Question about E-Machines Computers & Internet
About 2 weeks ago my sister's computer(emachines t3589) shut down I first thought that was the power supply,so I replaced it ,but the problem didn't go away,then I put the old power suply back on the computer.The green lights comes on but the computer won't come back on. pleas help thanks
    Genius:
  • 1,124 Answers
The CPU fan is working?
The power button is working?
Did you connect the cables right?
If none of above fix your problem, seem to be a motherboard problem
Posted on Oct 04, 2008
My e machine computer will just shut off after 5 or 10 min.,
I had an Emachines W3609 that did the same thing, I changed the 350-watt power supply with a 550-watt and it still shut off, even using the newer one. I thought just the first one was bad but I guess not. It had more than enough power to power it up but nothing. And it used to randomly restart at times and then just shut off. Try and get a new hard drive maybe that will help. Good luck!
Jan 03, 2013 | E-Machines Computers & Internet
Emachines e4026 non-responsive
I don't think it's an overheating CPU. It would stay on for a bit longer if it was that. My best guess is a power supply issue. Either your power supply is bad, or more likely something is pulling too much power from it. Emachines are notorious for using the bare minimum hardware... possibly the extra hard drive is pulling more juice than the power supply can handle, so it shuts down. Try disconnecting power to the new hard drive and see if the machine comes up. If it does, you need a new, higher wattage power supply.
Sep 06, 2007 | E-Machines eMachines Desktop PC
Emachine T5026 power supply ** FREE SHIPPNG ** (EM12EB324PIN) Power Supply: my cpu fan is running but at a low speed. When i t...
In my opinion you have a faulty power supply, replacing only the fan may not solve your problem. Try replacing the power supply.
May 16, 2010 | E-Machines Emachine T5026 power supply **...
My A215 wont stay powered up. It shut down and
Try running the computer on the Battery power and check if the power sustains. If not, then disconnect the power cord and remove the battery and leave it for a few hours then try turning it on.
If the problem exists then the power supply unit is required to be replaced. You may contact service center to get the power supply unit replaced.
Oct 01, 2009 | Toshiba Satellite A215-S7422 Notebook
PC SHUT down
three things i find to cause this,
one, the power supply is bad,
two, the power connector is lose or not push in
three, the heat sink on the processor has come off. This will cause the cpu to over heat and self shut off.
to test the power supply, pull the connector off the mother board and short the green wire to any black wire with a paper clip, this will switch on the power and see if it stays on.
if you need to replace it, you cannot use a regular atx power supply. E machines have a different pin out.
Aug 12, 2009 | Dell E151FPp 15" Flat Panel LCD Monitor
EMachines t3626 shuts down at random
You may be dealing with bad or overheating with your processor or memory. If possible, try swapping out your memory chips to see if that does the trick. If not, you will have to try swapping out the processor (much less likely you'll be able to swing that).
Jul 28, 2009 | E-Machines eMachines Desktop PC
E-Machine T6216 PSU fan runs, computer will not boot
It is the power supply. EMachines have a long history of using cheap power supplies. I have replaced over a dozen EMachine power supplies with a 100% success rate. They are easy to replace and can be had for less than $20. Just write down the model number and take that to a computer parts store or remove the power supply and take that with you. Steve
Jan 26, 2009 | E-Machines eMachines Desktop PC
First Power Saver Came Up & Now Fans Aren't Working
It is very possible that the power supply has gone out. If you hear the drives spinning up then its not. check the power supply thats what I'd do first
Dec 20, 2007 | E-Machines eMachines Desktop PC
Computers & Internet Logo
78 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
