer is dead.
Try to reset the memory on your HP Officejet. Do the following:
  • Turn off the power to the HP Officejet and unplug the power cord.
  • Hold down the "# + 9" button.
  • Reconnect the power cord and continue holding the button for another five seconds.
  • Turn the HP Officejet on, and the memory should be reset.
If this won't work, you can try to upgrade the firmware but you can only do this if the printer is still detected by the Computer. You can check control panel and see if the printer is listed as "online" or "ready".
If the above steps won't work. Your printer is deem defective and needs to be replaced. You can try calling HP support for more info. Here's their US number: 1-800-474-6836
Hope this helps.
Jul 07, 2011 | HP Officejet 5510 All-In-One Thermal...
I have a brand new KitchenAid mixer that is 5 years old and never used. I unpacked it this morning and it won't turn on, no noise, no movement, nothing. Help.
Please check manually the motor and see if it moves freely. Now make sure that the power plug and the connections to the switch are not tampered , check the continuity of the plug to the switch and to the motors.
If you notice any dirt or insects make sure that this has not clogged on the motor. If so clean using a degreasing spray- WD40- would be recommended.
If the motor is tight , lightly oil or degrease using the spray while manually rotating.
Once this is done connect the power while taking all precaution. Use the meter to check the flow of the circuit to the switch and to the motor. If there is a trip switch see that it is reset.
If there is power to the motor and still it does not work the brushes might be dirty and might need a cleaning/ reset.
Jul 07, 2011 | Vacuums
HP VP6210 won´t turn on at all
try to replace all the capacitors on the motherboard. This are the only parts that leak in time. Try otherwise to reset to counter or update the firmware on your machine on the infocus site.
Goodluck !
Sep 04, 2008 | InFocus LP120 / 1000 Lumens / XGA / DLP...
the fuse (if it has one) is on the power supply next to where the plug plugs in. if the fuse is ok, replace the power supply.
Jul 18, 2008 | Office Equipment & Supplies
88 people viewed this question
jasbo
jasbo
