the oven, timer, or clock will not work now. I think i locked it out by accident. How do i unlock it?the oven, timer, or clock will not work now. I think i locked it out by accident. How do i unlock it?
You can't post conmments that contain an email address.
Whirlpool Gold YGY397LXUS Slide In Electric Range, 30in, 4.5 cu.ft, with AccuBake Temperature Management System, Self-Cleaning Oven, Delay Bake, ... This AccuBake system uses a sensor to monitor the oven temperature; it will then turn ...
I have a Whirlpool Gold double oven and someone came to house and told me it ... black panel on whirlpool accubake system self cleaning oven gives double ...
Somewhere hidden in the stove, should be the engineers spec sheet. It should be one of these images
On this website: http://www.repairclinic.com/0078.asp#Whirlpool , it shows all of the codes for the Whirlpool errors. Based on the remarks, if it shows a "4 digit failure code" it is "Shorted
keypad"
"Replace
Electronic
Range Control/Clock (ERC)"
But verify this as I am not an appliance repair specialist. I am a computer nerd who just knows how to find information. I am actually trying to figure out an answer to my own problem with my Whirlpool Gold Accubake.
Wisco, this is a code for a overtemperature. You want to check the temp sensor in the oven. You need to ohm it out. Should read 1080 ohms at 70 degrees. If the sensor checks out ok, then I would suspect a welded or closed relay on the control itself. Catriver.
